I am trying to install win xp pro in ibm R51 laptop. the message on the screen (Setup Cannot Access Disk). System Halted , so what is best solution to install win xp.
  • Mohammed Arif Apr 27, 2010
    yes I boot from a cd, after it checked configuration . checking hard drive, partitions etc...and stopped loading got message on screen '" CANNOT ACCESS TO DISK DRIVE" and system halted .
  • Mohammed Arif May 01, 2010
    Great Job Thanks
  • 977 Answers
Hi!
I don't seem to understand if you can even enter/start the setup process... Do you manage to successfully boot from the CD??
Regards,
Pelu.
Posted on Apr 27, 2010
  • Ran Kedar
    Ran Kedar Apr 27, 2010
    Hi again!
    I guess setup DOES recognizes the hard drive (so it's not a missing SATA AHCI drivers...), right??
    If so, it sounds like something that is caused due to a faulty hard disk drive. You can use HDD Regenerator (download, burn, boot from CD) to try fixing BAD SECTORS on your HDD. If it founds any - it's recommended that you'll replace the drive (even if it fixed them all! Bad sectors sometimes reappear...).
    I'm here if you need any further assistance!
    Good luck,
    Pelu.
  • Ran Kedar
    Ran Kedar May 01, 2010
    Any time.... :)
I am getting a blue scree error on my IBM Thinkpad R51 that says unmountable_Boot_Volume. It will not let me run on save mode...it brings me back to the blue scree error message. I have windows xp
Unmountable boot volume = The file system is damaged and cannot be mounted.
To fix that do the following:
1.Put the CD first in the boot order and boot from the XP install disk.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.Select your partition - it should be C
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Jun 14, 2010 | IBM ThinkPad R51 Notebook
I wiped xp home edition from IBM thinkpad r51 laptop and installed win xp pro with sp2. Now I have no sound and cannot setup an internet connection. I am sure it is drivers but I don't know which ones to...
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP device drivers for your model computer, Use this link: -
http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
You can download the various drivers and then you click on and run the various driver files, they will then unzip and expand into a folder on C:\drivers Then install the various drivers from this folder.
By the way, you should install SP3 it contain some security bug fixes.
Nov 09, 2009 | IBM ThinkPad R51 Notebook
How to install windows xp into compaq presario cq40
compaq cq40 is one particular model from compaq which is literally designed for vista and when you want to install win xp ;it doesn't work becoz the BIOS block it;the only way out is to downgrade the system BIOS which is a risky thing.check your bios model and version and google for a lower version and download it and flash the ealier BIOS.gooogle more on How to downgrade BIOS
Sep 21, 2009 | HP Compaq Presario CQ50Z-AMD Sempron(TM)...
IBM ThinkPad 600E trying to put os on it
that is correct.. IF you are using windows 2000 the files are NOT the same as the files under XP.. Your best bet is to EITHER install the complete XP or find the win2k installation disk,, even an upgrasde disk for win 200 can be found probably around 100.00. IF the system isn't booting from your XP disk IS Your disk an ORIGINAL or a copy of the original?.. If for example your CD rom is drive E then see if you can find a win XP emergency boot disk and access the CDROM goto e:\windows\i386 then run the setup program, many cases this will overwrite your existing OS.. but do so at your OWN RISK I will not be accountable if you lose any of your important files.. some win98 emergency boot disks can access the cdrom but you may have to make certain additions to the autoexec.bat and/or config.sys files. be careful when using DOS because you can completely delete EVERYTHING on the HDD if you use the right command(s). As A DOS BABY I have performed many lazarus miracles but I have been using dos since the early 70's
May 22, 2009 | Computers & Internet
I cant login
friend
just use the xp disk to repair the installation
hope it will solve your problem
thanks
Apr 10, 2009 | IBM ThinkPad R51 Notebook
Blue Screen on R51
You will need to do a clean install of your operating system from the disks supplied with your computer, and then immediately afterward, supply yourself with some means of backup of your precious files, which if you have not already performed previous backups are, alas, gone.
Suggest that the backup method be a large external drive where you can store several copies of disk images for your laptop, which will prevent future data loss.
Sorry.
Mar 29, 2009 | IBM ThinkPad R51 Notebook
How to install win xp in toshiba portage r200 laptop
This is resolved by installing Intel Storage Manager drivers through "F6" option on XP Setup. YOU MUST HAVE AN EXTERNAL FLOPPY DISK (A Drive)...as the Portege doesn't come with one...and XP does not support USB or CD ROM for this particular function.
Mar 18, 2009 | Toshiba Portege R200 Notebook
Hi, I have an IBM R51 Type 2887 Thinkpad that came with Windows XP Home edition. I formatted the laptop and put the Windows XP Professional in it. However, it could not install few key drivers (Eg. CD ROM,...
You need to access a computer that is connected to the Internet, (try going to a friend or work mate or nternet cafe etc.)
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP audio driver for your model laptop,
www-307.ibm.com/pc/support/site.wss/MIGR-39956.html
Copy the downloaded files and install them on your computer.
Jan 31, 2009 | IBM ThinkPad R51 Notebook
Computers & Internet Logo
David Payne
David Payne
