Question about Powerline Ethernet Network Adapter
Powerline Adapters and Streaming Movies
I have 200 mbps powerline adapters connecting my desktop in a second floor office to my WD TV Live in the first floor family room. Movies stored on a large hard external drive attached the desktop on 2nd floor play poorly (seize up). The 200 mbps powerline adpaters should easily handle even HD movies (movie files that seize up range from 750 MB to 10 GB for a ~2hr film). Where could the problems be?
5 Suggested Answers
  • 193 Answers
SOURCE: Powerline ethernet lost connection
this is usually caused by dirty power, have you installed cfl light bulbs recently?
you might also check to see if any existing full fluorescent lights produce a buzzing noise.
Posted on Aug 14, 2009
SOURCE: connecting powerline ethernet adapters through orange livebox
  1. Make sure the LiveBox is set to "TV ethernet non active"
  2. Set OFF other existing connections (such as wifi), if any.
M. Razaire
Posted on Aug 20, 2009
  • 88 Answers
SOURCE: Can you explain to an idiot, which exactly what is
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Posted on Apr 03, 2010
  • 5 Answers
SOURCE: I have been using my Belkin powerline adapter
Is the same phase used in your office?(electrical wiring)
Posted on Aug 20, 2010
How do i fix after modem reset
Basically, you unplug all of the Netgear Xe104 units, wait a minute, then plug the one nearest to the Router back into a wall socket first. Wait a few seconds then plug in a second Xe104 and give it a minute to "talk" to the first unit. Then plug other Xe104's in one at a time. Below you'll find the official troubleshooting steps which you should read carefully if the basic steps above do not resolve the problem.
Also, i should tell you that Powerline adapters such as yours have improved greatly in the last few years, and you can buy a pair of new ones that are very, very much faster than yours for a very modest cost. For example, TP-LINK TL-PA4010KIT
or NETGEAR Powerline 500 1-Port Starter Kit (XAVB5201) or
ZyXEL PLA4225 4-Port 500 Mbps Powerline Gigabit
XE104 User Guide 4-2 Troubleshooting v1.0, September 2005
Power Light Not On Make sure that, if power to the AC power outlet is controlled by a wall switch, the wall switch is in the on position. Verify that the wall socket is live by disconnecting the XE104 85 Mbps Wall-Plugged Ethernet Switch and plugging in some other electrical product, such as a lamp or a hairdryer. If the error persists and you have confirmed the power outlet you are using is live, you have a hardware problem and should contact technical support.
HomePlug Light Not On If the power light is on but the HomePlug light is not, check the following: • Make sure that power is being provided to more than one PowerLine device. Another PowerLine device must be installed for successful communication across the PowerLine. • Verify that the network password is the same on all devices in the PowerLine network.
Ethernet Light is Off • Make sure that the Ethernet cable is plugged in properly at both ends. • Be sure you are using the correct cable on the router that the first XE104 is connected to. When connecting the router's Internet port to a cable or DSL modem, use the cable that was supplied with the cable or DSL modem. This cable could be a standard straight-through Ethernet cable or an Ethernet crossover cable. • On attached Ethernet device or network adapter card, check that the Link light is
Feb 25, 2015 | NetGear Xe104 Wall Plugged Ethernet Switch...
Problem with royal+ powerline eathernet the one unit rpl-204 power light not on once i plug in few lights on after it is like dead any help thanks
You need to plug the unit with 1 port into an outlet near the source of internet connection and the second unit acts as the hub once plugged in.
Mar 06, 2011 | Royal + 200 Mbps Digital Home Powerline...
I have a network with one desktop which is always on, one Sony Bravia TV and one laptop. All connected via D-Link powerlines (306/307 AV). My laptop connection is problematic. When the laptop restarts,...
Here is the link to the D-Link website: http://www.dlink.com/products/default.aspx?pid=DHP-307AV&tab=3
I would suggest downloading and updating the firmware for the device(s). Also, because it is expanding the wireless reach of your router via electrical wiring, any interference may inhibit the correct functioning of the system. I would suggest you try connecting to your wireless without the powerlines active to ensure it is not a faulty router or wireless card. If it still does not work with the powerlines deactivated, you may need to look into getting a new router or wireless adapter.
Hope this helps.
Feb 28, 2011 | D-Link DHP-307AV Powerline Network Adapter...
I have just bought Belkin Powerline AV starter kit. I have a Belkin N1 Wireless Modem Router connected through a Carrier PoE adapter. I have tried to connect my Sony TV and PS3 through the powerline units...
Try reset the device and start a new configuration.It seems that your networwork have issues between the router and the powerlines.All need to be in the same network as per router configuration.Connect one adapter to your router and plug it into an available electrical outlet. Plug the second adpter into an available wall outlet and connect the other end to any device with an available Ethernet port such as a gaming console, set-top box, or computer.
pd: OS to use the adapters; Windows 2000, XP or Vista.
Feb 24, 2011 | Belkin Powerline F5D4050 Network Adapter
This thing doesn't work. When moving the remote unit downstairs, it doesn't connect to the network.
The powerline modems are affected by the other connected equipment in your house and the wiring phases.
For BOTH modems try the following first:
-Connect the modems directly to the wall socket, don't use an extension lead.
-If you have a surge protecting extension block plugged in in the next/adjacent socket, try plugging it in on a different mains socket.
If this does not work, you may want to think again about routing an Ethernet cable between floors.
Higher performance and lower cost.
Feb 13, 2011 | Zyxel PLA407 HomePlug AV 200 Mbps...
I have two Belkin powerline adaptors 200mbps type
Your hard disk is failing and should be replaced. Have you tried to press F1 when you get the message? If this doesn't help try to enter the bios and disable S.M.A.R.T.
Your first goal is to save the data so please do that before it's too late.
Mar 09, 2010 | Belkin Powerline F5D4050 Network Adapter
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Mar 09, 2010 | Powerline Ethernet Network Adapter
Aug 14, 2009 | Powerline Computers & Internet
Powerline Ethernet Network Adapter Logo
89 people viewed this question
Top Powerline Computers & Internet Experts
Chris Larocque
Ivan Young
Ivan Young
Are you a Powerline Computer and Internet Expert? Answer questions, earn points and help others
