Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Blade hit the ground and bent. Now getting a growling sound from blade bearing housings and mower stalls after five minutes or so.I did replace the blades...
    Problem Solver:
  • 6 Answers
You must have damaged the hub on the deck if you bent one balde you are lucky disconnect the deck drive belt and see if the mower will stay running with the PTO engaged (I'm sure it will) Next pull the deck then replace the hub where the bent blades or blades where dont screww around with trying to fix the hubs its not worth the tome or missery if something goes wrong those blades are spinning to fast if you should break a shaft that one chunk of steel to be flyin around your yard Hope this helps
Posted on May 02, 2010
  • 2,100 Answers
I have a feeling that the bearings were damaged when they hit. The new blades are ok, but the bearings are growling and I don't know what is causing the engine to shut off. I would pull the deck off, check out the bearings, replace them if needed, just wobble the blade back and forth, it shouldn't move, should be tight, Take off the belt and spin the blade by hand, and see if it growls. It could be the drive pulley bearings that went, check them out too. hope this helps.
Posted on Apr 28, 2010
When I engage to mow, the mower deck has a clanging sound. do I need to change the belt ?
not likely a belt thing. Sounds like a bent blade, bent housing, bent spindle shaft. Perhaps something simple like a piece of metal or a rock jammed up in the housing.
  • Turn the key off and remove it from the machine.
  • Raise the housing up high enough to look everything over. Or maybe I should say to look everything under.
  • Rotate the blades to see where one might be hitting the housing or other object.
The belt usually does not contribute to clanking noises.
Apr 19, 2015 | John Deere L100 Series
Replaced the belt pulley now it sounds like the blade is hitting the sides is it possible I bent the shaft.
Did you run into something which bent the lawnmower frame its self. If the blade is just hitting a little then you might bend the frame out just a little I would have to see it to tell. I have even ground the ends of the blade a sixteenth of an inch off each end to make it a little shorter which will not hurt the operating of the machine. Don't take off too much and make each end equal.
Jun 30, 2014 | Toro Power Lawn Mower
WHY WILL MY BLADE NOT WORK ON MY HUSQVARNA RIDE MOWER AFTER HITTING METAL BAR
Sounds like the large nut on top of the spindle may have loosened up or the splines on the pulley are chewed up. Turn the blade and try to hold the pulley on top. If the blade turns and the pulley doesnt, its one of the two things I just described.
Jun 29, 2014 | Husqvarna Garden
Craftman 42 inch riding mower deck shakes and make noise
sounds like he bent a blade that's when the belt went
Apr 10, 2012 | Garden
When I engage the deck to start cutting a loud noise begins and the tractor does not work. I previously hit a tree root with it's blades engaged. Can you please help? Thanks Danny
Sounds to me like you bent a spindle. Turn the mower off and get under it and see if you can spin the blades. The blades whould spin and not be wobbly. If either one of the blades are wobbly then you'll need to replace the spindle.
Also check to make the blade belt hasn't come off or is not destroyed.
Aug 01, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Vibrations when the cutting head is lowered . Sounds like one of the blades is hitting the cover. Especially noticeable below a setting of 5. Three cutting blades. There is no noticeable loss of cutting...
Sounds like a bent blade to me. Can you determine where or which side the noise is coming from? For safety, I would replace all the blades. I once ran over my son's baseball while mowing and bent the housing and that caused the blade to hit the side of the deck. I simply bent the housing back with a few hits of a hammer and back to mowing I went.
Jul 04, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Husqvana LTH 2038 model, blade is bent so bought new ones, when i tried to put on the new ones the right hand side one hits the deck. What could it be (checked the blades they are the right ones)
Probably bent jack shaft or bearing. Or the deck bent, where the bearing is mounted. It is possible but probably just jackshaft. Or when you put the blade on it got hung on the part that go's in the center of blade and made the blade sit crooked. Thats what I do.
Jan 31, 2011 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Cuts uneven, lawn looks terrible. Missing half
Are your blades upside down? Mower deck level?Proper air pressure all 4 tires?Correct blades for the diameter of cut? Deck bent? Deck hangers bent?
May 28, 2010 | Garden
After hitting a low bearing tree stump with my troy bilt 6.75 push mower it bent the blade and now refuses to start. How do i fix it?
You will need to replace the key under the flywheel because it probably sheared when you hit the stump and you will need to replace the bent blade before starting the mower again.
I hope this helped
Please Rate Me
May 22, 2010 | Garden
Sounds like a blade is hitting something on my Cub Cadet LT 1042.
with tractor off and key in pocket check blade for straightness if straight then check by moving it up down if loose check retaining nut if nut tight then possible mandrel bearing burnt or shaft bent also check the mandrels are bolted correctly to deck lastly but least likely is a bent deck
May 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
181 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
