Question about Jenn-Air Ovens
I tried to use the self cleaning feature last night. After 30minutes of it working fine a chime began to go off and the control panel showed F4. I couldn't get the chime to stop so I pushed cancel. Now I am wanting to know what to do so I can use the self cleaning feature.
  • khughes56 Apr 28, 2010
    Hi Lee,
    thanks for getting back to me. I have a Jenn-Air Grill-Range with Self-Cleaning Conventional and convection oven. Model is SVE47600. I just put it back on cleaning and it appears to be preparing to clean. It shows "clean" and below that "lock". Earlier today I put it on convectional bake to heat up some quiche and a few times, maybe three it beeped again and this time showed F5. I hit the timer and it would stop. I imagine these things are related. Please if you have the solution I will be so grateful.
    Thanks, Kim
  • 4,472 Answers
First of what is the model of the unit? What happens when you go back into self cleaning mode? How long have you owned the unit? Once I have more information I can assist you further.
Thank you,
Lee
Posted on Apr 27, 2010
Ge oven control panel problem
Sounds like a control board issue. Check to see if that particular gives any error codes if you can. FYI a new board is probably about 200 bucks.
Dec 03, 2013 | Ovens
RBS305 replaced thermal cutoff twice and again it won't come on bake or broil
Good Evening!
The self clean feature is causing your thermal fuses to fail or open. This is a safety mechanism that when open (bad) won't allow electricity to pass through any longer. The temperature in your oven exceeds what the components in your appliance can handle. If you want your oven to last it's longest, I would discontinue using that feature. If ever the control board or keypad on your oven by way of the self clean feature, we can help you with that. Fixyourboard.com can help. Send all inquiries to info@fixyourboard.com . Thank you!
Jun 05, 2017 | Whirlpool RBS305PD Electric Single Oven
Are you working christmas night? we had a small
Clean that oven by hand before you cause more problems...
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Dec 26, 2010 | Frigidaire Ovens
The oven works fine as in it heats up but when turned off the cooling fan keeps going...used it last night and this morning the fan is still on...turned oven on and it is heating up but as I said the fan...
most ovens use a cut in limpet themostat(sometimes called button stat) typically normally open and closed at 40deg c. it will be this that will be not resetting to the open position at room temp. on rarer models the timer controls the cooling fan. some models of aeg and electrolux have a thermal delaying device located in abulb in the wiring loom. hope this helps
Aug 02, 2010 | Ovens
I have a Whirlpool electric build in oven with self-cleaning feature. It is about 8 years old and we just used the self-cleaning feature for the first time last week. The oven was not that dirty, but...
Your thermal fuse or TOD mounted to the back of the oven went out during the self clean,it shuts off the power to the elements.
 The oven must be removed from the wall to change this.
Aug 31, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Self clean results in f9 and beeping
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
utut
Apr 07, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven comes on then beeps and a code F4 comes on
how do I solve a F4 problem in the Decor electric stove?
Feb 02, 2009 | Ovens
Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Nov 05, 2008 | Whirlpool RBD305PD Electric Double Oven
F4
The F4 error code generally means a bad temperature sensor or a short in leads to the sensor. Under room temperature conditions the resistance should be approximately 1100 ohms. If you are not comfortable around electrical apparatus and/or don't have an ohmmeter, you will need to contact an appliance repair technician. GE typically places a trouble shooting guide in the top of their ovens behind the touchpanel. You will have to remove three screws in the bottom of the touchpanel to open the panel. Be sure and turn off the power before opening the touchpanel!!!
Aug 23, 2007 | GE JTP85 Electric Double Oven
Ovens Logo
16 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
Craig Butler
Craig Butler
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
