Question about Sony VAIO Notebook
My Sony Vaio pcg 3C2L's fan is always making horrible rumbling noises, like it is overheated and a ball is running between it. even if i only turn it on for five minutes.
    Sergeant:
    Novelist:
  • 172 Answers
Hi would i suggest is do not turn it on at all, while you can get a cooling pad for you laptop it does not work that well. Please take it to a repair shop inmediately. Sony and HPs tend to overheat a lot and the problem is that the video card on the motherboard goes bad and you will have to buy a replacement is the most expensive part rather than just the fan+labor. I hope this helps.
Posted on Apr 27, 2010
Hi, i had a same problem with my Vaio pcg 3C2L too , all you need to do just call sony and tell them your problem.then they will send a person to your house change a new fan on your computer.
Posted on May 22, 2010
Fixed the fan in a sony vaio pcg-3C2L now keyboard doesnt work
how did you fix the fan?
did you take the computer apart?
you may have inadvertently unplugged the small ribbon cable for the keyboard. i would check that first.
Nov 07, 2012 | Computers & Internet
Sony vaio pcg-71318L overheating
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Aug 30, 2012 | Sony Vaio PCG-71318L
My laptop (sony vaio VGN-CS325J) fan makes a horrible noise
This means that the micro ball-bearings are on their way out if the bearing race smashes then the fan will stop I suggest sourcing a brand new fan and fitting it yourself you might need a star drive look at the profile head of the screws.
http://www.fixya.com/support/r4730725-type_tamperproof_screw_tp3_torx_tri_wing
Make sure that both the mains supply and battery are removed, the fan will be a simple push to clip connection with only 2 wires.
Dec 06, 2010 | Sony VAIO VGN-SZ330P/B Notebook
Hi. I have a Vaio laptop that worked fine. Now it
Is the laptop getting very hot if so then the laptop is turning off because of this. You will need to get it cleaned out around the fan, if you are still getting the same problem after this you could ues one of these USB cooling fan stands. i use one with my acer6530g when i am working with it for hours at one time. hope this helps.
Jul 21, 2010 | Sony Computers & Internet
My Sony Vaio PCG 3C2L will not turn on. It looks
it sounds like a problem with your harddrive. if you have an oem copy of your OS then you could do a chkdsk /r from this. If not then the harddrive will have to be removed and the chkdsk /r done from a data reader from another computer. Hope this helps, leave feedback
Jul 03, 2010 | Sony VAIO Notebook
The fan of my sony vaio model pcg 3c2l stops
Only do this if you feel competent in doing so.
Pulling apart laptops is not for the faint of heart.
If you really must do it there are some
good guides here.
An alternative is to get a can of compressed air used to clean computers. Put the nozzle on and spray it in every hole you can see without putting the nozzle itself inside the laptop.
Do this outside with glasses on.
You may also want to remove the hard drive and ROM drive.
Take a
peek here for more ideas of what is involved.
There are a few are tips for various things in there.
DON'T touch the CPU cooler unless you know what you are doing and have some thermal grease for CPUs to hand.
To make newer laptops last longer between cleaning a good 3 fan cooling pad is suggested.
never use a laptop on soft surfaces as the ventilation can act as a mini vacuum cleaner and encourage dirt build up.
Soft surfaces also block the vents causing fans to run more and burn out sooner.
Hope this gives you the information you need
Bob
Moderator
It would be very decent of you to consider the quality of our experts answers and judge them accordingly as you pass through FixYa.
Thank you
Dec 13, 2009 | Sony VAIO Notebook
Sony VAIO Notebook Logo
1,961 people viewed this question
Top Sony Computers & Internet Experts
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
