Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Water stains on stainless steel doors
It appears water ran down the front of the stainless steel finish Kenmore refrig leaving a stain that won't come off. I can feel the roughness in places. I've tried vinegar, but it won't come off. Suggestions greatly appreciated. Chuck Klein
5 Suggested Answers
SOURCE: cleaning tray on door where water is dispensed
the stains is from hard water.(calcium)you can get a new tray from sears.com
Posted on Nov 26, 2008
  • 531 Answers
SOURCE: water stains
try jiff
Posted on Mar 31, 2009
ginko
  • 19396 Answers
SOURCE: My Kenmore 73503 Stainless Steel
Hi.
THe drain hose and duct located inside the fridge section is probably obstructed.
Most common cause for obstruction is water freezing inside line duct.
The best way to fix the problem is allowing the fridge complete defrost. This will probably fix the problem.
If it does not, the drain duct must be unlocked using a thin flexible shaft. Most of the time is sufficient to allow full defrost to fix the problem.
Posted on Aug 17, 2010
caroldon
  • 17130 Answers
SOURCE: My kenmore elite refrig keeps
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Posted on Sep 27, 2010
Please tell me how to get water stains off the front a stainless steel fridge. I have tried everything I can think of.
James, If really stubborn stains, you may have to use a chrome polish and buff. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Cleaning Stainless Steel Appliances Cookware and More
Removing stains from stainless steel refrigerator
How to Clean Stainless Steel Appliances Easy Kitchen Cleaning Ideas That...
Coulter Cleanup Refrigerator Rejuvenation
Jun 11, 2016 | GE Profile PFS22 33" Artica French Door...
How to clean stubborn burned on stains in the stainless steel oven
You need to use ordinary soap as a lubricant and a fine steel wool to buff the steel surface. That will remove any built up surface debris completely but you may still have some discolouration of the metal remain.
An automotive polish designed for polishing stainless steel and aluminium (available from auto parts stores) might finish the job for you and remove much of any remaining staining but I would not use a chemical of that type on an inside surface that is used for cooking your food. (Same issue with those dreadful chemical and toxic oven cleaners).
Unfortunately, with use of the unit and heat , you will get some residual discolouration of the stainless steel.
Nov 11, 2015 | Stainless Kitchen Ranges
I love stainless steel appliances and have a lot of them at home. But, it is trouble cleaning them. They look really bad if they are not kept clean regularly. How can I get rid of the stains and marks on...
get a 'oxygen' based cleaner soak overnight.
normal cleaner works based on surfacetant. oxygen cleaners works by dissolving the stains.
of course, you can use some elbow grease and polish them.
Oct 16, 2013 | Ronco 'Showtime' Rotisserie and BBQ...
How do I clean my stainless steel surface on my Samsung Refrigerator. I have use several stainless steel cleaners and they all leave a film. I am unable to get out drip stains from water.
Start with soap and water to remove old polish, then use CLR to remove build up, then use a product called Stainless steel Magic to clean. Make sure when your done to buff off all remaining cleaner
Jun 14, 2012 | Samsung RF265AA Bottom Freezer French Door...
White water mark stains on stainless steel
Debruce Polish will remove these marks. DeBruce Polish is all you will ever need for your stainless steel and ceramic cook tops, polished granite, marble, porcelain, formica and glass. DeBruce is non-toxic odor-less and eco-friendly. You can get DeBruce on line at debrucepolish.com.
They also have a you tube demo "debruce method"
this stuff really works
Aug 04, 2009 | Jenn-Air JCB2280HES Side by Side...
How to clean stainless steel
You say your new oven...and DW have stains...I will assume (if that's OK) that you have a stainless steel oven...and are washing stainless steel in the DW...but you are having streaks and or white...spots or deposits...Sounds like hard water...you may try a localized..(just for the DW and kitchen sink area) filtration system...to reduce hardness of water...(is this well water)..if so you definitely need filtration...if you don't already have it.
Here are some issues and or cleaning techniques for stainless steel.
stainless steel is known for its ability to be a clean surface that resists corrosion and rust. Dirt, dust and grime, however, put stainless steel at risk for corrosion and rust. Luckily, stainless steel responds well to cleaning, never wearing out from excessive cleaning, as long as certain rules are followed. 1. Water and a cloth.
Routine cleaning can be accomplished by using warm water and a cloth. This is the least risky option For cleaning stainless steel. Dry with a towel or cloth to prevent water spots. Wipe in the directions of the polish lines.
2. Mild detergent, (dish washing liquid) and cloth.
For cleaning that needs more power, mild detergent and warm water can do a great job without damaging the stainless steel. Make sure you rinse the surface thoroughly to prevent staining and spotting. Towel dry to prevent water spots which can be caused by minerals in water.
3. Glass cleaner for fingerprints.
Fingerprints are one of the biggest complaints about stainless steel, but can be taken care by using glass cleaner or household ammonia. Rinse thoroughly and towel dry. There are some newer types of finishes for stainless steel that resist fingerprints, a must if your pint-sized helpers leave their mark on your stainless steel appliances.
4. stainless steel Cleaner.
If you’ve had staining or scratching, or need to polish your stainless steel, a stainless steel cleaner may be a good option. Some of these cleaners and polishes can help minimize scratching and remove stains. They also can polish stainless steel surfaces nicely. Read the directions on the stainless steel cleaner and test in an inconspicuous spot. Be sure to rinse thoroughly and towel dry.
If this does not help please clarify...with specific model #'s and walk me through (step by step) what the specific problem is and how you address it....Thank you and I hope this helps.............
Good Luck...........The Fang.
Mar 06, 2009 | GE Nautilus 24" Built-in Dishwasher
Discolorations/stains on stainless steel refrigerator surface
Tried lots of suggestions to no avail. Tried a USED, dried out Scotch Brite Cook Top pad on the scrubber handle with Heavy Duty Fantastick sprayed on the pad. Scrubbed the drip marks at the bottom and wiped away to see if it was "scratching" or marri8ng the finish. Nope, but IT WAS taking the water marks off. So I did a bit more and checked again. Working great with no problems for the finish. Cleaned the whole watermark area. Rinsed of with wet cloth. Let it dry and then used my usual stainless cleaner, buffed to shine and walked away to post this. :> My refrig is an Aman too but I read other problem sites and it is common with stainless steel refrigs
Feb 26, 2009 | Refrigerators
Rusting of the door on a stainless steel refrigerator
True stainless steel will not rust, but it can get rust stained, which could be removed. Without any further info about your situation, I'd have to guess that you have a high iron content in your water supply, and thus rust issues with your sinks, etc., unless you have a good iron reducing softener and the water to the refrig is not running through that softener. Again, without further info, I'm guessing the rust issue is at or below the water dispenser area. Keeping the water from spilling over the drip tray will help. You might try Wink rust remover, but do test it on an inconspicuous area first to make sure it will not adversely affect the finish in a visible area.
Dec 07, 2008 | Frigidaire Gallery Series GLHS269ZDB 36"...
Cleaning tray on door where water is dispensed
Nov 26, 2008 | Kenmore 44103 Side by Side Refrigerator
Stainless steel appliances ie. refrig, dishwasher & oven
a quality s/s cleaner and a clean cloth sould do the trick for most stains, WD-40 also works to remove the stains, works really well, also leaves afilm on the metal to prevent stains from adhering, just dont use paper towells, the tend to leave fibers behind. and also look closely at the s/s there is a GRAIN pattern in the metal just like wood would have a grain!! be sure to wipe in the direction with the grain not against.
Mar 19, 2008 | Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
