Question about Roland Vs-2000CD Digital Studio Workstation System
My Roland VS2000 won't let me erase a project it says it's erasing it and then immediately asks me to store the current project. Clicking yes or no doesn't matter, same outcome. When I look at my project list on the drive. It is still there. Any ideas?
2 Suggested Answers
SOURCE: how do i return my roland vs2000 to factory
Call Roland's tech support, they will help you with anything you need. They're among the best in customer support 800-868-3737
Posted on Jan 02, 2011
How do I reset my I-pAD back to original factory settings
1. On the Home screen, tap "Settings" to bring up the Settings screen. 2. Tap "General"
3. And then tap "Reset". This brings up the Reset screen which will give you the following options. a. Reset All Settings - this resets all your settings back to factory default but does not erase your content data. b. Erase All Content and Settings - this resets all your settings and erase all your content data. You might want to do a sync with iTunes before performing this erase if you want to keep any music or apps that you have downloaded. c. Reset Network Settings - this deletes your Wi-Fi network settings. d. Reset Keyboard Dictionary - this clears any history in the dictionary such as the history of the keyboard suggestions that you've rejected or accepted previously. e. Reset Home Screen Layout - this simply resets your Home screen icons back to the original default layout. f. Reset Location Warnings - this erases any location preferences that was set for your apps. For example, GPS-aware apps often popup a location warning asking if you want the app to be aware of your current location. Your answers to these questions are stored by your iPad for each app. This reset will erase these answers so that the app may popup the prompt asking for your location permission again the next time you use it.
4. After selecting one of the above options, the iPad will ask for confirmation that you really want to perform the reset. If yes, confirm by tapping "Reset".
Jul 16, 2014 | Apple Ipad I-pad
This Greg thanks . how do I clear the code?
Clearing Codes
Print
Stored faults should only be cleared by use of the DRB-II or similar scan tool. Disconnecting the battery will clear codes but is not recommended as doing so will also clear all other memories on the vehicle and may affect driveability. Unplugging the PCM connector will also clear codes, but on newer models it may store a power loss code and will affect driveability until the vehicle is driven and the PCM can relearn its driveability memory.
The -ERASE- screen will appear when ATM is pressed at the end of the stored faults. Select the desired action from ERASE or DON'T ERASE. If ERASE is chosen, the display asks ARE YOU SURE- Pressing ENTER erases stored faults and displays the message FAULTS ERASED. After the faults are erased, press ATM to return the FUEL/IGN MENU.
Sep 29, 2013 | 1993 Jeep Grand Cherokee
My recording studio is stuck on the project load screen
Your VS-2000 is showing symptoms of fragmentation--resulting in the unit freezing or failing to completely load. The only possible solution is formatting the hard drive. Formatting erases all data on the drive.
Note: If you have any files that you need to keep, you may contact our Roland Customer Support department (323-890-3740) to arrange a "Data Recovery" service. Our service technicians can attempt to recover any data that is in your hard drive. Customer Support is available M-F 8:30am-5:00pm Pacific time.
CAUTION!!! Formatting the hard drive erases ALL recordings and data on the drive. This includes any installed plug-ins as well. Be sure to back up all of your project data (recordings) and plug-ins to CD/DVD(s) before formatting the drive.
Unlocking the System:
1. With the VS-2000 powered off, press and hold the TRACK/STATUS button for track 4 and the FX 2 button.
2. With both buttons pressed, turn on the VS-2000's power. Continue holding the two buttons until the display has loaded completely. This can take several minutes.
3. Once the system has loaded completely, release the buttons.
Formatting the Hard Drive:
Note: The format steps below pertain to using the VS-2400's on-board LCD screen. If you're using an external VGA (video monitor), press and hold HOME and press F6 to switch to the on-board LCD.
1. Press SHIFT AND F1/PROJECT.
2. Use the CURSOR buttons to Select "IDE:0".
3. Press PAGE until "FmtDrv" is displayed above F2.
4. Press F2.
5. CURSOR to "Physical Format".
6. Turn the TIME/VALUE dial until "ON" is selected.
7. CURSOR to "Surface Scan".
8. Turn the TIME/VALUE dial until "On" is selected.
9. Press F5 (OK).
10. Press ENTER/YES twice.
Oct 13, 2011 | Roland Vs-2000CD Digital Studio...
My roland vs 2000 says not found any drivers when i turn it on can it be fixed
I think your best option is to try downloading and installing the latest system update from the Roland Site link below.
http://www.rolandus.com/products/productdetails.php?ProductId=602
May 06, 2011 | Roland Vs-2000CD Digital Studio...
Hi, just wanted to know how to delete previously saved seasons and can one play an entire season playing for different teams
If you want to delete your saved game follow these steps:
1. Find the saved game by entering the Wii Options at your home screen.
2. Click on Data Management and then Save Data. You can access there your saved games.
3. Select the saved game you want to delete. You can navigate through the files by clicking the right and left arrows on the screen or by pressing the "+" and "-" buttons on the Wii remote.
4. Erase the file by clicking on the right-hand "Erase" box, and when prompted to erase the save data, select "Yes" on the bottom of the screen. The Wii will immediately delete the saved game from your Wii internal memory.
Mar 09, 2011 | Nintendo NBA 2K10 for Wii
How to delete the tracks on my roland spd-s that Ive made Ive had it only for 3 days
Permanently erasing the currently selected wave.
1. "[>] to delete." is indicated. Press [>].
If you hold down [SHIFT] and press [ALL SOUND OFF] in wave mode, you can jump to this screen.
2. A "delete, sure?" indication appears. Press [ENTER] to execute the deletion, or press [ "now processing.." is displayed. After execution, a "complete!" indication appears and the SPD-
S returns to the wave mode.
Source: page 51 of the user manual
pdf download: http://www.roland.com/products/en/_support/om.cfm?PRODUCT=SPD-S
Feb 02, 2011 | Roland Spd-S Sampling Percussion Pad...
How to delete on RCA VR5220A
Erasing Files and Bookmarks:
To erase files or bookmarks, while playback is stopped:
1. Press x once.
2. Press '<< / >>' to select one of the erasing options:
  • Delete the current file (DEL 01)
  • Delete all files in the current folder (DEL AL)
  • Format the memory of the player (FORMAT) (Caution! All data inside the memory will be erased)
  • Delete all bookmarks in the current file (DEL BK)
3. With one of the above options selected, press and hold x for about 3 seconds to confirm your selection and start the deletion.
  • File numbers that come after erased one will be moved forward by one automatically.
  • Press to cancel erasing all files. The undeleted files are saved automatically.
  • Formatting the internal memory may be required when encountering compatibility problem, etc.
  • You may also format the player when connected to a PC (by right-clicking on the player's drive name or letter and select "Format" from the menu). Make sure you select FAT or FAT32 as the file system.
May 03, 2010 | RCA Audio Players & Recorders
I have 5.8 vtech phone. A set of 3. I would like
Delete a Number/Name Stored in the Directory
1. Press . The screen displays DIRECTORY.
2. Press or to scroll alphabetically through entries stored in directory.
— OR —
Press the dial pad key for the first letter of the entry you want to delete.
3. When the screen displays the entry you want to delete, press select . Then press or until
ERASE flashes.
4. Press select . The screen displays ERASE NO YES and the number. The current choice
flashes.
5. Press until YES flashes.
Sep 07, 2009 | Lands Phones
Roland VS2000 Doens't load project after power accident
turn it on and just let it load..it may take like 20 hrs or so but it will come on...and yea when it does you might not have anything that you had on there but you can start over and it will work like new..worked for me
C.D.
Mar 19, 2009 | Roland Vs-2000CD Digital Studio...
Memory Full - Garmin nuvi 200
Turn off the device, push and hold in right-down corner on the display, and turn on the device. Hold your finger on the display, until you see "Do you really want to erase all user data?" message. Then click "Yes"...
Hint:
All private data will be erased. The user POI's too. You can backup the file G:\Garmin\gpx\current.gpx before erasing procedure.
Mar 23, 2008 | Garmin Nuvi 660 GPS Receiver
Roland Vs-2000CD Digital Studio Workstation System Logo
121 people viewed this question
Top Roland Audio Players & Recorders Experts
Electric Dime
Electric Dime
Vito Vacirca Jr.
 Grubhead
Grubhead
Are you a Roland Audio Player and Recorder Expert? Answer questions, earn points and help others
