Question about Sony PlayStation 2 (PS2) Console
THE SCREEN IS MOVING
WHEN I PRESS THE (ON/STANDBY)/RESET BUTTON, THE SCREEN OF THE TV OR THE VIDEO ON THE TV IS MOVING... IT IS SCROLLING FROM UP TO BOTTOM... WHAT WILL I DO WITH THIS PROBLEM..
    Problem Solver:
  • 4 Answers
It your tv
Posted on Mar 26, 2008
6ya staff
SOURCE:
My bush 40-133fdvd stopped responding to my remote, I thought I’d broke it so I bought another genuine bush remote which surprisingly didn’t work, I read on a thread I’d maybe need to reset my IR sensor by...
Please try the following:
1. Press "Menu" button
2. Type 4711 service menu code
3. Scroll to shipping conditions
4. Press OK this will factory reset this TV
or if this does not work try:
2. Scroll to "Setup"
3. Scroll to "First Time Installation"
both will perform factory reset
if this does not help book a repair with:
http://www.umc-uk.co.uk/fixedcostrepair.php
Apr 22, 2018 | Bush Televison & Video
How do you tune in a sense 51 - 19dvdw tv to channels
First check your aerial.
If other devices such as PVRs or other TVs can receive a signal then the Sense 51-19 should be OK also
Turn on the TV.
Press the "TV/.AV" button until the letters "DVB" (Digital Video Broadcast) appear on top right of screen.
Wait until patterned blue screen is displayed and the message "No Signal" is shown.
Press "SYS MENU" 3 times
"General Menu" should be displayed with Language option in highlight.
Press the "CH+" button once to move the highlight to the "Reset" option.
Press the "TV/TXT-DVB MENU" (this has the letters "SET" engraved on the button itself.
The TV will mute and a sub-menu will be displayed in the top left of screen.
Use the "CH+" or "CH-" to scroll to the desired option.
Cheers
May 23, 2012 | Televison & Video
Philips DVDR7260h
Hello
Disconnect the recorder from power outlet for one minute and reconnect it again. If the recorder still don't operate well, you have to reset it to factory default settings.* Disconnect the recorder from the power outlet. * Press and Hold down the STANDBY/ON button on the front of the recorder whilereconnecting it into the power outlet. * Release the STANDBY/ON button when STARTING appears on the display. * Wait until the recorder's demo starts scrolling; press STANDBY/ON button again to turn ON the recorder. [All information stored in its memory will be erased. The first installation menu will be appeard on the TV screen. OK.
Feb 02, 2012 | Philips Televison & Video
My samsung lcd ..two video channel input mixing problem
ok folks, for all of you with this kind of issue....
Firstly we need to reset the TV to the samsung factory settings, in order to do this we need to enter the engineers menu, you can do this by pressing the following buttons on the remote control while the tv is in standby.
INFO / MENU / MUTE THEN THE POWER BUTTON (NO PAUSES)
When the tv starts up you will then see the engineers menu. Scroll down to i think... number 12 which is RESET then press OK.
The tv will now power down and reset the Eeprom ic.
Turn the tv back on and retune etc.... then try your inputs again. All should then be OK.
Hope this helps everyone.
Please rate with thumbs up
Thanks
Nov 10, 2011 | Samsung LN46A650 46 in. LCD HDTV
Bought this TV used and was told it needed a ballast board. I spoke with the tech that worked on it and was told a supply board as well as possibly needing a new bulb. I've replaced all three with no...
Sir when replacing the bulb you should reset the lamp hour meter. 1. while on the standby mode press "mute" then the numbers 1,8 and 2 in succession, and press the power button.
2. wait until "loading factory" appears on your screen and the service menu is displayed with the lamp life hours. You will see a list of service options.
3. Scroll down to "option" and press "enter". next you will see "reset lamp" where you will press again the "enter" button. good day and best regards.
  • 2 Wait until "Loading Factory" appears on your screen and the service menu is displayed with the Lamp Life Hours. You will see a list of service options.
  • 3 Scroll down to "Option" and press "Enter." Next you will see "Reset Lamp" where you will press again with the "Enter" button.
  • Read more: How to Reset the Lamp Hours on the TV ' eHow.com http://www.ehow.com/how_5535314_reset-lamp-hours-tv.html#ixzz1VIGJC5k7
    Aug 17, 2011 | Samsung HL56A650 56 in. TV
    I want to reset the LG shine 720
    Hello thanks for using FixYa
    To hard
    reset of
    your cell
    Type 1809#*500# & select reset option which restores the factory settings.
    A confirmation screen will appear, select Yes. It it asks security code then enter 0000 it will take some time and your handset will be restored to original settings.
    or try this
    to Reset Default
    From the standby screen, press Menu
    Scroll to and select Settings
    Scroll to and select Reset Settings
    Scroll to and select Master Reset
    Your problem will be solved.
    I hope this solution will helpful 4 u
    Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
    THANKS & Keep Using fixya
    Jan 30, 2011 | LG Shine 720 Cellular Phone
    I have lg su 910 i forget my input password s.n/ 906kphg0179777 plese hhhhelp
    Reset Default
    From the standby screen, press Menu.
    Scroll to and select Settings.
    Scroll to and select Reset Settings.
    Scroll to and select Master Reset.
    Enter Security code, press OK.
    NOTE: The default security code is 0000.
    Clear memory
    Scroll to and select Master Clear.
    Scroll to and select desired option:
    Handset
    Memory Card
    A confirmation screen appears, select Yes.
    Enter security code, then press OK.
    NOTE: By default the security code is 0000.
    Dec 05, 2010 | LG Shine KE970 Cellular Phone
    How do you do a master reset touch screen is not working
    Perform a Master Reset
    1. From the standby screen, press Menu.
    2. Scroll to and select Settings.
    3. Scroll to and select Reset Setting.
    4. Scroll to and select Reset Default.
    5. Scroll to and select Yes.
    6. Enter Security code, press OK.
    Reset Memory
    4. Scroll to and select Clear Memory.
    5. Scroll to and select desired option:
      • Handset Contents
      • Handset Personal info.
      • Memory Card
    6. Scroll to and select Yes.
    7. Enter Security code, press OK.
    May 14, 2010 | LG Xenon GR500 Cell Phone
    Switched from HD tv to AV input tv and there is no picture on screen
    try video reset
    when ps3 is in standby mode(red light)
    press and hold the power button till you hear a second beep.
    standby mode press hold power........"beep"......"beep"..release power button
    Oct 25, 2009 | Sony Playstation 3 (PS3) Console
    I got my new samsung series 5 tv yesterday and had the ps3 working, then it had a green screen and now the tv wont come out of what appears to be standby mode
    unplug the tv for 10 mins to let the tv reset then
    try video reset
    Oct 18, 2009 | Sony Playstation 3 (PS3) Console
    Sony PlayStation 2 (PS2) Console Logo
    29 people viewed this question
    Top Sony Video Game Consoles & Games Experts
    Ekse
    shevantha perera
    Damen Wong
    Damen Wong
    Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
