Question about Brother EM-530 Typewriter
Daisy wheel - cannot type @ sign
Can you help? we have a daisywheel but when we use the shift key the @ sign does not show - we get " (quotation marks) instead
  • Anonymous Jun 03, 2008
    Our typewriter is virtually brand new - it does the same thing... types " when we want @
  • Brother Master
  • 3,594 Answers
Either you have a special printwheel or the spoke on the printwheel is broken or bent try a new printwheel.
DickyO
Posted on Apr 01, 2008
When I push the letters, wrong characters are showing up.
This is a daisy wheel typewriter. Either:
1. The daisywheel is for a different model.
2. The daisywheel is inserted incorrectly, IE upside-down, or if it is in a cartridge the wheel is in the wrong position when the cartridge is inserted. It might have had a little stop in it to prevent this that has worn out. You might be able to move it around to the right position by aligning that stop before inserting the cartridge.
3. If you can still buy those daisywheels, get a new one... maybe Ebay.
Jan 04, 2016 | Olympia Supertype 330 Typewriter
When i press a key a different letter appears
First tun it off and on. If no help, Make sure ribbon is not cuaght up in the daisy wheel. Daisy wheel petals may be bent. Change the Daisy wheel. Possibility you have
setting for language.
Feb 23, 2015 | Nakajima AX-150 Typewriter
During typing, daisywheel spontaneously readjusts itself and then the machine beeps and will not continue. Will it be expensive to fix? Ballpark cost?
Daisy wheel is kind of old school nowadays, you might have to go to a office supply store like staples etc, to possibly get it fixed
Feb 11, 2015 | Swintec 2600 Typewriter
Can a IBM wheelriter 6 repair when the G andH will not work
Replace the Daisy wheel cartridge, pull back on the small red top lever and it should rotate the print hammer back exposing the Daisy wheel cartridge, lift out and replace with new one, push the print hammer back forward till it latches and captures the new daisywheel. Turn unit on and let it initialize, try typing, it should be OK. Examine old daisy wheel you will find the G and H segments are probably missing.
Nov 21, 2014 | IBM Wheelwriter 6 Typewriter
How do I insert the daisy wheel on my Swintec 2416 DM typewriter?
Remove the ribbon, then remove the daisywheel, reinsert daisywheel, replace ribbon and it should work.
Jul 01, 2014 | Swintec Office Equipment & Supplies
How i can shift to arabic
You have to buy an Arabic printwheel and install it.
To insert the daisywheel:
1. Open the top cover.
2. Pull the lever toward you to release the daisy wheel lock.
3. Remove the cassette daisy wheel by pulling it out of the machine by the protruding "ear" on the top right.
4. Insert the desired cassette daisy wheel into the slot and press down gently.
5. Slide the lever back to its original position to lock the cassette daisy wheel into place. Make sure to press the lever firmly.
6. Close the top cover.
7. Press and hold the CODE key. While holding CODE press the Q key, this will move the carrier to the previous position.
Sep 11, 2013 | Brother SX-4000 Typewriter
WE CHANGED THE DAISY WHEEL IN OUR MACHINE & WHEN YOU TYPE IT JUMPS SPACES & TYPES THE WRONG LETTERS
First, be sure you are using a Brother compatible daisywheel. Some other manufactures' daisywheels "look" the same but the charters are in different order, so they will not function properly.
After changing the daisywheel you need to d a reset. Hold down CODE and press "Q" the carriage will do a little dance and your machine should be good to go!
Dec 23, 2010 | Brother SX-4000 Typewriter
When i install the new daisy wheel i cant get it set to type the correct letters
Dec 22, 2010 | Brother GX-6750 Typewriter
Brother ML100 Typewriter:All of the sudden, it just won't type. It seems the 'hammer' doesn't hit the daisywheel. We've replaced the daisywheel, corrective tape, ribbon and still it goes through the...
Ok,there could be two possibilities ,1, The daisy wheel may not be seated in properly. Of course I assume that the print side of the daisy wheel is facing the platen and that when the typewriter is switched on the print unit makes its customary re-setting motion and that the daisy wheel spins around at the same time. if this does not happen make sure that the lock-in lever for the daisy wheel is pushed home.. I am sure that you do all these elementary things so the only other possibility is the the hammer seleniod is not fully functioning and would have to be re-placed....Good luck!
Nov 14, 2007 | Office Equipment & Supplies
How to get the @ sign
You should just have to hold the shift key down and type the @
Aug 10, 2007 | Brother ML-100 Typewriter
Brother EM-530 Typewriter Logo
54 people viewed this question
CheckitRight
CheckitRight
Soulvisitor
Soulvisitor
Ron Dufek
Ron Dufek
