Question about Dell 810 All-In-One InkJet Printer
Paper Jam My paper jams all the time it goes in slanted and then doesnt take the paper in all the time but still prints. Please could you help me
  • Jammie79 Mar 27, 2008
    I decided not to try and solve the problem and got them to exchange it.. It is still under warranty
Thanks acdr your a wiz, i put it on its side,moved roller around cleaned with swab and gave it a few "taps" working ok now, thank you again acdr. now i can print my gransuns hockey scheduals out for him.
Have a good year.
Posted on Jan 09, 2009
    Genius:
  • 1,913 Answers
Hi
open your fuser assembly change your taplon tape or roller
check that taplone tap moves arrond roller.
alwaays papeer jam problem bcuse of bad condition of tapelone tape
try dear u can do this
\bye
Posted on Mar 24, 2008
SOURCE:
There is a document jam 1. After I remove the paper and code goes away, the printer may print a page or two and then jam again. I have tried a new pack of paper (fanning it) I have tried a new...
You refer to a document jam then you mention fanning new paper but that refers to a paper jam.Which one is the problem? What does the screen say? If document jam then its your originals you are copying. If paper jam then its the paper in the machine. I cant help you any more because your do not state the make or model. Please repost with a lot more detail. Cheers
May 16, 2011 | Office Equipment & Supplies
Paper jam problem
Hello... i have a copier IR6570. If i load the paper from tray 1, it always jammed. But if i load from other trays, everything goes well. Can anyone help me, please...?.
Jul 20, 2010 | Canon imageRUNNER 1370F Grayscale Copier
Photo paper cannot print
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Oct 05, 2009 | HP Office Equipment & Supplies
Paper Jam
try a test page..and see if that flows..
Aug 20, 2008 | HP LaserJet 2100 Printer
Paper jam
Are you sure you have the correct size paper?
Also check and make sure the exit rollers are turning, if not then there is a broken gear in hte fuser
Jul 23, 2008 | Office Equipment & Supplies
Paper Jam
Remove all the paper from the paper tray so that nothing gets sucked up in there while you're working. Hit the cancel button a few times until the screen clears itself and goes back to the "Print", "Copy", "Scan" option screen.
On your computer, if the printer option screen is up (depending on what kind of computer you have, a small screen might pop up to tell you the print progress), hit cancel or clear on any of the lines that say "Paper jam", if there are any.
The next time you print something, only put as many pieces of paper in the feed as you need to print. This should eliminate a lot of the chance of actually getting a paper jam.
Please respond again if this didn't help. I'm not sitting in front of my own computer right now, so I might not be following the same steps that I usually take.
Feb 02, 2008 | HP Photosmart C4280 Aio Printer
I860 False Paper Jam Message
Check the back of the printer. There should be door at the bottom. Your paper jam could be there.
If this helps you, please rate me. Thanks, Patty
Nov 06, 2007 | Canon i860 InkJet Photo Printer
Printer prints crooked (8.5 x 11 from paper tray)
check that the paper guides on paper cassette are hard up against paper edges
Oct 27, 2007 | Brother HL-2070N Laser Printer
Print problem
i believe that you may not have properly released the 2 green levers behiind the printer, they need to be in the up position
Jan 10, 2007 | HP LaserJet 1200n Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
Dell 810 All-In-One InkJet Printer Logo
67 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
