Question about Whirlpool Duet GHW9150P Front Load Washer
A piece of the rubber has come off the inside of washer and water now leaks out,
  • 5,911 Answers
Piece of rubber WHERE? If you are referring to the rubber bellow (door seal), they will wear out with age and may become mishapened from repeated pressure from the door being closed. Over time the bellow can stretch or develop rips and tears and begin to leak. If the bellow is leaking, or no longer providing a good seal, it must be replaced. This will cause water to puddle under the front of the washer and inside the cabinet. The following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and have great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If the model number is correct, the part number is 8182119.
If you are not referrig to the door bellow, or if you have questions about this repair, please post back and let me know. hope this helps you.
NOTE: If you leave the door OPEN between washes this will help prevent constant pressure on the door seal which can stretch it out of shape over time. It is also beneficial to allow the wash tub to air out to prevent mold and mildew from forming. In addition, overloading the washer can contribute to premature wear and tear on the bellow which can lead to rips, tears and possible dislodging from the bellow clamp seals. Always follow the manufacturer's recommendations for loading in your owner's manual.
Posted on Apr 27, 2010
Machine leaks water
The most common place for a front load washer to leak is in the bellow. This is the rubber piece right inside the door. Pull the rubber piece back and check for tears or holes. If there are not any holes then there is probably a hole in the hose that runs from the tub to the pump. Sometimes stupid things like bra underwire and bobbi pins get in here and tear them
Aug 25, 2012 | Maytag MHWZ400T Front Load Washer
Kenmore HE 2t washer is leaking from the front
thats called a bellow. from a scale of 1-10 id say a 9. front assy of washer needs to come apart to be able to get to gasket rear. that is why it leaking just a small tear or bend on the gasket bye the door will cause it to leak. ive done about 50 of those and it takes me about 1 hr. good luck .if u need furthur assistance let us know. thank you.
Oct 07, 2009 | Kenmore Washing Machines
Piece of rubber came out torn. water leaks out
door seal must have hole in it replace hole at bottomof seal
Jul 06, 2009 | Washing Machines
RUBBER RING INSIDE THE WASHER
if the washer is still leaking, take the outlet pipe and place it in a dish on the floor , the water is greater and should come out of the pipe, keep watching until empty . remember there can be a lot of water in a washing machine
May 12, 2009 | Frigidaire ATF6000ES Front Load Washer
Water hose leaks at the washer connection
Did you change the rubber washers in the hose? or did you use the old ones there should be a rubber washer inside the front of the hose.
Jan 05, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Leaking front loader
If your washer has a rubber seal around the inside of the door and it has a little opening where the detergent comes into the washer put your hand inside the rubber piece and feel all the way around and see if you feel any holes or cracks in it and that is where it will leak from.
Dec 03, 2008 | Kenmore Elite 45986 Front Load Washer
Washer not draining all the way
http://www.instructables.com/id/GE-Adora-Lint-Filter-Cleanout/?download=pdf
Had the same problem, this fixed it!
Oct 30, 2008 | GE WSXH208A Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Water leaking from front door
not really due to therebeing 3 holes at the bottom of the door seal which lets water out that is stuck in the seal
Sep 12, 2007 | Miele W969 Washer
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
