I have active directory domain 2003 entirprise ed but suddnly can't add any object to AD I get "sid POOL EXHUST" MESSAGE when i try add any object
You have to seize the RID master for you domain, appears to be removed from network or can't be contacted, you can use the next commands in order to get the actual (MYSERVER should be replaced by the name of you server
C:\WINDOWS>ntdsutil
roles
connections
connect to server MYSERVER
q
Select operation target
then you get the next response:
Server "MYSERVER" knows about 5 roles
Schema - CN=NTDS Settings,CN=MYSERVER,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=MYDOMAIN,DC=net
Domain - CN=NTDS Settings,CN=MYSERVER,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=MYDOMAIN,DC=net
PDC - CN=NTDS Settings,CN=MYSERVER,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=MYDOMAIN,DC=net
RID - CN=NTDS Settings,CN=MYSERVER,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=MYDOMAIN,DC=net
Infrastructure - CN=NTDS Settings,CN=MYSERVER,CN=Servers,CN=Default-First-Site-Name,CN=Sites,CN=Configuration,DC=MYDOMAIN,DC=net
select operation target:
the interested server is RID - this must be the name of a actual server, if this server is permanently down the you need seize the rol, use the next guide:
http://technet.microsoft.com/en-us/library/cc784077%28WS.10%29.aspx
if the server is an actual server you must review the event log in this server in order to get more clues of the error.
