Question about Viking DFUD042 Built-in Dishwasher
Hello, I have a built in Viking dishwasher and lately it does not work unless I keep pushing the door closed.Then it starts and when I leave the door it stops without finishing the whole cycle. What can i do to fix this? Thanks
  • 26 Answers
It sounds like one of two things: Inside the door are simple micro switches on the latch assembly it could be that one of these is not making a good contact or is misaligned. Secondly the latch on the top of the dishwasher could be loose meaning that it is not engaging the latch mechanism inside the door itself. Hope this helps. Let me know if you get anywhere with that!
Posted on Apr 29, 2010
Kickplate on model KUDG25SH
turn off breaker to it leave one minute and turn back on also make sure door is closed tight and nothing is fouling it from proper closing .
Jul 13, 2014 | KitchenAid 24 in. KUDS01FLBL Built-in...
No power
Hello
Plug the Siemens dishwasher into a working electrical outlet if nothing on the dishwasher is operating. Check the household circuit breaker or fuse and reset or replace as needed.
Push the door closed fully if the dishwasher has power but isn't starting. The unit will not operate if the door is open.
Sep 11, 2011 | Siemens 24 in. SL34A006UC Built-in...
Hi, we have a Frigidaire FBD1050REM diswasher that the soap door intermittantly won't open, leaving soap all over. Any ideals? Thanks, Christine
I have the same dishwasher and the same problem. What works for me 95% of the time is to push the soap door latch once before I load the soap and close the door. There seams to be two positions on this latch and one opens better. Also, make sure your top rack is pushed all the way to the back before closing the main door.
Personallly, I am looking for a replacement dishwasher!
Dec 22, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
My door doesn't close, on my viking dishwasher
Most likely you need to repair or replace the door switch.
Dec 05, 2010 | Viking DFUD042D Built-in Dishwasher
We have the Whirlpool Gold quiet partner III dishwasher and lately have noticed residue on the dishes after the cleaning cycle is complete. Where is the trap to clean?
Make sure your water is hot, at least 120deg f. Also, use least amount of soap you can get away with. Usually around 2 tablespoons for soft water. Use powdered soap not gel. Gel leaves a tiny residue each load and will clog up plumbing in dw after 4,5,or 6 years. Rinse agent such as Jet Dry is highly recommended.
Try the "Tang" trick. Orange Tang drink mix is mildly acidic. With an empty dishwasher, start and fill, then normal drain. On second fill, add a full jar of Tang then let the dishwasher run for a few minutes. Crack the door to stop the dishwasher and let it sit for several hours or overnight. Then close the door, push start and let the dw run through the remaining cycle. This will sometimes clean out the crud in the water lines.
Hope this helps! Ken
Jan 06, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
Viking Designer Series DFUD041 Built-in Dishwasher
Did you try the power on button all the way to the left?
Jan 27, 2009 | Viking Designer Series DFUD041 (Premium)...
Cancel light and rinse only light keep blinking and wont start
Hopefully you have resolved your issue. I have not heard of the cancel light flashing issue. I have had problems with the clean light flashing seven times over and over and the control panel will not operate. Here is the solution to that. Maybe it will work for your issue as well.
Open dishwasher door,
Push Hi Temp Scrub button,
Push Saver Dry button,
Push Hi Temp Scrub button again,
Push Saver Dry button again,
All lights on control panel will come on.
Close dishwasher door,
Push Baked on Cookware or Normal Button.
Dishwasher should start and complete cycle.
It is good if you have kids that play video games. Their fingers are used to pushing buttons quickly. I guess this resets the control board. The service guy let me have this info as I used to deliver appliances and work on them somewhat.Hope this helps.
Good Luck,
Tom
Nov 26, 2008 | KitchenAid 24 in. KUDS01FLSS Built-In...
Viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Jul 16, 2008 | Viking 24 in. Professional Series VUD040...
Viking DFUD042 Built-in Dishwasher Logo
260 people viewed this question
Top Viking Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Lloyd Carter
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
