Question about LG DLE2514 Electric Dryer
Check filter light is on cleaned filter still wont work
  • 45 Answers
Your dryervent hose is clogged which causes the air to not circulate. Remove the dryervent hose and clean.
Posted on Apr 28, 2010
Can somebody help fix the problem I'm having with my Honeywell air purifier....when I press power button it won't work all I see is red light any button I press red it wont do anything....pls!!!!.....
I have the same unit.
Have you cleaned out the removable filters?
also the red light at the bottom indicates the time to clean the filters.
to reset it, use a paper clip. The red light on the bottom right is the filter indicator light, what looks like it should be a light beside that filter light, is actually a reset button, just poke it with a paper clip for a few seconds to reset. The bottom red light goes out
Jun 07, 2016 | Honeywell Air Purifiers
Clean filter light wont go out and i cleaned the filter
Did you clean the sensor to? I think that will help a lot.
Jan 19, 2015 | Dehumidifiers
My dryer has worked GREAT...today lights blinking check filter..I thoroughly cleaned the lint filter and cleaned behind and IN lint fliter trap and it still is blinking and WILL NOT let me dry anything....
No there is only 1 filter,typically once a error code is display unlit its clered it wont clear itself.refer to your owners manual to see how to clear the code
Aug 06, 2011 | Dryers
Dryer wont run, lights work, timer clicks
what is the model number?there are a couple of things you can check with the little info you sent,check the door switch,push the paddle in and out ,if it doesn't click it's bad,check to see if the belt broke,on some dryers there is a switch down near the pulley,if the belt brakes the dryer won't run,one more thing if your dryer hasn't had a clean out in a long time or if your clothes have been taking a long time to dry check the thermal fuse located on top of the blower wheel housing,if the lint filter is on top the fuse is in the back,take off the vent line,remove the back panel and check the fuse located to the right and down near the bottom of the duct that the lint filter slides into,if the filter is inside then the fuse is in the front the fuse is on top and to the right of the blower wheel housing,also you should clean out the duct that the filter slides into,blow out the vent line,check outside and make sure the flapper is not blocked with anything and vac out the inside of the dryer where the motor is,you need to do this once a year anyway,if you still need help send the model number and let me know what you find,unplug the dryer to clean it and when working on it and remove one of the wires when using your meter
Mar 17, 2010 | Kenmore Dryers
Aquarius hotpoint wf541 wont pump the water out at the end of the cycle
You need to clean the filter.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove and clean the filter inside hose.
Remove hose onto pump, and check for blockage or obstruction here as well
Hope this helps with your problem
Dec 28, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Check filter light wont shut off and setting.lg tromm dryer
You might need to check the exhaust on the rear of the Dryer, or the blower motor iether one has lint inside, restricting the air flow
Dec 23, 2009 | LG Dryers
After cleaning red cell light wont go off
This red light goes on when air purifier needs to be cleaned, also check out whether fan is running or fan is stopped if fan is not running and red light is on then the problem is of filter got wet inside.let the filter get dry then check out.if still the same problem the filter needs replacement. to remove the filter for cleaning or replacement Remove the ESP cell by taking hold of the handles and lifting upwards. and then Remove the Oxygen Plus filter from the unit.by lifting it up slightly. its the filter problem either its wet and needs to be dried out or the filter is got clogged by dust and needs replacement.contact the local service center for air purifier and get the replacement filter.------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Nov 24, 2009 | Oreck Super Air 7 Air Purifier
Light flashes remove filter and clean
did try kenmore website
sears has a great place for trouble shooting
Feb 06, 2009 | Kenmore KCM12 Coffee Maker
Front loading dryer
The check filter light is just a reminder light and cannot be reset.  Nothing to worry about.  Just keep the filter clean before each use.
Nov 21, 2007 | LG DLG2524 Gas Dryer
LG DLE2514 Electric Dryer Logo
442 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
