How do I change internet browser on sciphone from chinese to english
  • 7 more comments
  • scorp11867 Apr 27, 2010
    how am I able to change internet language on sciphone from chinese to english although on some sites I'm able to select english language others such as myspace and facebook does'nt have selections to change to english
    I have google yahoo and msn in englishbrowser forms but when I go to opera it shows up in chinese the browsers are in english but when I go to download it has a selection of languages except for english
  • scorp11867 Apr 28, 2010
    when I go to the link to download to my pc it says it's not able to download files to my pc
    when I open the file to download it says failed to load main classmanifest attribute from temp internet
    what I'm attempting to do is download the version of opera you told me about to my pc first once I hit the run button it fails to go any further I'm not sure exactly how to download the version to my sciphone I have not a clue because it will not even download to my pc first I'm totally lost here sorry
    I changed the http to wap and also put auth type secure and I'm still having connection problems though I successfully downloaded opera mobile to my phone
    I believe the problem is where you say check the ip address and making sure the security it's on I'm having problems with how do I check security on the ip
    I connect using att
  • scorp11867 Apr 29, 2010
    very patient and even more helpful. Ans my questions very detailed and my problems are solved. I'm very satisfied and thankful.
  • 493 Answers
Please click here, find the file named "opera-mini-3.1.13045-basic-en.jar'' and download it.
Connect the sciphone to the USB port of your computer and copy the downloaded file to the JAVA folder.
Unplug the cable and in the phone menu go to "Documents", then "Memory Card" and go to the JAVA folder. In the JAVA folder you will see the .jar file you just copied. Install it.
Then select the memory card for the installation place.
If you have network error:
To fix it try changing from HTTP to WAP. To do that:
Service - WAP - Settings - Edit Profile - SIM1 - OK - Edit Profile
and in the "Connection Type" change from HTTP to WAP
Check the IP address and make sure "Security" its ON
Besides you need to go to Service - Data account - GPRS - Edit
and change "Auth. type" to "Secure"
Hope this helps.
Posted on Apr 27, 2010
  • 6 more comments
  • Ibrahim OKTAY
    Ibrahim OKTAY Apr 28, 2010
    Hi again,
    You have two comments. First you say that you can not download it to your PC. Later you have written about a opening error. Did you manage to download the .jar file from the website to your PC?
    As I understand from your second comment you managed it.
    If the answer is yes, did you manage to copy that .jar file to the JAVA folder in sciphone using the usb connection?
    Did the error occur when you tried to open it on your sciphone or computer?
    Would you please inform me this?
  • Ibrahim OKTAY
    If you are trying to run it clicking on the .jar file, please do not try to open or run the file in the computer.
    When you download it to your PC, please directly copy it on to your sciphone as I described in my first message.
    I am waiting your comment to help you.
    Thanks.
  • Ibrahim OKTAY
    OK my friend,
    1- After you downloaded the file to your PC you will save it, do not run it on the PC. You will see the file named "opera-mini-3.1.13045-basic-en.jar'' where you saved it. (on the PC)
    2- Connect your sciphone to PC. ( I think you know how to connect using USB connection.)
    3- Find the Documents\Memory Card\Java folder on your sciphone using PC file manager.
    4- Simply copy the previously saved "opera-mini-3.1.13045-basic-en.jar'' file from PC to that Documents\Memory Card\Java folder on your sciphone.
    5- Then now go to the Documents\Memory Card\Java folder on your sciphone. Run the copied "opera-mini-3.1.13045-basic-en.jar'' file by double clicking on it. (on the sciphone)
    6. After you run it, installation will begin, select the scifone memory card for the installation place.
    7- If you have network error:
    Waiting for your comments.
    Thanks.
  • Ibrahim OKTAY
    To clarify that:
    Downloading the file from the Web means you save it to PC.
    Installing the file on the sciphone means you run it on the sciphone.
  • Ibrahim OKTAY
    In my previous comment and explanation I want to add a little change to the 5th sentence to make it clear:
    5- After copy process, unplug the phone from the PC. Then now go to the Documents\Memory Card\Java folder on your sciphone. Run the copied"opera-mini-3.1.13045-basic-en.jar'' file by double clicking on it. (on the sciphone) (Normally you can't double click on the phone, I mean run that file on the phone using phone menu as you did before.)
    Good luck my friend.
  • Ibrahim OKTAY
    Do you connect to the internet by using AT&T service, TMobile or what? If you could inform me that i can also help you make the connection setup. But first i have to know which service you use for connecting.
  • Ibrahim OKTAY
    Please watch the Video which I send you the link HERE. Follow the instructions shown in the video. Then I hope you will be able to solve all your problems.
    Good luck.
    I hope this helps.
  • Ibrahim OKTAY
    Ibrahim OKTAY Apr 29, 2010
    Hello my friend,
    I hope your problem is solved.
    The question seems to be open. If you accepted my solution, would you please check the answer as accepted to be able to close this case.
    If you have any comments I am ready to answer.
    Good luck.
    Top Expert:
  • Computers & ... Master
  • 77,202 Answers
You need to install an english browserhow do I change internet - 2_bing.gif!
Google for "opera mobile" and download it.
  • 2 more comments
  • yadayada
    yadayada Apr 27, 2010
    i gave u the answer
  • yadayada
    did u download the english language browser?
  • yadayada
    here is the web link for the JAVA down load for the english language browser u need, it is free.
    http://www.opera.com/mobile/
  • yadayada
    yadayada Apr 28, 2010
    sorry don't know what is wrong with your PC, the fiel downloads fine on mine.
Sciphone i9 java script and internet browser is in chinese?
You need to install an english browser!
Oct 01, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Sciphone i68+ (clone)internet is all in Chinese!
Just ask here, they are specialized in finding english manuals for chinese import items. They helped me a lot with my SciPhone mobile. They even have UK settings for it.
Jun 15, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
I have a Sciphone I need help translating from chinese to english
Settings (2nd row, 3rd icon), Phone setup (4th choice down), Language (3rd choice down), English (first choice)
Jun 11, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Change default encoding for a sciphone
Try to type in the following code: *#0044# - this changes the SciPhone to english language.
Find an Sciphone i68 user manual at http://chinamanuals.com inc. network settings for major providers.
Jun 03, 2009 | Dual Electronics CECT P168 Cellular Phone
Want to remove chinese apps from phone
To change to all english mode type in the following code:
*#0044#
Find here an english user manual for SciPhone i68
May 23, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
Taiwan Version - cannot change language settings to English
May 07, 2009 | Garmin Forerunner 405 Handheld GPS...
How can I put my i9+++ sciphone in english?
This is a common issue which you should be able to correct by using one or more of the following methods;
1.) Change the E-Book reader option from the Main menu => Tools => E-Book reader => Options => Global settings => Encoding, change to "UCS2 (Unicode)"
2.) Globally set the phone to English by opening up the dialing pad and entering *#0044# and then press the call button.
For full help topics I have a cd available for 10 us dollars. Has 100's of mp3 ring tones wallpapers, and java games and opera java browser. Guaranteed help on every question ever asked on these phones. And all settings for all cellular services. I have answered 100 questions with this CD. If interested contact prestorose@aol.com Pay Pal only, will send out First CLASS Mail in padded envelope. If interested I will send Pay-Pal invoice that can be filled out and returned with instructions. Guaranteed safe transaction.
May 02, 2009 | Dual Electronics CECT P168 Cellular Phone
Reading or write Chinese with my phone
Dec 11, 2008 | Nokia N95 Cellular Phone
Computers & Internet Logo
123 people viewed this question
David Payne
David Payne
