Question about Samsung SPN4235 42 in. Plasma HDTV
My Samsung is delaying turning on
My Samsung has a touch turn on system and it now is delayed. Lots of clicking and then eventually it turns on
  • 50 Answers
Reason for your problem is that there is not proper power being supplied to the tv. Solution- on the power supply there is 2 capacitors 1 of which is exploded already. You would need to replace those with new ones. spotting and exploded cap, good caps are flat on the top and bad caps swell out.
current cap- 10v 2200mf
replace with -16v 2200mf or 25v 2200mf
repair will include soldering.
Posted on Apr 27, 2010
My laptop Touch is insensitive it delay to click on or may delay to recognition
This may be due to software , Or you might have over loaded or system is having virus in startup.
Also check it during power connected mode.
Check the hard drive activity if it is continuously running this may require to empty some HDD space.
Feb 05, 2013 | Samsung RV511A01 Notebook
I CAN'T GET THE FILTER PUMP LIGHT TO GO OFF - BEEN USING IT FOR A GOOD PART OF THE DAY - LOTS OF LEAVES AND BLOSSOMS IN POOL.
There is a 5 min. delay on this sytem once you turn on the heater or pool sweep. During this delay you cannot turn off filter pump. Hope this helps.
Mar 18, 2011 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
Jan 01, 2011 | Samsung Microwave Ovens
Need to make entry time longer . I am able to delete option 10 but can't add option 10. Entry is only 5 sec.
Here is instructions from Installation Manual. I am also attaching links to full Installation as well as User Manuals for your reference at the bottom of page. Make certain to input as 3 digit time - example 45 seconds as 045. Good luck!
Option 10: Entry Delay (Default = 030 sec.)
Determines how much time the user has to disarm the system
after entering the armed premises through a designated delay
door, before an alarm occurs. Beeps sound during the entire
delay time to remind the user to disarm the system.
When turned on, the Entry Delay can be set from 005-254
seconds (030-254 if SIA Limits Option 69 is on). All entries
must be 3 digits. When turned off, the Entry Delay is set to
005 seconds.
Note
For UL listed systems, the entry delay must not exceed 45 seconds.
 To set Entry Delay, press:
1. Add
2. Option #
3. 10
4. Use the numbered keys to enter the 3-digit delay
time.
5. DONE
 To turn off Entry Delay, press:
1. Delete
2. Option #
3. 10
4. DONE
Installation - http://www.homesecuritystore.com/downloadmanual.aspx?mnl_id=334&prod_id=171
Users: http://www.safemart.com/manuals/simon3.pdf
Oct 02, 2010 | GE Security Simon 3 Wireless Home Security...
Too short of a keypad lock delay while making voicemail calls.
I have the same problem with my LG VU on Rogers in Toronto. I don't think there is a solution to this, as simply turning off the keylock feature only works when the phone is idle. You could try an excellent site for the VU, but you will probably need to mess around with the phone's software using Bitpim, which voids the manufacurers warranty.
http://www.lg-vu.com/
Check it out anyway, because it is full of lots of ideas and advice.
Jul 24, 2009 | LG Vu CU920 Cellular Phone
Blue screen
Check the CRT.and then check if there is a loose solder on the whole board and also check the H-out..change the CRT socket which is Color White Connected to the Tube.
Nov 12, 2008 | Samsung TX-R2735 27" TV
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Audio: hearing everything twice
you have a delay time on your home theater JVC, that is normal. So it's either you reduce the delay time of your JVC or do not use the TV sound. Set the delay time of your DSP so you can heqar the sound you wish... like the delay time of your surrond.
Mar 30, 2008 | Audio Players & Recorders
Samsung SPN4235 42 in. Plasma HDTV Logo
140 people viewed this question
Jerry Greenberg
Jerry Greenberg
