Question about Sage Instant Accounts 8.0 (013604ug)
Sage Instant Error Message SGREP32
Hi, when I try to run a report, say Profit and Loss, in Sage Instant I am getting this message headed ''SGREP32''. The details is:
c:Program FilesSageInstant AccountsReportsFinance\*PNL.SRT contains an invalid path.
Any clues?
Many thanks
  • deegeraghty Jan 17, 2011
    Hi, I'm finally getting back to this problem. I looked in this directory"C:\Program Files\Sage\Instant Accounts\Reports\Finance" and in here are Report Designer Files. This seems to be the same for all the sub-directories ie Suppliers and these reports are working fine. It just seems to be the reports under Financials (except for calculating VAT). At the time when I moved computers, I would have installed the disc, taken a backup on the original and restored this. I am using Windows XP. Thx
  • 977 Answers
It looks like the program is looking for the data - but it's not where it defined to search. Pay attention that if you've COPIED the program's files from another computer - it won't work correctly! You should INSTALL it normally on the target computer, then restore only the DATA files from the source directory to "C:\Program Files\Sage\Instant Accounts\Reports \Finance" on the target computer.
Look here for a similar solution...
Good luck,
Pelu.
Posted on Apr 27, 2010
  • Ran Kedar
    Ran Kedar Apr 27, 2010
    You should basically make sure than the data files are in the Reports directory.
    I had a redundant space in my previous post... The correct target directory should be:
    "C:\Program Files\Sage\Instant Accounts\Reports\Finance".
    Source directory (if copied) may vary, depend on the operating system installed on the computer.
    Look for the Reports directory...
    In ANY WAY, make sure the data files (including Finance directory) will eventually be in the Reports directory.
I was working in sage instant accounts version 8.2 when my computer crashed. Im trying to go back into sage but it comes up with the message 'you may only run one copy of this programme at any...
If you are unable to logon to Sage you can try deleting the Queue.dta file. All users MUST be logged out of Sage and Sage should not be running. Sage will recreate the queue.dta file when it is restarted. The Queue.dta file can be found in the ACCDATA folder for the Sage Company Data that is experiencing the problem.
Note that the "Username already in use" message from Sage can occur if Sage wasn't shut down tidily for that users session. If you are sure that the user is not actually logged in it's OK to allow Sage to clear the session and log in.
May 19, 2011 | Sage Instant Accounts 8.0 (013604ug)
Hi. I am having problems installing Sage Instant Accounts.Just before the the installation process is completed, a pop up window appears with the following message: Component Error Returned the...
It sounds like the SBD installer isn't working you need to ensure you have full administrator rights and you can run setupsbd.exe from the program directory
Nov 04, 2010 | Sage Instant Accounts 8.0 (013604ug)
Hi all I am gettig the following with my sage line 50 v7 'sage report says unable to connect to data sourc, check configuration' I then get a system error coded 2 Its on windows 98 Can anyone...
Try removing Microsoft.net framework 3.5 sp1 from add remove programmes has known conflict with sage. If this does not work then try removing the .net framwork 3.0
Oct 05, 2010 | Sage Instant Financial Suite v8.0 CD Win...
Instant Accounts 8.0 (013604ug): I am using Sage Instant Accounts version 8 and am ...
Hi.
We had same problem. Our solution:
1. Empty both the 'accdata' and the 'criteria' folders.
2. Start Sage.
3. Restore a previous backup.
This worked for us. Hope it helps you.
May 17, 2010 | Sage Instant Accounts 8.0 (013604ug)
When I try to print reports in the Financial window on Sage Line 50 I get an error message C Prog Files x86|AccRep\*TB.SRT contain invalid path. how do I fix?
find the TB.srt file and copy it into location should solve this. You may also have a problem with profit and loss and balance sheet as these are normally held in same location
Feb 09, 2010 | Sage Instant Accounts 8.0 (013604ug)
Sage Instant Accounts error Message Coming up during installation, Internal error 2753 eirregistration.dll
Was getting the same error for version 12. On the cd there is a support folder. In that there is an installs folder. I installed jet, mdac and the xml parser (probably not necessary) and the next install worked OK.
Feb 01, 2010 | Sage Instant Accounts 8.0 (013604ug)
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Invalid Path error
I get this error when trying to run Financial reports in Sage line 50 financial controller verson 10: C:\PROGRAM FILES\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid path No matter what financial report I try to access I get the same error including audit trail. My computer is window Vista. Please help me and also let me know how much is it cost for on line chat?
Thank you
from selvi
Apr 14, 2009 | Sage Instant Accounts 8.0 (013604ug)
Error message with sage instant accounts
Jan 13, 2009 | Sage Instant Accounts 8.0 (013604ug)
Sage line 50 nominal reports.
reinstall ODBC Drivers usually found in your sage data directory
Jan 16, 2008 | Sage Instant Financial Suite v8.0 CD Win...
Computers & Internet Logo
1,296 people viewed this question
Top Sage Computers & Internet Experts
Mohammed Ebrahim M
Mohammed Ebrahim M
Clinton Daley
Clinton Daley
Are you a Sage Computer and Internet Expert? Answer questions, earn points and help others
