Question about Zoom X6 (5590) DSL Modem (55900003)
Trying to hook my Wii up wirelessly,
I had it hooked up to this same router before and it was working fine, had my ISP up my memory to 1 g and it kicked me off, can't get it to work now. My router is in the same place it was before
  • 476 Answers
Sounds to me like you need to reset your ip addresss or reset the modem and reload the informtion for the user to connect to the wii again
Posted on Apr 29, 2010
Can't get internet to work with dir-615 router for more than a day or two at a time
If you have more than one device hooked up to the router, when the problem occurs try pinging another device. If you are able to then the router is working fine and most likely the modem is flaky and needs to be replaced. The modem supplies the internet connection, the router just applies NAT so that more than one device and use your public IP address. If this turns out to be the issue make sure you contact your ISP for any special instructions. For instances Comcast requires the MAC address located on the bottom or back of the modem in order for your connection to work, other ISP use proxy settings. Century Link has no requirements.
Jan 22, 2012 | D-Link DIR-615 Wireless Router
I just signed up for netflix and am trying to hook it up to my wii to watch movies. The wii is properly connected and hooked up, and we have a wireless internet connection in my home, however when i go to...
Error code 51030 means you Wii is unable to connect to your wireless network.
Try unplugging your modem and wireless router, then plugging them back in after a couple minutes.
While you're waiting for your modem and router, delete your network setting from your Wii, and set them back up once your router and modem are back up.
Your wireless router's setting might have changed and your Wii might not be able to properly connect.
May 08, 2011 | Nintendo Wii Console
We moved and when everything was hooked up i cant get a connection from my linksys wireless router to my laptop
Ok - hook the power to the Linksys - then RESET - the folded out paper clip will work. Once RESET - hook it up to your ISP provided MODEM [ You must have this service to get on the web] now unplug the Modem provided by your ISP or provider - and unplug the router.
WAIT
15 seconds - then
hook up the MODEM from the provider - then hook up the router - then restart the laptop - if wired it will need to be plugged in - if wireless - run your 'search for a wireless signal and you should have it.
Thanks
Gary @ Fix Ya
Sep 06, 2010 | Linksys WRT160N Wireless Router
EROR CODE 52032
Try this - power off your router. If for any reason this doesn't work try powering down your PC as a precaution.
1 - power down the router - when it reboots it will work.
Best of it
Gary
Jun 08, 2010 | Nintendo Wii Console
Trying to hook up my wii to the internet via Intellinet 523431
Take a look at this site and you may find a solution to your problem there. I think you need to first check your firewall and security settings also. WiiErrorCodes.com.
Jun 03, 2010 | Linksys WRT160N Wireless Router
Im trying to hook up my brand new wireless router my mother go hers hooked up but it wont hook up to mine can I get some help
wireless router always comes with an installer cd..do you already installed it??if not try to install it if you need further help just contact me here in fixya...
Feb 06, 2010 | NetGear WGR614 Wireless Router
Trying to run wii systems update through the new BT home hub connections fine but I get an error code of 32004 can you help. Many thanks
Error Code: 32004Please check the following:
  1. Satellite Internet often causes this Error Code. You must have a cable or DSL internet connection. Other connection types, such as dial-up and satellite, are typically not compatible. Contact your Internet Service Provider if you are not sure what type of internet connection you have.
  2. Ours servers may be trying to handle an unusually high amount of traffic (especially if a new Wii update is available). Please wait a few hours and try the connection again later.
  3. Does your internet service provider (ISP) require that you log in whenever you wish to use the internet? If so, your ISP may not be compatible with the Wii console. Please contact your ISP for additional information.
If you are still unable to connect, and have waited a few hours, please try the following:
How are you attempting to connect your Wii console online?
    Wireless Router:
  1. Adjust the Wii's manual settings. Click here for more information.
  2. Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  3. If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  4. Try temporarily disabling your router's firewall.* Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
Nov 12, 2009 | Nintendo Wii Console
PC works fine with Linksys USB card, but laptop's NetGear won't.
It looks like you are either using TKIP or AES just put the wireless to use MIXED and it will solve your problem.
Mar 19, 2009 | Linksys Wireless-G WRT54G Router
Does the Wireless G Plus MIMO work with a Cable ISP?
sometimes when you unplug the modem for a while it resets all the settings. if you have a login and password for your isp you will need to log into the router and re-enter the login info to access the isp
Feb 05, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Can't get a wireless router to work with a speedstream 4200
This may actually be an issue with your ISP. There is a good possiblity that your ISP has bound your connection to the MAC address of the network card on your computer. This is a common occurance which is why router manufacturers give you the option of having your router clone your computer's MAC address. Go into your router's management an perform the clone, sorry I cannot give you more details but I don't know the specific model of your Belkin router.
Jan 05, 2009 | Siemens SpeedStream 4200 (13A4200001)...
Zoom X6 (5590) DSL Modem (55900003) Logo
82 people viewed this question
Top Zoom Computers & Internet Experts
Prashant M
Prashant M
micky dee
Are you a Zoom Computer and Internet Expert? Answer questions, earn points and help others
