Question about Whirlpool Calypso GVW9959K Top Load Washer
Machine will not spin
Machine works great but will not spin
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on Apr 28, 2010
Tip
Washing Machine, Apliance help.
Washer works great during the wash and rinse cycle,the agitator works fine for those but the drum will not spin on the spin cycle. A couple of things go on when the washer goes from wash to spin, the motor pivots, tightens the belt and the drum spins up to speed. I had the same problem on my Maytag, I replaced the belt and the pullys and it has been washing and spinning great ever since, The belts can be accessed by removing the front panel, or disconnecting the machine and laying it down, if you see a lot of fine black dust,(rubber), the belt is probably worn out, change the pullys also at this time, it is cheap insurance that everything will go well. make sure that the motor pivots smoothly, if it does not, correct this issue first and run it. That may solve your problem, A great website that i use for parts and info is www.repairclinic.com. They have parts diagrams for tons of appliances, and stock parts, I have used them many times in the past.
on Jan 04, 2010 | Washing Machines
I have a front loading clothes washer model ltf2140es3 it use to work great, we moved and now it does not spin , whats up ? it was born in 2006
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 13, 2011 | Frigidaire 24 in. FDB510LC Free-standing...
High spin does not work
Hi!!
In order to Spin Dry (FAST), the lid must be closed, If the Lid Switch is not operating, the circuit won't be closed and the machine will not Spin. Try bypassing the switch by connecting together the two wires on it. If the machine Spins FAST, replace the Switch.
Good Luck!! A HELPFUL - 4 THUMBS - rating for this solution would be greatly appreciated. Thank you for using FixYa.
Feb 11, 2011 | Kenmore Washing Machines
Zanussi jet stream iz16s tripping ouy rcd once filled up with
It would seem to me that the heating element needs replacing from the information you have supplied especially as it performs most of the other functions like filling and spin and drain.
Good luck
Mar 17, 2010 | Washing Machines
Washing machine not spinning
you didn't state what brand, but i'm thinking kenmore or wpl. broken lid switch. replace.
Jul 26, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Washing machine wont spin
Try and help it to spin in the spin mode.. if it moves.. sounds like a clutch problem ..IF NOT... you may have something like nail, screw ect... binding the spin tub from moving.. get a flash lite do some close checking inside the spin tub
Aug 28, 2007 | Whirlpool Ultimate Care II LSQ9564J Top...
Spinning Cycle
hi no' 32/33 is what you need follow the instrctions and you'll do great http://www.applianceaid.com/direct.html#runs good luck
Apr 03, 2006 | Whirlpool LSR5102LQ Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
262 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
