Question about Samsung Digimax S730 Digital Camera
My camera turns on then beeps 3 times then shuts off is it broken or is there a reset button?
  • 466 Answers
The three beeps mean that the lens motor is unable to extend the lens assembly.
This could be due to a low battery situation, but the most likely cause is the lens drive train stuck or jammed. You'll find generic instructions on solving some cases of jamming here.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Unfortunately, more serious cases (due to falls, shocks, and most of all, the camera being turned on while some resistance prevents the lens from extending: e.g., if the camera accidentally turns on while in a pocket) require the repair shop.
Posted on Apr 27, 2010
SOURCE:
I turn on my ps3,tv displays message..invalid format... what can cause this,how to fix it?
Hi there, your display needs resetting back to standard resolution, please follow my guide on how to do this -
http://www.fixya.com/support/r6784945-playstation_3_no_display
Thank you for using FixYa
Dec 27, 2010 | Sony Playstation 3 (PS3) Console
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
When i try to turn my camera on it beeps 3 times and shuts off.
It must be the end of the Samsungl camera battery life made this matter ,why not change the Samsung digital camera battery for a try.It is a simple but usual problem.
Jun 02, 2010 | Samsung S860 Digital Camera
I click the on button on polaroid i834 digital camera, then stops
Sounds like the battery is too low. Replace/recharge batteries.
Oct 03, 2009 | Polaroid i834 Digital Camera
Beeps three times and shuts off
The lens is jammed. It requires manually resetting. If you in the U.K I can help you out. email me at kiddo242@hotmail.com
Aug 09, 2009 | Polaroid i631 Digital Camera
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
I turn camera on. Lens comes out. beep 3 times. turns off.
Everytime I try to turn it on, the lens comes out for about a second, the camera beeps 3 times, the lens retracts and the camera shuts off. The battery is completely charged and the camera is only 4 months old. HELPP :(
Jun 17, 2009 | Samsung Digimax S500 Digital Camera
Digital camera starts then shuts down
yeah its broken sorry mate
suggest a new camera
Dec 15, 2008 | Cameras
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
It dont turn on
I had the same problem. Try to turn it on, 3 beeps and then it would shut down. Screen would come on for that time. Also, the lens was stuck open. It wouldn't close.
I twisted the lens (gently) and it appeared stuck. A gentle screw motioned seemed to free it. I hit the power button and it come on, but this time no 3 beeps and shut down. I then turned it off and this time the lens retracted and closed.
So, it appears that if the lens gets stuck open, it has a shut down feature that doesn't allow the camera to go further into its operation modes. I believe this stuck open problem occured on our camera when the batteries went low.
Again, a second of gentle twisting seemed to unstick it and with fresh batteries in, it was able to operate and shut down properly.
As far as batteries, I use the rechargeable Ni-Cad 2500 mA. They last a while.
Blessings to you!
Jun 02, 2007 | Samsung Digimax S500 Digital Camera
Samsung Digimax S730 Digital Camera Logo
632 people viewed this question
Top Samsung Cameras Experts
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Jerry Z
Are you a Samsung Camera Expert? Answer questions, earn points and help others
