Question about Ryobi Garden
Tiller starts but rotor blades wont turn - Ryobi Garden
4 Suggested Answers
  • 4 Answers
SOURCE: Troy Bilt Rotor tiller, won't start
lac spark plug on motor pull cord if no spark take the pull start cover off and sand rust off fly wheel
Posted on May 05, 2009
  • 22 Answers
SOURCE: I have a troy-built rear blade tiller. It starts
Your belt is likely slipping. To adjust the belts, slide the block down that the roller on the forward/reverse lever uses to lock the tiller into forward. Use a 9/16" wrench to loosen the bolt on the backside of the block, then slide the block down a bit and retighten the bolt. If it's not the belt slipping, you've got transmission gear or bearing problems that could be costly to repair. I hope it's the simple adjustment.
Posted on Jun 16, 2009
SOURCE: motor run but blades don't
mine is doing the same thing
Posted on Oct 06, 2009
Do you have or can you find Agrator Rototiller Gears ?
Agristore USA ' Replacement Parts ' Agrator Tiller Blades
www.agristoreusa.com/collections/agrator-tiller-blades
Tiller Blade for AGRATOR D-UR $6.75 · Tiller Blade for AGRATOR D-UR $6.75 · TillerBlade for AGRATOR D-UR $8.50 · Tiller Blade for AGRATOR D-UR $8.50.
Sep 25, 2015 | Garden
Why won't my rotor tiller stay running after starting Its a briggs and stratton
95% of run ability problems are carb related. It needs to be disassembled and cleaned. Do you leave gas in it at the end of season,if yes always drain the tank and let it run till it stops next time before storage. Good luck
Jul 08, 2014 | Husqvarna McCulloch Garden Tiller, 5hp...
Maxtra tiller
Transmission needs grease. Most tillers have a plug on the tine base for checking/ adding "dope" to them. Could be gears are bound up,
Apr 20, 2014 | Garden
Tiller wont go in reverce belt smokes a little then dies .
-Are you talking about hands held rotor tiller...? If so Check belt tensioner. Or it could be off from the tensioner.
Good luck
Mai
Feb 20, 2014 | John Deere Garden
Blades wont rotate
Check for a broken pin or loose grub screw in the drive area of the box.
Mar 11, 2013 | Troy Bilt Tiller/Edger 26cc, Model No....
I have a Mantis Tiller. It starts but has no torq...
possibly the (muffler) is plugged with carbon. happens when too much oil is used
May 19, 2010 | Mantis Tiller
I have a troy-built rear blade tiller. It starts fine but when the blades hit the ground they stop turning.
Jun 15, 2009 | Troy-Bilt Garden
Motor run but blades don't
May 14, 2009 | Mantis Tiller
May 05, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Replacing lawnmower blades on 38 inch yardman
Need to plug spark plug [for safty]. Install 2x4 blocking between blade and chassy,use clamps.Coat threaded area with wd 40 and torque in clockwise position,not counterclockwise to remove old blade and install new turning bolt counterclockwise or [unscrewing direction].
Please rate. Thanks jj505
Mar 28, 2009 | Mtd Products Yard Machines 158CC Tiller
Garden Logo
48 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
