Question about Jenn-Air JGR8850 Gas Kitchen Range
Cleaning black cooktop surface - what products to use.
A sticky substance will not come off - it is not cooked on and it seems like an abrasive would take it off but I am not sure whether to use a grainy abrasive.  What would you suggest?
  • 5,911 Answers
It is recommended that you use a straight edge razor blade and push in one direction to remove anything stuck to the surface of a glass cook top. Stubborn, cooked on, substances can be cleaned by scrubbing with a light abrasive cook top cleaner and/or a green kitchen scrub pad. The green srub pads are considered non-abrasive and safe for cook tops. You can also use liquid dish detergent (such as Dawn) to break through grease and grime. DO NOT use steel wool, SOS pads, or any scouring powders. These products can permanently scratch or dull the finish on your cook top. If you have any questions please let me know. I hope you find this information helpful.
Posted on Apr 27, 2010
Sticky mesh
try cooking oil as i use it to remove grease and sticky substance often
May 17, 2014 | Altec Lansing Inmotion-IM600...
Tip
Proper Use and Care of Ceramic Glass Cooktops
Here's some helpful tips that can hopefully ensure many years of quality use of your ceramic glass cook-top.
NOTE: It is important to maintain PROPER care of your ceramic glass cook top as they can be very expensive to replace. Prices vary between models, but most are in the $200 to $300 range. With added labor charges, this repair can cost over $600 from an appliance repair company.
WARRANTIES: Most manufacturer warranties DO NOT cover cosmetics. That is, if your cook-top paint starts to wear off from normal use, or from the selection of cookware you choose to use, manufacturers typically WILL NOT replace it. Warranties also DO NOT cover accidents such as dropping something on the top and chipping or breaking it. Some warranties WILL cover, however, blistering, warping and heat related breakage that were no fault of the consumer (as long as you were using the recommended cookware). It is important to become familiar with, and follow, all the manufacturer's use and care instructions that come with your range.
CERAMIC GLASS CHARACTERISTICS:
It is normal for the ceramic glass to change color when heated. This is especially true for lighter colored surfaces. The color should return to normal when cooled. It is also normal for the enameled or painted areas on the cook top to show signs of wear and fade over time. Proper cleaning and cookware selection can extend the cook top appearance.
It is NORMAL for the radiant heat surface elements to glow red and cycle on and off. There is a thermostat associated with each individual element that regulates the temperature. The frequency at which the elements cycle on and off is determined by the heat setting.
PROPER COOKWARE:
Use ONLY flat bottomed cookware for the best results of heat transfer from the surface elements. Cookware with warped, rounded or ribbed bottoms can cause uneven heat transfer which can result in uneven heating of the cooking surface and cause damage to the cook-top such as cracking and/or permanent surface discoloration.
An easy test you can use to determine the flatness of your cookware, is to turn the cookware upside down and place a ruler across the surface. As you rotate the ruler around the surface perimeter, you should not see any light along the ruler edge where it meets the surface. Cookware with slight indentions or expansion grooves can still be used, however.
Make sure the cookware bottom is always clean and dry before use to prevent any foreign matter from burning to the cook-top surface and leaving stains. ALWAYS place your cookware on the cook-top surface BEFORE turning the surface elements on.
Make sure the selected cookware matches the size surface element in use. The cookware surface should NOT exceed one inch beyond the radiant surface element surface.
COOKWARE CHARACTERISTICS:
The material of the cookware you select will determine how well it transfers heat and how evenly it cooks. The ideal cookware should be of medium to heavy thickness.
NOTE: A non-stick surface will take on the characteristics on the base metal used. (i.e., non-stick over aluminum, will take on the heating characteristics of aluminum).
*ALUMINUM - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*COPPER - Heats quickly and evenly, light weight, suitable for all types of cooking tasks.
*Both aluminum and copper are great when used as a core metal cover with a non-stick or enamel surface. However, when used as a base metal, alone, they can leave metal transfer marks on the cook-top surface which will have to be cleaned immediately following use.
GLASS or CERAMIC - Heats slowly and unevenly, may scratch cook-top surface if there are any rough edges, best results are when using low or medium heat settings.
CAST IRON - Heats slowly and evenly, maintains heat for slow cooking, great for browning and frying, rough on cook-top surfaces, may scratch.
STAINLESS STEEL - Heats quickly and unevenly, a base or core of aluminum or copper can provide more even heating.
DO's and DON''T's:
DO NOT store heavy items, such as jars, cans, pots and pans above the cook-top surface. Any inadvertent dropping on the cook-top surface and cause cracks or shattering.
DO NOT lay hot lids on the cook-top surface. Heated air can become trapped under the lid creating a hot spot as the rest of the cook-top surface cools. The cook-top surface could potentially crack when the lid is removed.
DO NOT slide cookware across the cook-top surface. LIFT cookware as much as possible when moving from surface to surface. This will minimize metal transfer marks and scratching.
DO NOT cook popcorn in prepackaged aluminum containers. The aluminum could potentially melt and may not be able to be removed from the cook-top surface.
DO NOT store anything on the cook-top surface that could melt (such as plastic and aluminum foil). Once melted to the surface, some of these substances may not be able to be removed.
DO NOT store empty pots and pans on the cook-top surface.
DO NOT attempt to use the cook-top surface while the oven is on a self-cleaning cycle. The oven super heats to temperatures in excess of 500 degrees and causes radiant heat to be exhausted from the oven vent on the stove surface.
DO NOT use a cook-top that is cracked. Any spill overs could potentially leak into the radiant heat elements and create an electrical hazard.
DO clean up any spills from the cook-top surface that contains milk or sugar. You may allow the cook-top surface to cool in order to safely clean, but do not allow these substances to remain on the cook-top for extended periods. If not removed, these substances can cause permanent discoloration and stains.
DO wipe down the cook-top prior to, and immediately following use, to maintain the surface appearance.
DO NOT attempt to cook any foods directly on the cook-top surface without a pan!
CLEANING and CARE:
Clean all spills and boil overs immediately.
Any substances that become adhered to cook-top surface can be removed by wiping up excess with hot soapy water and a kitchen sponge.
Use a non-abrasive pad (the green kitchen pads are considered non-abrasive) and a straight edge razor blade, pushing in one direction to remove stubborn particles.
Some metal transfer marks (copper and aluminum) may be removed by simply wiping cook-top surface with a damp sponge. Any remaining marks can often be removed with an approved cook-top cleaner.
Use only approved, non-abrasive cook top cleaner to keep the surface clean and polished.
DO NOT use scouring pads that will dull or damage cook top surface (i.e., steel wool or SOS pads).
DO NOT use any harsh chemicals such as ammonia or bleach that can etch or dull cook-top surface.
on Apr 19, 2011 | Cooktops
How do you Clean Toastmaster 218? what's the Trick?
Be cautious whencleaning..take note of this, UNPLUGFROM ELECTRICAL OUTLET BEFORE CLEANING. NEVER IMMERSE APPLIANCE IN WATER OROTHER LIQUIDS. ? While grids are still warm, brush with clean,soft pastry brush or cloth. ? Donot use steel wool or coarse scouring pads. Remove stubborn ? >stains with a plastic mesh puff or pad. For best results, use only products with directionsstating safe for cleaning non-stick surfaces ? Theexterior finish should be cleaned with a non-abrasive cleaner and a soft, dampcloth. ? Close latch and stand on end for storage.
Nov 21, 2010 | Toastmaster 218 Cool Touch Waffle Maker
How do i clean my cooktop on a whirlpool 465
Light Cleaning
  • Clean your CERAN cooktop after every use. To remove simple spills, wait for the surface to cool before beginning the cleaning process. Pour a small amount of cleaning cream on a damp paper towel and wipe the cooktop surface until the soil and cream are no longer visible. The cleaning cream will leave a protective finish, which will preclude scratches and other types of damage.
  • Heavy Cleaning
  • Wear a heavy oven mitt to remove burnt foods or liquids while the cooktop is still warm. Use the metal razor scraper to remove the substances that are stuck to the cooktop surface. Once the cooktop has cooled, use a damp paper towel to spread a small amount of cleaning cream over the entire cooktop surface and wipe it thoroughly until the cream is no longer visible. Rinse the cooktop with water and dry with a clean paper towel.
  • Cleaning Melted Substances
  • Remove melted plastic, foil or other kitchen products immediately using the metal razor scraper. Spills containing sugar, such as ketchup, tomato sauce, syrup or pudding, must also be removed with the metal scraper at once. It is best to remove these substances while the burner is still hot. Once the melted substance has been removed and the cooktop has cooled, use a damp paper towel and cleaning cream to complete the cleaning process. To protect your hands, remember to wear a thick oven mitt when cleaning the hot cooktop.
  • Tips
  • Scratch marks resulting from daily use will not interfere with the performance of your cooktop. Pots and pans with flat bottoms and those that cover the entire burner surface are recommended for use on your CERAN cooktop.
  • Warnings
  • Spills containing sugar may permanently damage your cooktop unless the substance is removed immediately. Use only the recommended cleaning products on your CERAN cooktop to protect it from damage. Do not use scouring pads, plastic coated sponges or abrasive products of any type. Do not use oven spray or any other type of cleaner containing ammonia or chlorine. Clean all spills thoroughly before using your cooktop again.
  • Nov 07, 2010 | Whirlpool Cooktops
    Good morning we are staying in a house of friends who are on holiday. I would like to clean the Bosch Ceran top but I am not sure which cleaning stuff I can use. Is the use of CIF creamer allowed with a...
    Harry -
    I would first see if your friend has a special ceramic cleaner in his or her cleaning supplies cupboard. If you can't find a ceramic cleaner, the best thing you can do is use hot water to clean the surface. All-purpose cleaners (like Cif) can damage the ceramic glass so it's best to avoid using them.
    Also, look in your friend's cleaning supplies cupboard for a metal razor scraper. Use the razor scraper to scrape off any burnt-on food or spills. Do this by holding the scraper at approximately a 30 degrees angle to the cooktop while wearing an oven mitt to protect your hands. If no scraper is available, don't resort to a knife or abrasive sponge as these could damage the ceramic glass.
    When the cooking surface is cool, apply a few dabs of the ceramic cleaner (if you found it) in each burner area and work the cleaning cream over the cooktop surface with a damp paper towel. Then wipe down with water and dry with a clean paper towel.
    If no ceramic glass cleaner is available, it is sufficient to wipe down with hot water and a soft sponge. Never use abrasive sponges or scouring pads on ceramic glass cooktops. Also watch out for corrosive cleaners such as over sprays, cleaners containing chlorine or ammonia and stain removers - these will just further damage the surface.
    For a list of approved CERAN cleaners see here: www.schott-ceran.com
    Oct 28, 2010 | Microwave Ovens
    My cooktop has only been used since the 21 of Dec 2009 and already is ugly Whats up whirlpool black top
    Hello! Cook tops need a special cleaner that has a mild abrasive. A special sponge used with the cleaner does an excellent of both cleaning and polishing.
    Although there are several brands, the one that works best is called, don't be surprised by its name, Cook Top Cleaner. They make a kit, which has sponges impregnated with cleaner. You can buy sponges and a bottle of cleaner as well.
    Follow directions but be advised the product contains an abrasive and is for the cook top only; It will ruin a high luster finish.
    Burnt on spots can be removed with a razor blade.
    Guru...............saailer
    Jan 12, 2010 | Cooktops
    Spot on Jenn Air smooth cook top stove with down draft.
    Use Cooktop Cleaner with a soft micro cloth. Don't use water. Buff until the mark disappears. Hint: Never clean the cooktop until it is completely cool to touch as doing so makes cleaning much harder. Never use abrasives on the glass or abrasive cast iron skillets.
    Mar 26, 2009 | Jenn-Air JED8430 Electric Cooktop
    How to remove burnt grease, fix lightly scratched black stovetop?
    Hi, I assume we are talking about a flat glass top. First the bad news. using any abrasives will permanently scratch the glass hence the dull spot. You can however make it look a little better. Grease spots and the like can be removed with a flat razor blade scraper which needs to be held flat to avoid the corners making scratches. Use any good glass/ceramic cooktop cleaner ( which is the ONLY cleaner you should ever use ) (available in your local grocery diy store and some hardware stores). The cleaner is a thick liquid, put about a dime size drop on each burner area and use a paper towel to buff out the finish like waxing a car. Once it looks clean flip your paper towel over and shine the top to like new. Good Luck!
    Jan 28, 2009 | GE 36 in. Monogram ZEU769 Electric Cooktop
    Discoloration of cooking surface (darkened) on Bosch stove
    I'm Bruce of DeBruce Polish, our new polish is non-toxic and odorless and non abrasive, should take care of your problem. We designed it for stainless steel, and have faboulous results on ceramic stove tops, and chrome and many other uses. Even removes permanent magic marker. web site will be up soon debrucepolish.com. Phone 612-220-2236.
    Jan 02, 2009 | Jenn-Air 30 in. CCE3401 Electric Cooktop
    Jenn-Air JGR8850 Gas Kitchen Range Logo
    150 people viewed this question
    Top Jenn-Air Kitchen Ranges Experts
    Mike Carew
    Dan Webster
    Dan Webster
    Sal DeAngelo
    Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
