Question about Frigidaire 30" Self-Cleaning Slide-In Gas Range - White
Gas oven doesnt work
My gas oven doesnt work. when i turn it on, i smell gas but the oven doesnt get hot
  • Frigidaire Master
  • 3,051 Answers
Hello there:
Gas oven won't work, Ignitor is glowing Everything in the circuit must have continuity for the oven to fire up. What if the ignitor glows but the oven will still not come on? If the ignitor is glowing that would mean you have a circuit. Solution: Replace the ignitor, even if it comes on. Why? Because 99% of the time the ignitor is weak. When it is working fine it should be so bright you cannot look at it for long. If it is a mellow orange color it is bad, replace it. The only way the gas oven valve would be bad is if it is open and has no continuity. That goes for the control as well. Check out this simple diagram of how a basic gas range operates. gas oven doesnt work - glowbar.jpg oven ignitor An ignitor must draw at least 3.5 amps or that safety valve will not open up and release the gas: . Click on image to see it in motion
Posted on Apr 28, 2010
  • Michael Thomas
    Michael Thomas Apr 28, 2010
    Hello there here is some more information for you
    A burner doesn't work
    The most common problem for gas surface burners is
    that they get gas but don't light. This is generally caused by dirt or
    grease splatters on the burner itself. Residential-grade range/stove
    burners are round and have small holes around their perimeter to allow
    gas to flow out and create a round flame. The gas coming from these
    holes is often ignited by a small vertical row of holes on the side of
    the burner. If these vertical holes are clogged or obstructed, the gas
    can't ignite.
    The solution is to clean the burners thoroughly.
    Use a toothpick to clear the small vertical holes, then allow the burner
    to dry completely and try lighting it again. If it doesn't light
    immediately, either repeat the procedure or call a qualified appliance
    repair technician.
    It won't bake or broil
    If neither the oven nor the broiler heats, but the
    range burners still work, the clock may be set for a timed or
    self-cleaning cycle. Check to be sure the clock buttons and knobs are
    set properly. If your clock has a knob that says "push for man(ual),"
    push the knob in and try heating the oven and broiler again. If they
    still don't work properly, you probably have a defect in the thermostat,
    selector switch, or common wiring.
    Note… If the oven doesn't have a separate
    bake/broil/etc. selector switch, the problem is often with the
    thermostat. It's not easy to check the selector switch or thermostat for
    proper operation. If you suspect a problem with either of these, call a
    qualified appliance repair technician.
Oven takes too long to start or not at all
is this electric or gas? if it is gas and a newer model it has an ignitor that heats up that will then ignite the gas burner, the ignitor is bad or you may need to inspect and clean the gas ports on the burner as they can get cloged up over time, try the inspection and cleaning first. If it doesnt appear to be cloged then turn on the oven and watch the ignitor, if it doesnt heat up to be white hot then it is bad or going bad and should be replaced. if it is electric check to see if the heating element is working by turning the oven on and watch for it to glow red hot, if it doesnt then it will need to be replaced.
Sep 08, 2014 | Ovens
I have a kenmore electric oven, which is 13 years old. i used it two weeks ago, and it was fine. now when i turn on the oven, there is a strong gas smell coming from it that not only envelopes the...
Hello Cheryl Davis...
Your posting came in UNDER A DUAL FUEL
ELECTRIC - GAS combination...
If you are smelling gas... you are in immediate DANGER.
PLEASE turn OFF the gas at the wall...
The gas is not only toxic it is highly EXPLOSIVE ...
Do not experiment with your health & safety...!!
GAS appliances are very dangerous...
A single HOT-SURFACE ignition failure
should have caused the GAS to not flow...
If it is flowing ... you are in EXTREME DANGER.
Aug 12, 2017 | Whirlpool SF315 Dual Fuel (Electric and...
Won't get hot, smells like gas
Most of these new fangled gas stove feature a silicone carbide ignitor to light the oven. Older stoves used a standing pilot light. As silicone carbide ignitor age a little they tend to get weak and fail to open the gas safety vave sufficiently enough for ignition. Take a look
Jul 06, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Gas stove When I turn on the oven, I smell gas,
This is more than likely the igniter to be sure you will need to do an amp draw on the igniter. To do this watch the video on troubleshooting a gas oven at www.appliancehelponline.com/servicemanual.html
Mar 12, 2010 | Stoves Ovens
Oven ingniter lights , smell gas but oven doesnt turn on
Hello- Ignitors may 'light' yet not reach proper resistance and temperature, causing improper gas flow past valve. If resistance is below 4 ohms, ignitor is bad. Part is 40-75$ at local app. parts store. Fairly easy to replace. Hope this helps. -Thanks- ED
Mar 01, 2010 | Kenmore 71513 Gas Kitchen Range
My Amana gas oven won't heat up gas smell strong
Sounds like a sticking gas valve or a defective hot surface igniter. Open the broiler drawer or remove the bottom cover in the oven compartment. The oven usually has a hot surface igniter or a spark igniter. Turn on the oven and watch for the hot surface igniter to start glowing. It should glow very bright. Once it is glowing the burner gas should come on. If you hear the gas come on it should light right away. If there is any delay shut off the oven and stay back. Let the gas clear out then inspect the area near the igniter and make sure the burner is not plugged(the little holes may have debris in them). If you turn on the oven and the igniter comes,glows brightly,no gas is heard but you can smell gas it is either a blocked burner orfice/assembly or sticking gas control valve. Try giving the burner and gas control valve a tap and see if it comes on. If you tap the control valve and it starts working then shut of the oven and try it several times. If it starts to come on and off now you may have cleared whatever debris was causing the problem. If it does it again then it could be the control valve or a weak hot surface igniter. The igniter can be tested with a ohm meter. Most of the time when I get this complaint it is the oven control valve that is sticking. Be very careful when doing these procedures....gas can build up in the oven compartment very quicky and flash if ignited. Always have the gas shut off valve at the back of the range within reach and the electrical outlet in case you need to unplug it.
Sep 13, 2009 | Magic Chef 9122 Gas Single Oven
Oven doesn't heat up
Hi, Even though your igniter is glowing it's bad..A igniter should glow brillient yellow for it to be able to light the gas...basically whats happening in your case is although the igniter is drawing the correct amps to open the gas valve it is not getting hot enough quick enough to light it..change the igniter and you should be good to go. Good Luck!!! Mike
Aug 17, 2009 | Ovens
How to light Oven Pilot for Magic Chef stove 31000 PAW
There is a cover plate that has two screws holding it down. Inspect the pilot area and you will see a hot surface igniter sitting right next to it.. That is what lights pilot and then the pilot lights main burner. You need a new igniter. Also do not touch any part of the hot surface igniter as human oil will shorten the life of part.
Nov 25, 2008 | GE JGRP17 Gas Single Oven
Ge gas oven with electronic ignition
yea sounds like you have a bad oven ignitor, tell tale signs are not heating past warm, smells gas, too long to cook, popping noises while cooking. Id replace that ignitor. Although it might appear to "glow" not glowing strong enough
Feb 28, 2008 | Kitchen Ranges
Frigidaire 30" Self-Cleaning Slide-In Gas Range - White Logo
249 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
