Question about Kenmore 73952 Gas Dryer
Shuts off before clothes are dry, will restart and shut off again
  • dthorn292005 May 11, 2010
    Is it getting hot at all?
    Habit-Forming:
  • 98 Answers
Most likely, the operating thermostat has failed. When the dryer heats up, it gets too hot and the high limit thermostat turns the machine off. After it cools down, it will start again.
Unplug the machine! Check the thermostats for continuity with a multimeter. All thermostats should have continuity at room temperature.
Posted on Apr 29, 2010
Bosch Nexxt 500-series electric dryer problems - Dryer never finishes complete cycle of drying clothes. When attempting to restart, the display will show 20 (mins) even though I've pushed something di
did you clean the LINT filter? try vacuuming the lint trap area. wet or damp lint can get built up in the lint trap area. it is good to regularly clean the area as it is a Major fire hazard.
Mar 12, 2014 | Bosch Nexxt 500 Dryer
Dryer shuts off before cloths are dry,then then you have to wait about 10 mim before you can restrat dryer..cleaned vent duck to out side2 times to besure it was clean..cleaned venting back of...
Check motor for lint build up around motor. Will cause motor to overheat and shutdown on motor
overheat switch and will restart after cooling down.
Feb 11, 2011 | Dryers
Dryer gas heat not staing lit
It is probably electronic gas valve, or safety valve that let the gas flow and shuts off immediately. Better take it to the repair shop will save yourself $75.00 service fee.
Dec 30, 2009 | Maytag LSE7806A Top Load Stacked...
Heats and runs, but not long enough to dry clothes; then would not turn on and run at all. maybe dryer ''thinks'' clothes are dry?
Hi, After the dryer shuts off, can you restart it right away or does it need to cool down before restarting? If it needs to cool down for a bit, the motor is going bad. If the dryer is running a full cycle but not completely dry, check your venting to the outside and make sure it is clean.
If this is a gas dryer, the coils on top the gas valve might be shutting down early and not reopening later in the heat cycle.
I hope this gives you some direction. Please let me knwo if I can assist you further on this problem
Vic
Jun 13, 2009 | Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Washer won't spin dry clothes
What model is in reference here? Please post back with model number.
Jul 02, 2008 | Whirlpool 3.2 cu. ft. Plus Washer
Dryer will start to dry clothes then shut off
sounds like the over-temperature thermostat is the source of problem. This device prevents over heating by removing power to heating coil when normal thermostat control has failed. Perhaps your model takes it a step farther and removes all power to machine for safety. But this device is "tripping" too early unless you can find that your normal thermostat has failed. One test for this condition is to remove power to heating coil (ONLY) and retry a cycle. If your symptom disappears, then the over-temperature thermostat is faulty. If no change, there is either a faulty controller circuit or an intermittent short that is rising temperature-sensitive.
Dec 05, 2007 | Whirlpool LER5636P Electric Dryer
Kenmore 73952 Gas Dryer Logo
81 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
