Question about Brother IntelliFAX 2800 Laser Fax
Fax copy is streaky, almost banded looking. Copies the same too, streaky looking. Toner seems to be full, drum was replaced about 10 months ago with an after market one.
    Problem Solver:
  • 6 Answers
If they are black streaks and they are always in the exact same place, open the cover and clean the skinny little scanning glass. It might be ink or lint. If it's white streaks then it's in the same place but it's dried correction tape or fluid, etc.
Posted on Apr 28, 2010
I have one canon ir 2020 i copier machine how to all copies recovery at a time please infor me
To recover prints at time of failure is not possible, the device will need powering down to resolve issues such as error codes. E007 will need film replacement or clear code. E019 is waste toner need emptying, E010 is main drive motor maybe related to drum seizing from waste toner being full etc. image quality may be either film or drum. The drum Would look more streaky looking ==== could be bold and dark but will have straight lines within. and the film would be more blotchy/patchy/speckle y :;'";:;':':;;;':;';,. Please give more information if answers still not helping and whats been resolved so far
Aug 01, 2013 | Canon Office Equipment & Supplies
When we recieve faxes they have black lines running down the entire length of the page. I have already changed cartridges and am wondering if there is something that needs cleaned? What can I do?
You have to determine if your FAX is the problem or the sending FAX has the problem. The first thing to do is make a copy or print a report. If it comes out clean you FAX is NOT the one with the problem. The sender has to get their optics cleaned.
On the other hand, if it's still "streaky" then your fax has a problem. First off remove the cartridge and look inside it, if you see toner get a can of compressed air (sold in office supply stores to clean keyboards) and blow out as much as you can. I suggest taking the machine outside the toner dust can make quit a mess. Make a few copies (5 - 10) to check it out. Each copy should come out with less misplaced toner.
Dec 07, 2010 | Brother IntelliFax-2820 Laser Fax
Okidata C5200N printer: streaky copies on magenta
If the streaks are only from the magenta then your magenta drum is bad. If you recently replaced it, it may still be under warranty.
Jan 19, 2010 | OKI C5200n Laser Printer
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
Copies are coming out streaky
Defective toner. And a cartridge is only good for about 2000 pages - not 10,000.
Mar 02, 2009 | Samsung ML 2010 Laser Printer
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Light copies
You may have your machine set to print in "toner save" mode. Check your machine settings by printing a list. Also, some generic toner cartridges have too much polymer in the mix and will print light copies. If you change back to OEM toner, you may have to change the drum too, as the extra polymer stays in the drum unit and weakens the mix.
Jun 04, 2008 | Brother IntelliFAX 2800 Laser Fax
Copies and outgoing fax quality
your machine most likely has toner spills in it.
if you send faxes face side down follow these instructions ;
1- take out toner
2- look for thin glass strip on bottom inside the machine
3-wipe clean
if you make copies side up then do the same except look for glass strip on the upper side of machine
Nov 27, 2007 | Brother IntelliFAX 4100 Laser Fax
Lanier Copy Machine 3635
Is this a small table top model? They usually do not have a waste bottle. The waste toner accumulates is the drum housing Where hopefully the change drum warning will come on before the waste toner fills up and causes poor copies. I have taken the drum asm apart and vacuumed the toner out.
Aug 03, 2007 | Copystar (023-JF503) Fax
Brother IntelliFAX 2800 Laser Fax Logo
287 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
