Question about Samsung Propel Pro SGH-i627 Cell Phone
It won't turn on. i've plugged it into the charger, checked the battery, removed the sim card, nothing:(
    Genius:
  • 1,417 Answers
this means that your phone have developed what is call power problem . i.e
the power witch button is bad /forth from the panel
the way out to solve your phone problem is you have to unscrew your phone case to it panel with phone tools of it size gently then locate the position of the witch before unscrewing.
take a note if there is any form of damage or liquid in it please if yes or no ! clean the surface of the panel very well with little spirit and cottonwood.
then allow it to dry up it self that is the panel
after you have allow it to dry up it self then you can then screw it up at it was i.e the way you unscrew it
after all this you will be able to make use of your phone again.
please note if you can not do this your self , to avoid more on your phone then you advice to take it to a very good phone work shop around to do the fixing.
Good luck and thanks for using fixya.
Posted on Apr 27, 2010
My Motorola electrify won't turn on or charge. It
maybe your battery or your phone os .... try a new battery if nothing happens... try re flash your phone
Jun 02, 2013 | Cell Phones
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I have a Dell Precision M60 laptop and the charger adapter's led light is on when i plug it in, but the laptop won't turn on.I've replaced the battery and tried a different charger but that...
Unfortunately it sounds like you have an issue with your motherboard. If you remove the battery and just try to power on the laptop using the AC adapter and it still won't power on then it's probably the motherboard. The power supply circuit (where the AC adapter plugs into) for the motherboard is integrated into the motherboard.
Sorry. If it's still under warranty Dell will replace the motherboard.
Sep 10, 2011 | Dell Precision M60 Notebook
I have a Storm 9530. One evening I plugged my phone into my wall charger (not computer) to charge and when I woke up the next morning... low and behold the infamous battery with red line showed on the...
It could be the charger, the phone's power interface, or your battery. When you plug the phone in to charge it, does it recognize the charger and show the lightning bolt symbol for charging?
If you use your computer's USB port to charge it instead of the wall charger, does it act any differently?
Aug 16, 2010 | Cell Phones
Reset button ?
Sometimes there is a reset button and sometimes you have to reset it through a menu. Of course, if it won't turn on, then you can't get to the menus.
May I ask, what is you Toshiba camcorder's model #?
Jul 31, 2010 | Toshiba Video Cameras
Htc 8925 error "sim card not detected" have removed and replaced sim card have removed battery and rebooted have swithed sim card to annother phone, works fine have replaced sim card with a working sim...
I see this is an older post but I wanted to post the solution that helped me after a very frustrating 30 minutes. I was having the same problem. I bought a new phone (HTC 8925), and when it arrived, I plugged it into the wall charger and inserted the SIM card. I still got the "SIM card not detected" error. After removing an inserting, checking all possibilities of having done it wrong, and searching the internet only to not find the answer, I tried something that worked.
My solution: When I unplugged the charger and reinserted the SIM card, it worked immidiately. It was as if being plugged into the charger was not allowing the phone to reboot completely, even though I was powering the phone down and back up again. Since this was the solution, if you are having the problem and not connected to a charger, I would try a soft reset by pressing the stylus into the button (tiny whole) to the right of the USB port.
Mar 23, 2009 | Cell Phones
Frozen phone
Hello Gary,
Remove the back cover, remove the battery and remove the Sim Card and Memory if you have it, now put the Sim card back in put the battery back in and try and power up, if it powers up add the memory back in. if it dose not power up try to plug in the charger and power it on if this dose not work go to you local Service Provider and have them check the battery. if the battery checks out ok then you will need to replace the Phone.
Hope this helps,
Jason
Dec 03, 2007 | Motorola Mobility RAZR V3
Cell phone problem
try removing the battery, removing the sim, plug in the charger -> try turn on. Insert battery (no sim), plug charger -> try turn on Remove charger -> try turn on Insert sim/battery/charger -> try turn on.
Aug 14, 2007 | Nokia 6280 Cellular Phone
Samsung Propel Pro SGH-i627 Cell Phone Logo
176 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
