Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
I have a riding mower and it runs but lack power
I have a riding mower and it runs but lack power doesnt knock are smoke what could b the problem (21hp bs engine)
  • 86 Answers
If it's a 2 cylinder (should be) 1 spark plug is fouled out...rule-o-thumb...replace both...that's step 1...
Posted on Apr 28, 2010
Just got used john deere riding mower model L118 with briggs 22 hp v-twin,runs rough and spits back through carb
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Mar 07, 2017 | John Deere Garden
I have a same lazer 110 1988 tractor . There is a lot of black smoke and lack of power what could it be .pat
Stuck Choke probably if it is black smoke or it could be a stuck carb float, black smoke usually indicates way to much fuel
Mar 29, 2015 | Garden
Ign timing 16.5 b/s motor mtd ride on. or cyl has fuel in it on cold start.ok most times on hot run ,can still play up at times
You cannot alter the ignition timing, it is set by the ignition unit and the flywheek key, if it has sheared the key it will knock the timing out, if the valve clearances are not correct the auto deco valve in the engine will not work and will increase the compression to the point where the starter motor cannot crank the egine over.
Mar 29, 2012 | Garden
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a Simplicity model 1692762 with a 16hp Briggs and Stratton. The mower blew large plume of white smoke three times while cutting grass over a period of 10 minutes. Engine seemed to lose some power...
I suspect an internal engine issue such as a valve, the white smoke was oil and it could mean a bent, burned valve or damaged valve seat causing the valve stem seal to leak allowing the engine to **** some oil and burn it (the white smoke) and now you lack compression. It is less likely but possible the oil was overfilled and you "lipped" the piston which causes the compression to drop. check the compression, 100-120 is normal, less than that means bad internal parts.
May 27, 2010 | Garden
Mower smoking and running rough
Check the gas you put in, it sounds like it had water in it.
Apr 26, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Stalls when hot
it is overheating. first thing to try is ****** the timing, to run cooler, as you have just replaced the points.-plz rate -bozcro
Sep 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My lawn tractor is losing power. its smoking black smoke and the smoke burns your eyes. its did it off n on the last few cuttings. today i had to stop mowing. it almost completely quite running.
First thing to do is change the oil. This should help but does sound like the mower is burning oil do to worn oil piston rings
Jul 10, 2009 | Garden
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
427 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
