Question about D-Link DKVM-8E KVM Switch
Had a power surge; monitor now reads PASSWORD
Had a power surge; monitor now reads PASSWORD ________
CONSOLE OFF
I don't know the password and can't advance the Port switch.
2 Suggested Answers
SOURCE: Need your help
default is 00000000
Posted on Apr 26, 2010
I cannot connect using serial console port (no signal / data out of serial console port). I don't have IP address of the DS4100B. I don't have its password... How can I reset it to factory default?
I am assuming you will still need console connection to do a password recovery.. however, here is the link to one password recovery doc that may help.
May 10, 2016 | EMC DS-4100B 32 Port 4Gb SAN Switch
How to configure cisco aironet 1131 and how to find the getaway for this router ?
Have you read the quick start and installation guides?
http://www.cisco.com/en/US/products/ps6087/prod_installation_guides_list.html
Yes, the AP should be able to obtain an IP address via DHCP from your
Netopia router.
If this device is used, it may not be setup to aquire things via DHCP,
and you'll probably have to hookup over a console port and do password
recovery.
Cisco's aren't the easiest things to setup, they are more akin to a
box of tools, rather than a single purpose built item, and thus can
do quitealot, but you have to learn how to use the tool first. It will
then let you setup things quite advanced that the single-purpose built
item never imagined, but you have to know how to get there first, not
coast and do the advanced stuff later.
Dec 29, 2013 | Cisco Air-Ap1131G-A-K9 - Aironet 1131G...
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Have secondhand gsm7312 and don't know username or password. How can I factory reset this unit? There is no reset button and I can't enter menus via console cable as it asks for username (not the...
Netgear FSM (and GSM) switches have an RS232 serial console port. Connect to that using Hyperterm, PuTTY, Xterm etc. at 9600-8-N-1, and power up the switch. Early in the boot process, it will give you a choice of normal operation, or the boot menu. Select the boot menu before the time runs out (usually a couple seconds), and one of the options will be to reset the switch configuration, including the password.
Jul 26, 2011 | NetGear ProSafe GSM7312 Ethernet Switch...
I want to know the default ip address of 3com superstack 3 switch 4500 model and the default username and password of the device
Username:monitor Password: monitor---monitor mode, view only manager manager--can change all except security features admin (no password)--sets security features IP: 169.254.100.100 or 169.254.100.99
Jul 18, 2011 | 3Com 4500 24-Port Ethernet Switch
We lost power last night and the wii console is now not powering on
You probably had a power surge. Was the console plugged into a relatively new and reliable power strip, or was it plugged straight into the wall? If you don't have it on a surge protector, power surges can tear apart the internal components of your system. Unfortunately, there is really no easy repair for this. The easiest fix is probably just buying a new system.
May 15, 2011 | Nintendo Wii Console
Recover Password
there are two ways ..try them
first :
In order to set a new password do the following:
Make sure you have a console connection to the Foundry device.
Reset the device using the reset button in front or remove and then reinsert the power cable.
Immediately enter b to go to the boot monitor mode at the time of boot up.
Enter no password in boot monitor mode.
Enter boot system flash primary (or secondary).
At the prompt enter the following commands:
FastIron>enable
FastIron# configure terminal
FastIron(config)# enable super-user-password test
FastIron(config)# write memory
Your new password is now "test".
second... only try if first doesnt work
Set the switch to its default configuration. Make a direct connection to the switch’s console port and power cycle the switch. Immediately after powering on, press <Ctrl><u> to access the system file menu. ]Select <D> to delete all user-defined configuration files. Press <Q> to boot the switch.
hope this solves your problem
Aug 08, 2009 | Foundry Networks Foundry EdgeIron 2402CF...
Can't console cisco catalyst 3500
It's possible that the management port is on another VLAN or is not enabled. Your most reliable bet is to try a serial connection to console in.
Alternatively, there is a procedure that will work even if you don't know the password:
http://www.cisco.com/en/US/docs/switches/lan/catalyst2900xl_3500xl/release12.0_5_wc5/swg/swtrbl.html#wp1028958
Jul 15, 2009 | Cisco Catalyst 2924-XL Enterprise Edition...
Advanced power options settings UPS for blackout buster?software
I have to answer this question with just plain old common sense. Get a new one! This is crazy. If you get a new one, you will have a better, more upto date and something you can handle with todays OS and obviously new batteries. That is too old to mess with. I fixed a powerware once and the plastic was falling apart and the PC board was held together with a rubber band. Not worth it.
Jun 03, 2009 | PK Nextgrid BlackoutBuster B6U2 UPS System
DON`T KNOW HOW TO WAKE UP PSP
It may have been struck with a power surge. Or your battery could be dead
Nov 25, 2008 | Sony PlayStation Portable (PSP) Console
D-Link DKVM-8E KVM Switch Logo
320 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
