Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Rca D52W20 changing picture size
While watching HD content - right in the middle of a move - the picture will change size. It may go from wide screen to SD size and a few minutes later change to a zoom view. Seems to happen reandomly.
  • cmiles31 Apr 09, 2008
    The picture format changes...goes to the zoomed in format.
    Any ideas?
    Thanks!
  • Anonymous Apr 16, 2008
    I have tried to reset picture size using the format/zoom functions on the RCA remote but the picture remains too large to fit on screen.
    Genius:
  • 1,030 Answers
CHANGE autoformat in customer setup menu
Posted on Mar 24, 2008
SOURCE:
Make the picture fill the screen
The TV will produce a picture that is set by the aspect ratio of the film. You can however expand to an unatural size to fill the whole screen.
Oct 03, 2014 | Samsung Televison & Video
Xbox 360 picture too large
Have you tried just clicking on your left or right arrow to change the screen size without using the menu button?
Jul 01, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca Model R56WH70 Tv. Problem: Unit switches between wide screen & regular size picture on it's own. When watching this tv, picture just changes size on it's own.
you have the auto format on! the tv is working correctly, go into the user adjustments and turn off auto pic size
Oct 08, 2008 | Televison & Video
Picture size off with 1080i
Thats as good as youre going to get bc its a projection set. Use the non hd input.
Sep 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have a T5054 TV and the picture has zoomed in and is way too big, however in the picture settings menu the zoom option is not highlighted in Component mode.
There could be a problem, but verify the settings as listed in the owner's manual as follows:
1 Press the MENU button to display the menu.
Press the ▲ or ▼ button to select Picture, then press the ENTER button.
2 Press the ▲ or ▼ button to select Size, then press the ENTER button.
3 Press the ▲ or ▼ button to select the screen format you want.
Press the ENTER button.
Press the EXIT button to exit.
16:9 : Sets the picture to 16:9 wide mode.
Zoom1 : Magnifies the size of the picture on the screen.
Zoom2 : Expands the Zoom1 format picture.
Wide Fit : Enlarges the aspect ratio of the picture to fit the entire screen.
4:3 : Sets the picture to 4:3 normal mode.
Just Scan : Use this function to see the full image without any cutoff when DTV
or HDMI 720p/1080i signals are input.
Press the P.SIZE button on the remote control to change the picture size.
And realize the restrictions as listed:
• In TV, VIDEO, S-VIDEO, and COMPONENT(480i, 480p) modes, all screen
modes can be selected. (16:9 ➞ Zoom1 ➞ Zoom2 ➞ 4:3)
• In COMPONENT(720p, 1080i) or HDMI(720p, 1080i) mode, 16:9, 4:3 and
Wide Fit can be selected.
• In Zoom1, Zoom2 and Wide Fit modes, you can move the picture on the
screen by pressing the ▲ or ▼ button.
•You can not change the picture size when PIP is set to Double.
•When Double ( , ) mode has been set in PIP, the Picture Size cannot
be set.
•Wide Fit can be used when watching a Digital HD (High Definition) signal.
Wide Fit sets the optimum picture format by expanding it both horizontally and
vertically. For example, you can reset the picture in 4:3 format to 16:9. Wide Fit
does not support all external devices (DVD, VCR etc.).
Keep us posted.
Dan
May 29, 2008 | Samsung Televison & Video
Picture Issues
When your watching non HD channels you have to stretch your screen.Your TV has that input option to do so.
May 08, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hd picture too wide
If you are using a cable box you need to look on your cable remote for HD ZOOM or you can try the # sign on the remote. This should change your screen size and get you taken care of.
Feb 09, 2008 | Toshiba 57H84 57" Rear Projection...
The picture has shrunk - maybe 720P vs 480P?
make sure your hd cable connection from your cable box is going to an hd connection to your tv.[via hdmi, dvi,or componant.] if you have a different hook up such as rca out or coax out, these are not hd connections and you are probably streching out the picture.look at the rear of the tv & cable box and see how the connections are.the hd hook up to the hd input should make the picture the right size only if it's set on the hd input channel.hook up the dvd player to a aux/line in or video/source input and try changing the picture size. you may have to play around with it till you get it the way you want.
hope this helps.
wg
Feb 06, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
RCA 52" tv
ON THE REMOTE. ARROW RIGHT OR LEFT
Feb 03, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
289 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
