Question about GE (PSS26MSRSS) Side by Side Refrigerator
GE SIDE BY SIDE FRIDGE MODEL #GSS25XSRC SS I REPLACED THE EVAPORATE FAN TO FIX HOWLING NOISE AND IT WORKED FOR A COST OF $80 CAN. NOW THE ICE MAKER STOPPED WORKING. EVERY THING IS PLUGGED BACK IN, THE LEVEL SWITCH IS IN THE DOWN POSITION. NOT SURE WHAT WENT WRONG THANKS STRESSED
  • kfhb May 07, 2010
    I have a GE side by side fridge, model #GSS25XSRC SS. Mold has developed quite seriously in the rubber lining and throughout the insides of the fridge. I'm an elderly lady without much strength in my arms and a back that doesn't like leaning over. What is the best way to get rid of the mold? Or Is there a service to clean it out or replace the lining?
  • 35 Answers
SOURCE: GE fridge and dishwasher
For GE Model# GSS25SGRESS
replace the evap fan motor in the freezer..or have it checked
PART# WR60X10185 W/O THERMISTOR
PART# WR60X10074 WITH THERMISTOR
Posted on Mar 02, 2008
SOURCE: GE Side by Side Fridge Problem
could be defrost problem. check frost pattern on evaporator.
Posted on Jul 22, 2008
SOURCE: GE Fridge: PSS26SGPA SS Model
CallMe-
Your "freezer" and "refridgerator" temps are not jumping back to 14 and 44 respectively. When you change temps, they both wait 3-5 seconds before they revert back to a temp reading, not a temp setting.
Does your "freezer" make any loud or thumping noises? If not, do you hear a quiet whisper when both compartment doors are closed?
Solutions could be :
1. Servicing the coolant (might have a small leak)
2. Checking the seal on your freezer compartment (black rubber that meets the metal frame)
3. Your internal cooling fan is not operating and needs replacing (but I think your temps would be significantly higher).
Best of luck.
Posted on Jul 30, 2008
MNTECH
  • 1543 Answers
SOURCE: GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Posted on Aug 04, 2009
  • 11 Answers
SOURCE: GE Fridge - Model #GSH25JFTA CC - is making a howling noise...
Typically this happens when the ice maker is not getting the water pressure it needs to fill the trays. Replace your filter on the ice maker and this should solve your problem.
Posted on Aug 22, 2009
My GE Side by Side Freezer sounds like a Cessna when the fan goes on.
Here is a permanant fix based on a simple design change to address the cause of the howling - ice build up on the evaporator fan cowling:
http://www.deaven.net/~deaven/Make/fix-arctica-howling/index.html
Total cost of solution is less than $5
Aug 08, 2015 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling noise
Check the help link mentioned below:---
Click the link:--
Ice maker is noisy and not making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-is-noisy-and-not-making-ice.html
These will help.
Thanks.
Nov 21, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Model PSC23SGRC SS Serial #RH418861. Refrigerator make a howling noise Dave eci.david@gmail.com
I suggest a defrost with doors open over night, what often happens with this model is that you get an ice build up near the fan which causes an extremly loud noise, very common problem.
Sep 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
My fridge is howling pretty loudly when ever it runs , the howling is coming from behind the ice maker turned the ic e maker off but unit st ill howls what s wrong
Hi, It sounds like the evaporator fan motor is going bad or there is frost building up and hitting the fan blade.
Unplug the refrigerator and remove the rear panel inside the freezer and locate the fan.
You can plug the refrigerator in and see if the fan is making the noise.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 19, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSL25JFR Freezer fan noise.
Replace the fan motor is my guess to cure the noise.
Mar 01, 2017 | GE Profile¿ 42" Built-In Side-by-Side...
FAN MAKING NOISE BECAUSE OF BAD COMP BOARD, PUT UP WITH NOISE OR REPLACE EXPENSIVE BOARD
Sep 12, 2008 | GE GSS25JEM Side by Side Refrigerator
I also had the same problem (gsh25jfta ww). It did that for a couple of months now the coils freeze up and fridge gets warm. Still looking for solution?
Jul 03, 2008 | GE GSS25JFPCC / GSS25JFPWW Side by Side...
Jan 10, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Howling - Which is the correct fix
I think I have the same problem. The unit is also about 2 years old (GSH25KGRBB). I have an extended warranty. They already replaced the controller card. I see it is the exact part number you have mentioned. It seemed to help for awhile but I think it has gotten worse again. The noise is more consistent after they changed the board. Less revving up to "turbo" mode. Howling is a good description. I can hear it now, on the other side of the house. I would change the fan out. I think they did the board first because it probably is easier even if the part cost is higher. I will probably call them back again. This will be the third time. The first time they just changed the little flapper on the ice dispenser. Otherwise the unit cools and runs flawlessly.
Aug 11, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
134 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
