Question about Smeg Kitchen Ranges
Smeg spa 42016 electric oven not working
Fuse and mains have been tested and electricity is getting to it, however, clock, fan, ignitor, all electricals not working. any ideas?
4 Suggested Answers
SOURCE:
SOURCE: Smeg Oven electric burning smell
My Smeg cooker worked fine for 5 years. Then I noticed that the fan which stays on after you turn off the oven did not ever turn off, unless you switched the oven off at the fuse box. I think this is a fan that cools the oven down, but some bit of it is now broken because it doesn't realise that the oven has cooled down. It smells funny when you first turn it on, so I don't know if that is an electrical fault smell. Model possibly 70cm A420-5, but could be an earlier model (bought in April 2000). Is double oven with 4 rings on top, 70cm wide.
Posted on Apr 01, 2008
SOURCE: Smeg Oven blowing
Phew! I'm very grateful for all that freetek but it certainly sounds like I may have a problem outside of my ability. I guess I will have to bite the bullet and get some expensive engineer to come in and sort it.
As a layman I just can't understand how it works fine for 5 years and without any alterations made simply stops! :-(
Thanks for all the advice, I will post back when and if I solve the problem, or wether in simply ends on the dump!!!
Posted on Oct 16, 2008
SOURCE: how do i change the volume on the oven timer? i
whilst alarm is ringing press the minus (-) button. there are 3 volumes to choose.
Posted on Feb 11, 2011
SMEG SPA 42016, tripping switch after oven on for certain time, is this thermostat or Element issue?
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Aug 13, 2013 | Smeg Ovens
Smeg cooker SPA 42016 oven will not heat up although the fan is working and the oven light is on
This happened with my 42016 single oven. It was the element. They can be bought online and are easy to fit.
Mar 17, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Blows mains fuse
Aug 26, 2012 | Smeg SE210X/1 Stainless Steel Electric...
My smeg electric oven model no. SA22XMF/7 is not heating after we lost power. Fan and light is working but the heat is not. What can that be ? Is it the fuse or the element has gone
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Nov 29, 2011 | Smeg Ovens
SMEG DUCO4SS double oven electronic timer the bottom (main) oven does not work no light comes on and no heat but the fan does come on i have sitched the power off waited and then reset the clock
Apr 07, 2011 | Smeg DO81CSS Electric Double Oven
SMEG A42 fan motor problem
check that the fan mounting screws or bolts are in place and tightened
Aug 02, 2010 | Smeg A42-5 Dual Fuel (Electric and Gas)...
We have Smeg DUCO8CSS double electric oven. Bottom oven does not work, clock is blank and fan doesn't work. Top oven OK ! - though usually the fan runs when this is operating.
If the clock is blank, then the main oven will not work, as the clock timer is linked with the main oven.
You need to to get the clock working, or you will not be able to use the main oven
Jan 19, 2010 | Smeg DO81CSS Electric Double Oven
The light and fan works but no heat comes on in oven.
If this helped like us on Facebook please How to Video Tutorials on Domestic Appliances
Jul 08, 2009 | Smeg SE399X/5 Stainless Steel Electric...
Manual for Smeg SpA42016
SpA 42016 is Smeg's postcode in Italy! Model number will be on same lable. Mod:
Jun 14, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Smeg SNZ91MFX1 Fan heating not working
If this helped like us on facebook please
Jan 01, 2008 | Smeg SE250XUK Stainless Steel Electric...
Kitchen Ranges Logo
901 people viewed this question
Top Smeg Kitchen Ranges Experts
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Joseph Mueller
Joseph Mueller
Are you a Smeg Kitchen Range Expert? Answer questions, earn points and help others
