Question about Dell UltraSharp 2005FPW 20.1" LCD Monitor
I have a dell 2005FPW and it seems to go into this very shaky screen when its idle or when i turn it on after it quits sometimes like 5 minutes it will be fine till next time is the monitor bad?
  • 11,361 Answers
More likely to be components (caps) failure in the power supply/inverter board. You can look for bad caps with bulgign tops, burnt parts, bad solder joints.
Board: http://www.lcdrepair.us/2005fpw-power.html
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Apr 27, 2010
Dell 2005FPW screen turns black after a second ,can not get it back on
this is a fairly common problem. The backlight circuit is probably shot. Not much to do but replace the monitor.
Oct 05, 2014 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Display jumping vertically
I had same problem.
Narrowed it down to C637 on logic board.
Replace C637 or logic board.
Sep 21, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell 2005FPW Monitor Flicker problem
The flickering is most likely the florescent backlight having a hard time starting, Just like in a light fixture, as it gets old, it takes longer to warm up to get full functionality.
If under warranty, contact Dell for a replacement, if not, then when it becomes untenable, replace the monitor. Prices are dropping drastically, an new 20 or 22 In can be bought for about $150 or less
Aug 08, 2009 | Computers & Internet
Dell 2005fpw flash problem
Often this is a capacitor problem, there have been many problems with them as of late. http://www.badcaps.net/forum post here and they will be able to help you out.
Jun 12, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell monitor 2005FPW keeps on flashing
I was having the same problem.
I solved it by replacing the two 47µF capacitors on the power supply/inverter board.
I actually removed all the capacitors (around 13) and all checked out fine except for the two 47µF.
I forgot to take pictures or even write down the capacitor label on the board.
They are located close to the logic board connector
Feb 05, 2009 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell screen
Hi...there,
It's open from the front bezel of the screen. But if you are still under warranty...send it back to Dell for repaired... Happy Holidays!
Dec 05, 2008 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Flashing on and off
I would suggest trying another monitor to rule out your PC or monitor card. I would also check the video settings on the PC. Then assuming your cable/connector and video card are okay, it sounds like a lamp or lamp driver (a.k.a. ballast or inverter) issue. In other words, an internal issue that probably needs component-level troubleshooting.
Jan 08, 2007 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Screen resolution
1680 x 1050 at 60 Hz is the ooptimal resolution and the only one that will not be fuzzy.
http://support.dell.com/support/edocs/monitors/2005FPW/En/about.htm#Specifioications
press command - shift - a to bring up the Applications folder. Then open System Preferences. Click on Displays, from there you should be able to adjust the resolution
Oct 10, 2006 | Dell UltraSharp 2005FPW 20.1" LCD Monitor
Dell UltraSharp 2005FPW 20.1" LCD Monitor Logo
242 people viewed this question
Alun Cox
