Question about Sta Rite Sta - Rite& Poolshark In - Ground Pool Cleaner
Pool shark will not move The sta rite pool shark stays in one position and does not clean the pool
john224
  • 1378 Answers
SOURCE: we have a Sta-rite mode P2RA50-120L, when trying
If all you are doing is running your filter system to waste or backwash the fact that the pool is over full has nothing to do with it. It should run fine in either case. Your motor is likely starting to fail and as it overheats, shuts off. You may want to consider taking it to a local electric motor shop for repair or replace the motor. That motor is somewhere around $150 from most places. We sell it as well. If you would like a quote, please contact www.arrowmotor.net
Posted on Jun 18, 2009
  • 83 Answers
SOURCE: Sta-Rite S7M120
The brown-green gunk sounds like algae. You stated that you have cleaned the filter. Have you taken the cartridge completely out? If not, I would suggest that you do so. Scrub the inside of the filter tank with a 4:1 bleach water mixture, only 1 part bleach. Then soak the cartridge in an acid bath, like Muriatic Acid. This will kill any algae that is in the filter itself.
You may need to vaccuum your pool to waste, get rid of some of the water and refill it. This may help get the chemicals in order.
Another idea would be to run the system continuously for a couple of days. Vaccuum to waste, not to return lines, and clean the filter when it reaches 8 to 10 PSI above start-up. You may not be running the pump long enough to properly filter water. Keep trying to get chemicals in order.
Posted on Jul 08, 2009
  • 83 Answers
SOURCE: sta-rite gas heater won't ignite
I am not sure if either of these issues have been solved, but with the AGS light on, you will need to check the flow of water first. If it is below what is needed for the heater, this will light up. If the water flow is fine, then check the water temp on the display panel. If it is readin higher than that of the ACTUAL pool water temp, you need to replace the Thermister.
If the water temp displayed is about that of the pool water, then the Automatic Gas Shutoff will be the next thing to check and replace.
You can tell IF a Sta-Rite heater has been converted by the model number. The Convesion Kit is supposed to come with a sticker stating that the heater has been converted, but there are two options for the kit and the one without the sticker is cheaper.
If you take off the top two halves of the heater, on the Junction Box there should be a Tri-fold card there. Unfold it, if the model number ends with NA it is a Natural Gas Heater, LP would be Propane.
Posted on Jul 10, 2009
  • 83 Answers
SOURCE: Sta-rite heater error code 126
The 126 is not an error code, but it maybe the temp of the water that the heater is reading. If the heater thinks the water is 126 degrees, it will not start at all.
If the heater is reading the wrong water temp, the problem is the Thermister, which is the sensor that is suppose to read the water temp. You will need to replace this sensor in order to correct the problem with the heater. It is really easy to do!
If you have a manual for the heater, if you go to the Replacement Parts Listing for the Electrical System, page 53 in the online version, the Thermistor is Item #9. It goes into the left side of the manifold in the to place, between the first two manifold bolts.
  • 83 Answers
SOURCE: Temperature reads 125 degrees.
I am not sure if you have solved this issue, or not, but just in case. The problem is the Thermister, or temp sensor. That will need to be replaced since it is reading the water temp at 125.
The Thermister is located on the manifold, left hand side, between the first two bolts. It is pretty easy to change out and this will correct the problem.
BHR170 hose set up
in form skimmers out to filter in to out of filter to returns
Jun 01, 2014 | Sta Rite Sta - Rite 24" Sand Filter & 1 Hp...
How to clean or remove impellers in sta rite pool pump
remove band clamp then remove the part over the impeller then the reverse screw holding the impeller on then unscrew the impeller regular thread hold the back of the motor shaft take apart remove old install new and re assemble
May 16, 2014 | Sta Rite GO-KIT-6 Sta-Rite P2RA DuraGlas /...
How to clean out filter
Shut off power,
Move Filter Valve Handle to the backwash position
Turn on Filter
Let filter run until the water is clear.
Turn back off and move the handle back to the filter position.
TIP: Replace your sand every two years!
For more info, go to:
http://www.oskopoolnspa.com
Sep 16, 2012 | Sta Rite StaRite Aboveground Pool Sand...
Hi I moved into a place where the control board for the sta-rite heater was stolen, and the ID tag is blank - no model number or stats. How can I find out what I need?
I recommendyou call the Sta Rite technical support line at 888-782-7483 and they should be ableto help you figure this issue out.
Ihope this helps.
Sep 23, 2011 | Sta Rite STA-RITE CONTROL BOARD KIT -...
The pump is running but the filter is not staying full of water (I call it short cycling)
YOU HAVE A RESTRICTION ,OR A BAD JANDY VALVE. TRY MOVING THE VALVE ON THE SUCTION LINE, SEE IF IT INCREASES, ALSO TAKE ALL OF THE STUFF OUT OF THE SKIMMER, SO IT HAS UNOBSTRUCTED FLOW. GIVE THAT A TRY ..JAY
Jun 10, 2011 | Sta Rite 1 HP Sta-Rite Pump: 1.5" in/out,...
Looking for manual on Sta Rite Sand filter Model HRP830
Here is a copy of the users manual for Sta Rite BRPB30 pool filters.
http://www.pool-filters.com/pdf/Sta-Rite-HRPB-Filter-Manual.pdf
Apr 16, 2011 | Sta Rite Sta - Rite 31" Sand Filter & 1.5...
Looking for the best replacement pool filters for Sta Rite s8m150 inner and outer filters. Dont know if I should stay with Sta Rite brand or other relacement options.
I would recommend sticking to sta-rite. They are more expensive but are worth it. The system 3 cartridges are very good compared to generic replacements.
Mar 19, 2010 | Pool & Spa
Sta-rite problem
Pump is heating up and kicking the breaker try cleaning the pump filter and let me know by posting to this solution.
Sep 29, 2009 | Sta Rite Sta - Rite 1hp Dura - Glas...
Sta Rite Sta - Rite& Poolshark In - Ground Pool Cleaner Logo
119 people viewed this question
Top Sta Rite Pool & Spa Experts
Jay Finke
Jay Finke
john h
steve morris
steve morris
Are you a Sta Rite Pool and Spa Expert? Answer questions, earn points and help others
