Question about Dell E173FP 17" LCD Monitor
Monitor does awake from sleep mode
When I step away from my computer and it goes into sleep mode, I'm unable to awaken the monitor. After moving the mouse, the power button on the monitor simply flashes green. I am unable to turn on the monitor by quickly pressing or holding down the button. The button just keeps flashing. Even when I unplug then replug, the button flashes without displaying a picture.
  • 2 more comments
  • madelman547 Apr 27, 2010
    Not sure how to get into the menu settings since I'm not getting any image on the display.
  • madelman547 Apr 28, 2010
    Ahhh. Thanks for the clarification. Unfortunately, I fear the problem is at the point of no return now as the power button won't stop flashing and there is no image displayed.
  • frankdanfelt May 11, 2010
    You need to perform this before the unit goes into sleep mode.
    Go into the menu settings on the monitor and set it to "Default"
  • 11,361 Answers
You need to check the inverter fuse, transistors, caps, solder joints. Please see my pictures here to get some ideas so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/Dell%20E173FPb/
Please post back.
Replacement board: http://www.lcdrepair.us
Posted on Apr 27, 2010
  • Bud Martin
    Bud Martin Apr 28, 2010
    The light is flashing because the power supply is in the shutdown/restart, it is sensing too much current draw. You will not get the display until you get the cause of the overload fixed.
LCD monitor turn to sleep mode
Does it turn off or go to sleep? If it turns off , there may be a setting that needs to be reset or reprogrammed. If it goes to sleep because of inactivity, just move mouse to awaken it
Sep 27, 2012 | Vocopro Ltv-5 LCD Display System
HI HAVE A NEW AOC COMPUTER MONITOR FROM AOC. IT SHUTS DOWN EVERY TIME I LEAVE IT AND I WOULD LIKE FOR IT TO REMAIN ON ALL DAY LONG AND I WILL SHUT IT DOWN AT NIGHT MANUALLY; HOW CAN I DO THIS. ...
go in to monitor in the control panel and set the sleep mode time mode
probably better if you go into bios setting and click on computer start from any key movement
that way the monitor and computer go into sleep mode and that saves money on power and you only have to move the mouse or press a key and 10 seconds later the screen is awake and the computer is operational
I am typing this looking at an aoc monitor attached to a pc ;
Sep 13, 2017 | AOC 931SWL 19 inch Monitor
Monitor will not awake from sleep mode. Pilot light is amber when asleep. If the monitor is turned off pilot light goes from amber to off or black or nothing. Turning the monitor back on the pilot light...
That means your monitor is not receiving a signal from your video card.
A couple things to check:
*Make sure your cable is ok - unplug and replug the cable to see if it is a loose connection. Or try a different cable.
*Make sure your computer is not in sleep mode - Move your mouse or otherwise ensure your computer is awake and sending a video signal
*If you have another computer, try the monitor on the other system and see if it works.
Sep 03, 2017 | LG L196WTQ-BF 19" Monitor
My Dell monitor goes to sleep right after windows xp starts to load and it won't come on after that. my computer is still running but the monitor is a sleep. I have hit f8 and f12 with nothing happening....
Go into safe mode
Under settings, control panel, power options set "turn off monitor to never
reboot
I think this is not a sleep problem but the incorrect monitor settings were set. This will cause the screen to go black when the OS comes up. Boot in safe mode and change the display settings
to 640x480
OR
in safe mode, delete your monitor. When you reboot it will load a default monitor and you should be OK
Oct 13, 2010 | Dell XPS 410 PC Desktop
I have a dell optiplex sx280 computer and monitor that has lapsed into ''power save mode'' and I have been unable to ''awaken'' it (I'm not sure which is ''asleep'': the monitor or computer!) from sleep. I...
How's the status light of your computer monitor? is it blinking amber? and the status light of your computer tower's power button? blinking amber as well or solid green or no light at all?
1. Disconnect all the connection at the back of your computer tower
2. Press the power button of the computer tower for 15 seconds
3. Reconnect the power button and the monitor cable at the back of your computer tower and turn on the computer (if it turned on that means that one of the device plugged at the back of your computer tower is faulty)
4. If still the same problem, open up your computer tower.
5. Reseat the video card, Reseat Hard drive, Reseat Memory, Reseat CPU, Reseat power cord coming from the CPU to your computer (doing all things one-by-one to pin-point the root cause of the issue)
If none of the troubleshooting steps fixed the problem, possible that the power supply is faulty and if the power supply is faulty sometimes it goes with the motherboard.
Jan 08, 2010 | Dell OptiPlex SX280 PC Desktop
Mx75 monitor turns off when I awaken my computer
right click on desktop select properties(screen saver ) select monitor button in that select turn monitor never.(configure carefully)
Nov 24, 2009 | HP Pavilion MX75 17" CRT Monitor
Monitor goes to sleep after not being in use and then won't wake
Check the "power options" settingsin your control panel.
Nov 16, 2009 | HP W2007 LCD Monitor
Acer V223W monitor goes to sleep and doesn't awake
Go To Start > Programs > Accessories > System Tools > System Restore. Select "restore my computer to an earlier date". Look at the LIST of Restore points. Find the DATE when this "Security Update" was installed and Select the last date before it was installed and Follow the "Wizard" to Restore it to BEFORE the Update you think CHanged Things. Too many variables to figure out without seeing it to determine what was changed but that will correct the situation and you will not loose anything.
Aug 21, 2009 | Acer V223WBD Monitor
Monitor Samsung914v will not awake from sleep mode using Vista HP
Pease follow the below steps
Right-click on Desktop Screen- Select properties- Click on Screen Saver tab- Click on Power button- Change the power scheme option to "Home/Office Desk"- Click on OK to save and exit the window. This should resolve the issue and hope it resolves.
Feb 01, 2009 | Hanns.G Corporation HU-196DP LCD Monitor
When I select sleep or hibernate mode - the monitor stays black...
Hit the keyboard keys. It is better to just turn sleep and hibernate off and just use a screen saver or tun it off.
Aug 24, 2007 | ViewSonic VX910 19" LCD Monitor
Dell E173FP 17" LCD Monitor Logo
256 people viewed this question
Alun Cox
