Question about Microsoft Xbox 360 Console
Xbox 360 my xbox 360 will not load any games its fairly new 8 months old but it says put the disc in an xbox 360 or open tray, but then another time it will play no problem it is pot luck and my young son is getting a bit fed up.
  • 99 Answers
Send the unit back to Microsoft for warranty repair.
Call 1-800- 4MY XBOX to set it up.
Posted on Mar 24, 2008
My xbox 360, has a problem i put in a new clean disk(game) into the xbox . it is a xbox 360 game and every time i put in a new clean disk the xbox says (open tray)
The XBox 360 is a wonderful video game console, however, with heavy usage, the laser (and/or other components in the drive) will eventually burn out.
The first signs of the laser starting to burn out is that your game will start freezing during game play. Eventually the games will stop reading altogether and you will get an "OPEN TRAY" message when you put a disc in and close the tray. What this means is that the XBox 360 thinks that there is no disc in the system.
If you click into the following U.S. based website, you can find more information about this issue, the parts to fix it yourself and you can also send your XBox 360 to them to have it repaired:
http://store.richspsxparts.com/howtofixxb36.html
Jun 21, 2011 | Microsoft Xbox 360 Console
Won't read the disc.
You can check the Open Tray error troubleshooting tip i have put on FixYa, check the link here
Happy Gaming, please do take time to rate my solution
Regards
KreativeGeek
http://gamingbox.wordpress.com
Jun 08, 2010 | Microsoft Xbox 360 Console
The xbox 360 elites keeps on saying open tray when trying to play
1, the disc may be dirty
2. the mian reason for this your xbox drive cannot read the disc , because the power of the lens is gone(not completely) ,
solution:
1. keep your disc inside the drive and switch off the console, again swith on try this 2 to 3 time
2. keep the console in vertical position or little slanding position(180 dg) make sure it does not fall
3. its better to buy hatddisc and load the game inside it , so that u lens life increased
4. change the entire drive
Feb 09, 2010 | Microsoft Xbox 360 Console
I put the disc in and on my tv it says open tray and when I do that and close it it says reading then goes back to open tray.
Hi friend try this:
1) Restart your console.
2) Check for loose cables.
3) Pull out all the cables, and get them back in.
4) Take out the hard-drive, and put it back in. Repeat this 4 times.
if the problem still persists then you need to replace your disc drive.
Please vote for me.
Brand new 360 elite will not play nba live 09 ONLY
ok , if it is giving u the open tay error , every time u try and load it , it could be a number of reasons behind it , i had the same problom , most games will play but i had 1 game that no matter how many new copys of the game i got , when i put it in my xbox the game spun 3 times and then said , open tray , like trhere was no game in the xbox, so i went 2 you tube and typed in open tray error xbox 360 and there r loads of examples on how 2 fix it , if u keep opening and closing the tray each time after it says open tray after about 6 to 7 times , it should play , but i would go 2 you tube , becase u need 2 open your disc drive 2 fix the problom.
Jan 13, 2010 | Microsoft Xbox Console
My Xbox 360 Halo 3 edition hardly reads any disc successfully!
This most likley a weak laser .
8 mw 633 nm laser diodes fail in stages
as they get weaker the cd ups voltage
to the laser diode till you get to full gain, affter that
it's time for a new laser .Good news
there cheap 30.00-40.00 and not too
hard to swap out yourself .
Rob
Jun 13, 2009 | Microsoft Xbox 360 Halo 3 Special Edition...
Xbox 360 disk tray wont stay shut
My 360 is/was having a similar problem...my 360 would say "reading disc" then "open tray". Well since my system is only about 8 months old...I opted to send it in for repair. Its under warranty. My system is in route to be fixed as we speak. I would advise you to get yours registered too.
May 28, 2009 | Microsoft Xbox 360 Console
My 360 wont ******* play
i had the same problem. listen to your xbox cd rom and if you hear it start up and kinda skip or make a weird stopping sound then your disc drive/ cd-rom is wearing out. either send it in or do what i did and start by just giving the center to the center left above your cd-rom a nice few taps in a row while its spinning before it stops. fairly good knocks on the case will help it. i ended up really hittin mine a lot of time in row after about a month. sometimes it will put rings on your games thought but they buff out. i even took it apart but theres not much you can do
Feb 28, 2009 | Microsoft Xbox 360 Console
Disc wont read
Hi
Are you using a modded Xbox 360 console?, if not then the disc you are trying to play is probably a copied Xbox 360 disc which would not work on an original Xbox 360
Regards
KreativeGeek
Aug 30, 2008 | Microsoft Xbox 360 Console
Game problem
MY 360 DOOR OPENS AFTER CLOSING IT,EJECTS GAME AND CAN'T STAY CLOSED MORE THAN 1/2 SECOND
Mar 03, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
69 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
