Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
I have a Sony KP53hs30 that may have convergence ,,, it seems to converge in the middle, the top and the bottom are bady bowed,,, could it just be a fuse or is it the stk's ?
  • 2 more comments
  • benrules92 Apr 27, 2010
    would it be the stk-560's, or would it be a resistor
  • benrules92 Apr 28, 2010
    I just changed the stk-560's now the TV won't power on
    the red light blinks then I hear a click and it stops flashing
  • 438 Answers
No fuse related to this fault Sorry, the fault is in the convergence circuit and needs to be diagnosed, convergence is very finicky so unless you have a good background in electronic service this needs a professional to correct the problem
Posted on Apr 27, 2010
  • Fal Mueller
    Fal Mueller Apr 27, 2010
    are all the colors afected ?
  • Fal Mueller
    sorry doing some computer maintenance hear,,are all the colors affected ? the stk`s are the convergence amps and relate to an amp per color basis.
The top of the picture is bowing down, and the bottom of the picture is bowing up, and throwing the convergence out. What is causing this?
The 2 STK convergence ICS and some or all it resistors are the cause and is dead.The tv convergence board require these parts to be replaced to solved the convergence problems.The shop will cost u $300-350 for parts and labors.
Jul 13, 2010 | Sony KP-61HS30 TV
My 57hx81 has a slight concave bow in the middle top to bottom
Sounds like a problem in the vertical sweep circuit. Check voltages to your convergence ICs. If they are  not to spec then look for bad fuses and capacitors on the power board. These will throw off the DC voltage to the convergence chips causing the bow effect. I've had a single bad pico fuse ($1) cause this symptom.
Dec 06, 2009 | Toshiba 57HX81 57" Rear Projection...
I have a sony kp-41t65 tv acting like computer screen out of whac
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can get more information and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 10, 2009 | Sony KP-41T65 41" Rear Projection...
Bowed convergence
It's best to replace both ic 's at the same time,but it will fix the problem.
Jul 25, 2009 | Televison & Video
Pt-47wx49e convergence problem
I just replaced the 2 convergance chips, but it did not seem to fix the problem. I then tested all the resistors that feed the convergence chips anf there was a 2.2 ohm fusable blown. IT was R7050 on mine. That seemed to fix it so that I could adjust all the colors through the convergence 2 screen. There seems to be a slight bow near the bottom when you look at the c2 screen, but not noticable when you are watching a picture. Since I got this broken, I am not sure how perfect it should be.
If anyone can send me the service manual, I would appretiate it. Thanks.
Oct 10, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Picture is bowed down from top left corner to top right corner and bowed up from bottom left corner to botton right corner. Colors are seperated a little in corners and middle top and middle bottom.
Convergence ICs are faulty what is your model number? I can post which ICs you need and where you can get replacements that come with free instalation instructions so you can do the repair yourself
May 07, 2008 | Televison & Video
65 in sony projection tv
Defective convergence PC board. Must be checked by pro/tech
Apr 21, 2008 | Sony KP-46WT510 46" Rear Projection HDTV
Phillips 55PW9363
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 24, 2008 | Philips 55PW9363 55" Rear Projection...
Good picture in the middle but picture gets worse going to top or bottom.
The convergence IC's need to be replaced. they are the black standup IC's standing up and mounted on a metal heatsink. They are soldered into place and this set is a solid state set and have no user replaceable parts unless you have the training to solder and trouble shoot electronics. You should call a pro in to assist you with this repair.
Sep 27, 2006 | Sony KP-53V45 53" Rear Projection...
Picture Distortion
you have a convergence problem.. If you understand how this works then you can go into the set find the convergence ic's and replace them and sometimes you need to do some alighnment as well. Its always best though to let a service tech do a job like this as he will have all the proper equipment to adjust and troubleshoot the set Good luck
Mar 30, 2006 | Sony KP-53HS30 53" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
328 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
