Question about KitchenAid KUDS01DJ - Multiple Color Dishwasher
I have a mod KDSU01DJ that will not drain. I've had it all apart, there are no clogs, nothing stuck. I bench tested the motor and the pump, both run ok. It seems like the pump isn't pushing hard enough. Should the motor be running with the pump during the drain cycle. I"m stumped. Thanks.
  • 1 more comment
  • rpeter311 Apr 27, 2010
    OOPS, dyslexia strikes again. Anyway, the drain pump motor (part # AP3133590) does run, should the main motor (part # AP3179651) also be running during the drain cycle or just the pump motor? If it's just the pump motor that runs I think mine must be going bad. Thanks for the help and the quick response.
  • rpeter311 May 05, 2010
    Epilog:I replaced the pump, put it all back together, hit the drain button and still the water just sat there. As it turns out there is a LITTLE check valve in the elbow of the drain hose where it attaches to the drain pump. That hose is smi-transparent and I could see some water moving around in there so I never thought to check that part of the hose. I had taken it apart where it attaches to the extention hose to the sink and found that part was clear too so I ASSumed the hoses were okay. After I took the hose off the dishwasher and tried to blow through it (and couldn't) I saw, embosed on the elbow, DO NOT REMOVE, CHECK VALVE INSIDE
    (I wasn't through, hit the wrong button) anyway..I cleared whatever was blocking the check valve, put it all bact together, AGAIN, and now it works just great. I told all this to an appliance repair man I ran into and he thought I was nuts. He said there was a check valve in the sump but didn't know about the one in the hose. That made me feel better, I found something the expert didn't know about. I now know a whole lot more about dishwashers and my wife is happy. Life is good!
    Thanks for your help, it put me the right track. Rick
  • KitchenAid Master
  • 3,361 Answers
Yes the drain pump motor must be running during the drain cycle.
This manual will help trace your problem.
4317196.pdf
Posted on Apr 27, 2010
Testimonial: "Thanks, that was the info I needed. I'll replace the pump and hope for the best."
  • 1 more comment
  • steve
    steve Apr 27, 2010
    Sorry. The pdf link I posted is not working.
    Cut and paste this link for the manual.
    https://secured.whirlpool.com/Service/Sr...$FILE/4317196.pdf
  • steve
    steve Apr 27, 2010
    BTW your model is KUDS not KDSU
  • steve
    steve Apr 28, 2010
    Only the drain motor runs during the drain cycle.
Holding water
Good Day,
Your washing machine is fully automatic?
the washing cycle is normal?
if yes do the same maybe it will help you.
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, how? remove the cup of your drain pump like a ordinary cup, screw it clock wise or counter clock wise.
Remove drain pump filter and clean it, some hair pins, cotton buds or coins or any small item that coz of clog up.
if your washing machine dont have drain pump ,but fully automatic check the drain motor if running or not? how? open the back cover for top loader washing machine only, select spin cycle and press start to see the drain motor running? the drain motor is like a small box with small wire to pull the lever of the drain to remove water inside, if the motor running or pull the lever of the water pipe but water still inside the washing machine, remove the drain cup or cover and clean it or check if have coin or cloth inside that coz of clog or water stuck,
if the drain pump or drain motor is weak this is will cause and long time draining or totally not running the drain pump or drain motor and its cause of totally stop the cycle of washing machine in rinse time or spin time, because all fully automatic washing machine, after washing cycle the drain pump or drain motor must be on, to remove water before start the next cycle. rinse or spin cycle.
Nov 02, 2013 | Washing Machines
Washer won't spin
Good Day,
My Beko 81241 LW seems to be stuck in the Spin & Drain cycle (it's not actually on though) and the Start symbol is flashing. The time is also displayed (12mins). The door is also locked. Holding the Start...
Good Day,
Oct 30, 2013 | Beko Washing Machines
Washing Machine wont drain, gives empty filter error message
If there was items stuck in your pump/ tubes-you may need to now reset your machine to clear the error and have your machine back up and running.good luck.
Jan 24, 2013 | Samsung WF448AAW 4.5 Cu. Ft. Front Load...
It give me an code F4 and nothing works the fill valves open for a few seconds and then a buzzer gos off and i get the F4 code
F4 is typically related to a drainage problem. If the water is not draining from your dishwasher, verify the following: Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall. Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports. Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced. Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it. There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
Feb 16, 2010 | Whirlpool GSX9885J Top Load Washer
Machine is about 7 years old and gets stuck in one cycle, will not drain. Recieved code CA, LD and OB. Machine is stuck and won't drain!
The OB indicates and out of balance condition has been detected by the motor control.
One thing about the OB error is that the lid must be opened to clear the error and allow the washer to advance to the next part of the cycle. If the lid is not opened to adjust the clothes then the OB error will happen again.
If the OB error was cleared and the OB occurs with an empty load then the motor control has failed.
The drain pump must work. The image below shows how to run a diagnostic test to check the drain pump. Follow the instructions in the image below and check the drain pump operation. If the pump runs and the water does not drain then the sump is clogged. If the pump hums but does not run then the pump needs to be replaced.
http://media.fotki.com/1_p,wkktswgwqtqrbwfxgtqsskgwtqkq,vi/gftrgbbtfxfffgqskfk/1/1303472/5961857/image48348img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Everything works except drain. I have 6 ohms resistance on the drain circuit of the motor. How can I test the control board? Is there some way to bypass it to know everything else is good? mod:DU945PWPQO
Check the following areas to combat this issue further. Use the connector pins on the back of the control to test its operational value.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Jun 21, 2009 | Whirlpool 24 in. GU980SCG Built-in...
My roper dishwasher won't drain
Check the following to address this issue.
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Jun 11, 2009 | Roper 24 in. RUD3000 Built-in Dishwasher
Model # mav7700 AW wont drain
Dear Customer
Please perform the following
Please rate this,Thank u
Dec 16, 2008 | Maytag Washing Machines
Clogged pump on Affinity Washer
Exactly the same problem. Washed a small area rug that appeared to have pretty much disintegrated. Machine would not drain. Got the same e 20 code. Checked the drain hose, and it was fine. Reamed the house drain just to be sure. Drum appears to have drained, but now the motor runs, and no water enters the machine. Both water hoses are flowing. No further error codes. Nada.
Apr 20, 2008 | Frigidaire ATF6000ES Front Load Washer
KitchenAid KUDS01DJ - Multiple Color Dishwasher Logo
369 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
