Question about Kenmore 74602 Gas Dryer
Kenmore gas dryer model 11070812990
The baffle came off my dryer how do you get to the drum to put the srew back on
Take a flat-blade screw driver and stick it in the seam between the top cover and front panel at one corner and pry up. The top panel will pop up from the catch - then do the same for the other front corner.
You can then tilt the top up towards the back of the dryer because there are hinges in the back. Spin the drum to where the holes for the baffle are and screw the baffle back on. If you are missing the screws, they probably fell to the bottom inside.
You can take off the front by unscrewing the two screws that hold the top of the front panel to the outside panels. Once those are off, just lift the front panel straight up and pull away. There are two holders towards the bottom that the front panel slides into.
Once the front is off you should be able to find the screws below.
Good luck. . .
Posted on May 22, 2008
6ya staff
SOURCE:
Kenmore elite steam dryer replacing a baffle
Remove the top and you will be able to see the side of the drum- rotate it until you expose the screws to the loose baffle.(tighten them all while you are in there) Drum Baffle WPW10112972
Jul 09, 2016 | Kenmore Dryers
How to tighten dryer baffle on HE5 electric dryer?
The dryer baffle mounting screws are located around the outside perimeter of the drum. You will need to remove the top panel of the dryer to access them. The panel comes off by locating and removing the three screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off. CAUTION: Make sure you UNPLUG the dryer prior to servicing. You should be able to manually rotate the drum to get to all the bolts you need to tighten.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Apr 28, 2011 | Kenmore HE5 Electric Dryer
How do you clean out the baffles filled with lint in the Whirlpool Duet dryer?
To remove the dryer drum baffles on a Whirlpool Duet, follow these steps:
1. UNPLUG the dryer.
2. Remove the top panel of the appliance by removing the screws that hold the panel in place in the rear of the dryer. With the screws removed, the panel will slide back, then lift off.
3. Locate the bolts that hold the baffles in place on the outside perimeter of the drum. There should be 2 for each one.
4. Remove the screws for the baffle and it will come off.
HELPFUL HINTS:
1. Remove ONE baffle at a time so you can use the remaining baffles to turn the drum manually.
2. Drum rotates in a clockwise direction.
3. When removing or reinstalling each baffle, duct taping it place will keep it from flipping around when you get to the last bolt holding it in place. It will also keep it from dropping in the drum when removing, and help you hold it in place to reinstalling.
If you have any questions, please let me know. I hope this helps you.
Feb 07, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My kenmore model 11070812990 gas dryer won't heat. I have removed it to the garage so I can work on it. I have the front, back, and top off, Have determined the ignitor is working, what should I be looking...
HOW DID YOU DETERMINED THE IGNITOR WORKS? DID IT GLOWS REALLY RED? IF IT DID, MEANS YOU HAVE GOOD FUSE AND YOU SHOULD CHECK THE RADIANT SENSOR(NEXT TO IGNITOR) AND THE COILS.IF THE IGNITOR DID NOT GLOW AT ALL, THEN YOU HAVE A BROKEN FUSE. IT IS LOCATED IN THE BACK. ABOUT AN INCH LONG AND IT'S NARROW. CHECK FOR CONTINUITY. OPEN MEANS IT'S BAD. OHM READING MEANS GOOD.
[email protected] OR 714-334-1998. I CAN WALK YOU THROUGH PROCESS
Jan 14, 2010 | Kenmore Dryers
HOW DO I TIGHTENED UP A LOOSE BAFFLE IN MY GAS DRYER
if you have the model with the lint filter on top,remove the 2 lint filter screws,pull the top toward you and up and your in-mike
Jun 01, 2009 | Kenmore Dryers
I have a Kenmore 70 Series gas dryer, model 76712691. The dryer has 3 plastic ''tumblers'' inside the dryer, to help the clothes tumble. Two of the tumblers have fallen off inside, leaving big holes inside...
Pull the dryer away from the wall, there is no bottom on the dryer, so the screws should be on the floor.
You can then pop the lid up from the front and fold it back. When you do, you will see the drum. Roll the drum around until you see the holes and reattach the tumblers.
You can also access the drum from below. Tip the dryer on its back and you can see the drum from the bottom.
Good luck.
Regards,
May 15, 2009 | Kenmore Dryers
Clothes roll into a ball on kenmore gas dryer #11062202101
Just get the filter out and remove the 2 phillips screw init's housing on top. Then use a putty knife to press against the spring clips that hold down the top Then just roll the drum around to the top where the holes are to reattach the baffle, get some screws and put it back.87656db.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 15, 2008 | Kenmore 63942 Dryer
SOMETHING stuck inside the dryer body - something like a coin... let me knwo
ok here is the best way to describe it you will need to get around the back there are two torks screws remove them and slide the top panel back to you ..OH I FORGOT unplug the machine first !!!....Ok now with the top off you will see the drum.. slowly hand rotate it until you see some screws that are lined up with the baffles inside the drum You will need to remove just a few screws on one side (the baffle that has the coins) dont take them all out or the baffle will fall inside the drum and it will be a pain to get back on9u will need 2 people) and that should do it you will need to rotate the drum around until the correct baffle ...ie ..the one with the coins in on top at the 12 o'clock position.. let me know if this works our for you
Feb 16, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 74602 Gas Dryer Logo
233 people viewed this question
Top Kenmore Dryers Experts
Marvin
Marvin
jimorris77
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
