Question about Pioneer PRO-200 60" Rear Projection Television
A very loud static pop noise
The sound is very loud and the sound will shut down for a few seconds when this happens and then comes back. did speak with nboise and they feel the problem is the dvr sending a digital signal which is bad..
could the digital cable from the dvr controller to the boise theater system go bad??? Any ideas will help. this stuff is connected to a sony rear projection tv with its speakers shut off..
  • 438 Answers
I would suspect that you may have a defective coupling capacitor in your preamp or amp, try using another source input or and a different amplifier to help localize the fault, I do not suspect the cable as being the fault, and is more likely and amplifier problem
Posted on Apr 27, 2010
Samsung HLS5086WX/XAA made popping noise and shut off, then made whirring noise.
When my TV did this in the past it ended up being the color wheel. I had someone replace it and it worked fine. I asked it if had to be calibrated after it is installed and he said no. Also make sure the door switch is pushed down when you install the back bulb door. Sometimes this switch can go bad as well.
Jan 10, 2013 | Samsung HLS5086WX/XAA
Toshiba 52hm94 when powered on continuously shuts on and off with blinking red and green light and static noise
that happened to my old LED tv it was the tubes that have gone go into currys and ask an expert thats how i found out what was wrong with mine
Aug 02, 2012 | Toshiba 52HM95 52" HDTV Projection...
I have a bose lifestyle 12 and we get a static sound with a pop and the sound goes dead. If we turn the unit off and back on, it works for 10 minutes or so then does it again. Sometimes it will go for...
It could be bad soldering joints inside the unit. If the unit is moved and comes back on then it will be definitely that!
Otherwise it could be some device which is heating up due to failure and shuts down when it gets to much. When it cools down it starts working again.
Jul 18, 2017 | Bose Lifestyle 12 System
I get a loud static noise, when I first turn on the yamaha ysp-1. Lasts a few seconds. Have unplugged all inputs. Problem persists.
u have a cool sound projector but u have a baaaad power supply system. bad power supply design - u will get all sorts of noise when u power it up. i have a sub woofer with the same problem(which in my case is the way it is designed). i used a delay circuit. but in ur case i know YSP-1 has a clean start up. so, if the warranty still covers it get it replaced. static noises, pop noises are often caused by bad capacitors.
Mar 12, 2010 | Yamaha Digital Sound Projector Home...
LCD HDTV turns off, displays lines & static w/ loud noises
check in your manual and follow instructions on updating the software. you download the file to computer then move it to a memory stick (USB), then simply insert it into the tv
Mar 01, 2010 | Televison & Video
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
02 silverado gas tank popping noise after startup & shutdown
It could just be the heat shield around your exhaust expanding and contracting again when your engine cools down. Sounds like a tin can type of popping noise?? If it is that's the heat sheild from the engine that protect's the spark plug wire and around under the truck cabin. Good luck and hope you find where the noise is coming from.
Apr 06, 2009 | 1999 Chevrolet K1500
Problem with RCA TV Model 27F634T
You almost certainly have a bad picture tube. The green screen was from one of the elements inside shorting out. The static sound you're hearing is the high voltage arcing out through the end of the picture tube to other parts inside the set. It's more economical to buy a new TV than to repair this one.
Sorry to have such good news, but this is one of the ways a picture tube can go bad, and it happens quite often.
Mar 11, 2009 | RCA 27F634T TV
Static noise
Check for the Third earth wire of your computer else check for the motherboard taking earth for the cabinet.
Good luck
Oct 09, 2007 | Dell WL6000 Computer Speakers
Panasonic PT-53WX54 What is that popping noise?
A loud popping noise, like a sharp "snap!", is usually caused by high voltage arcing. Somewhere in the high voltage system an insulator may be cracked or loose, such as the plastic around the flyback transformer or one of the rubber cups on a picture tube. When the high voltage arcs, it momentarily drops and the picture could go out for a split second. High voltage is dangerous in projection sets so allow a qualified tech to service it for you.
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
170 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
