Question about Pioneer GM-X542 Car Audio Amplifier
What guage wire do i need for a pioneer gm-x542 amplifer?
    Top Expert:
  • Pioneer Master
  • 80,417 Answers
14 or 16 gauge 16 is easier to work with
Posted on Apr 27, 2010
I need wiring for pioneer gm 3000 amp?
Here is the pinout. You need to solder your own connections.
I’m happy to help further over the phone at https://www.6ya.com/expert/chris_7f7f91eb941fb23f
Oct 15, 2014 | Pioneer Gm-3000t Car Amplifier
The protect light wont turn off, so power light wont come on
OK, I am assuming that you are talking about an amplifier, right? If so, check the wiring. An amplifer's protection senses fluctuations in amperage load. This is a good thing. It's saving your amp from frying, so don't be mad at the amp. Start with the ground wire. This is typically the source of the problem. If you know how to use a multimeter, use it to ensure that your ground is a good position. If you solve this, look at the guage of wire you are using. 50-65 amp loads from 13-22 foot runs are acceptable for a 4 guage wire. If you are running 8 guage for this, you need to upgrade your wire. Look at your amp. Check the fuses. The numbers on the fuses, add them up. You can use that as a bases for your amperage load. Also, is your remote wire allowing the amp to turn off, and thus reset? Something else to think about. Happy Wiring
Aug 12, 2011 | Car Audio & Video
Pioneer GM-X542 , i have 2 1 running each sub 1 is workin fine the other is popping fuses everytime it is powered up,, got power going to both from the same power block???? can u help
chances are the power supply in the amp is bad. it may be able to be repaired. you would want someone who knows what theyre doing to look at it. it may cost more to fix than what its worth. good luck
Dec 29, 2009 | Pioneer GM-X542 Car Audio Amplifier
I dont Know what guage of wires to use with my Amp
8ga will be fine with the amp listed, but if you plan on upgrading in the future, then go ahead, and buy the bigger wire. 4ga +. See at the time of purchase there is only about $20 difference between 8ga, and 4ga kits, but if you go with the smaller wire for now, and then upgrade later on, you end up paying double for yopur wire, and double for your install (if you arent doing it yourself).
Aug 07, 2009 | Pioneer GM-X332 Car Audio Amplifier
Pioneer GM-5200T problem
i dont think transistors are bad . you should check the amp controlls they may need adjusting
Jan 20, 2009 | Pioneer GM-5200T Car Audio Amplifier
Pioneer GM-232 Amp
amp%20specs%20001.jpg444bbca.jpgcc2af91.jpgthese are from the actual owners manuel-i used to have this amp also. hope these help
Dec 29, 2008 | Pioneer GM-232 Car Audio Amplifier
SOUND CUTS OFF AT HIGH VOLUME AND POWER LIGHT FLASHED RED
You need to check the DC voltage across the power and ground terminals of the amp. If the voltage drops below ~11v when the amp shuts off, you need to check the power/ground wiring and fuses.
If the voltage remains above 11 volts, you may have a problem with the load on the amp (incorrect ohm load, shorted speaker, shorted speaker wires...).
Jun 13, 2008 | Pioneer GM-X542 Car Audio Amplifier
Pioneer Amp
Hello Shaun123, Phase adjust the amount of lag or lead one signal has in reference to another. Frequency is an adjustment of the number of cycles pers second a signal will produce. Gain refers to the amplification factor of a signal. now in reference to you amplifier by changing phase you can set the delay of a signal (if used right you can make a wicked reverb effect), but setting phase normally will affect the tones Frequency will affect for bass and treble functionality Gain will both preset and provide amplitude adjustment (volume) Take into mind these are more then likely presets. I hope this helps
Sep 05, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
Car Audio & Video Logo
128 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
