Question about Audiovox ACD-16 CD Player
Can not power up my cd player, Help Please...
Can not power up my ACD- 16 rampage. I hooked it up correctly and it even powered up the first time, I mapped the connection, but, when I hooked it up the second time I blew fuses. I now replaced all the fuses in the car and stereo, but cannot get the stereo to power up. The car wires I am not using are the light on-signal and radio switched power wires. Maybe hooking them up to something starts the current I thought, but the other wires are live, plus, there is no available wires on the cd player and its manual states the required wires. What do I do?
3 Suggested Answers
SOURCE: Rampage
I found an owners manual (free) on line for an ACD-21. It has pics so you can see if
it is close enough to the one you are looking for. Here is the link.
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=277026&langId=-1
Posted on Jan 11, 2008
SOURCE: owner's manual info for rampage acd-12 car stereo
You will get your owner's manual in the following link.
http://www.retrevo.com/s/Audiovox-ACD-12-Car-Receivers-review-manual/id/362ci673/t/1-2/
Hope it helps,
~regards,
Jegan
Posted on Jun 03, 2009
Cd player chevy aftermarket
Find a test light and probe your wires you are trying to hook into. You should have one that stays hot, or has power all of the time, and one that only has power when the key is in the on or acc position. Hook the new radio memory power to the one that is hot all of the time and the main power to the one that only has power when the key is on.
Apr 24, 2013 | 2006 Chevrolet Impala
I provided 12v from car the security red light blinks, but when I attach face plate the stereo is dead?
do you have power going to both the yellow and red wires????????
yellow is constant power and red is switched power (ignition).
May 31, 2010 | Audiovox ACD-22 CD Player
Power Acoustik PWM-16 Equalizer Help
You should be able to use your RCA output (Line Out) from your Pioneer to the input of your PWM-16. Then take the PMW output to an amplifier and then to your speakers. Your EQ only uses RCA's so an amplifier after
it would really bring the sound to life. The amp need not be huge as you have an output for subs also. You could try a line converter to change the RCA lines to speaker wire connections. Not sure if the output would be enough to power a speaker but it's worth a try.
Sep 28, 2009 | Power Acoustik PWM-16 Car Audio Amplifier
Owner's manual info for rampage acd-12 car stereo
Hope it helps,
~regards,
Jegan
Jun 03, 2009 | Audiovox ACD-12 CD Player
Sony car cd player help!
Run a temporary direct power line to battery and see if it will turn on
Aug 08, 2008 | Sony Car Audio & Video
Kenwood kcd-mp335 cd player
You might have...my best bet would be on the memory wire not being shot solid 12 volts. There are 2 wires meant for 12 volts the red one which has 12 volts on it when the car is turned on only. And the yellow wire which should be at 12 volts all the time. If you have power at the Yellow wire at all times then you might have a deeper issue. I hope this will fix it.
-Andrew Hawkins
Mar 14, 2008 | Kenwood KDC-MP335 CD Player
Rampage
Jan 10, 2008 | Car Audio & Video
I am trying to re-install ACD vrsion 7 which I bought some time ago.
check if it is still in the recycle bin, or you try a system restore if you can not restore then you need to install using the cd of this ACD system
Dec 19, 2007 | ACDSystems ACD Systems 7.0 Powerpack for...
TOC Reading...
According to rep. at Tascam, laser is weak or dead. If you are electronically/mecahically inclined, you can replace the drive mechanism (sort of like aCD-RW drive in a computer, but this has flex-circuit cables going to it for power, signal, and control which are relatively delicate compared to the cables in a computer). Parts Dept @ 323-726-0303 ex.840 can supply you
with your needs.
Nov 08, 2007 | Tascam CC-222MKII CD-RW Cassette Combo "...
JVC KD-SX770
Per manual, you can lock a cd in by pressing and holding the power and cd button for moer than 2 secondsthe cd cannot be ejected. if acd is inserted upside down, please -eject appears.
May 18, 2007 | JVC KD-SX770 CD Player
Audiovox ACD-16 CD Player Logo
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
