Question about HP LaserJet 1320 Printer
Printer gets a feeding error when paper is exiting the printer. Paper is about half to two thirds out of the printer. Second page is left in unit and mut be manually removed. Neither paper is wrinkled. If you help the paper out, the printer works correctly.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Check if your are using different paper from the one that you have told to the printer that has
Posted on May 01, 2010
Paper wont feed
Paper not feeding in all-in-one printer - Kodak
support.en.kodak.com/.../paper-not-feeding-in-all-in-one-printer
KodakPaper not feeding in all-in-one printer. Published 10/19/2010 04:38 PM ' Updated 09/23/2014 01:38 PM ' Answer ID 19640. What should I do if the paper does ...
Basic troubleshooting - Kodak
resources.kodak.com/support/shtml/en/manuals/.../urg01238c11s1.shtml
KODAK ESP Office 2100 Series All-in-One Printers - Extended User Guide ... If you experience an error with your printer, restarting your printer will ... For wireless connectivity issues, go to www.kodak.com/go/inkjetnetworking. Carriage ... If thepaper is not stacking properly in the output tray, remove the pages as they exit.
[Solved] Kodak ESP Printer Paper Jam - YouTube
? 20:50
https://www.youtube.com/watch?v=jpkitdHmkuc
Aug 15, 2014 - Uploaded by Sabretooth Barnacle
This is probably a common issue amongst all Kodak Printers. ...thanks for the video, these same instructions worked on theKodak 2150! ... What do you thinkthe pproblem is, Kodak offered me another one for ... the printer realises they don't match so rejects the paper until you feed in the size it's expecting.
Paper won't feed on kodak 2150 printer - Fixya
Dec 21, 2015 | Kodak ESP Office 2150 All-in-One Inkjet...
Constant Paper Jam
check the wheels that pick it from the tray.
If they feel smooth, try to put some tape on them and rip it back off.
This cleans the wheels. Also try a new pack of paper and check if it\'s set to plain paper and not to heavier or coated paper
May 30, 2013 | Brother MFC-7840W Multifunction Laser...
Paper Jam / Printer Dock Series 3
try this no promises
unplug the power cord for 5 sec
paper should feed out after resetting
DONT EVER PULL ON THE PAGE WITHOUT THE MACHINE EXITING IT FIRST. THE TABS ON THE END OF THE PAPER BREAKS OFF INSIDE THE PRINTER DOCK.
check the back of the dock for the photo to eject as well as the front.
check paper size with new one after it exits to make sure no extra pieces are stuck in printer. good luck
DONT PULL ON PAGE JAM (UNPLUG FIRST(RESETS THE PAGE OUT THE BACK/FRONT))
Mar 13, 2009 | Kodak EasyShare Printer Dock Series 3
Installed new 084K18470. Error e2-3 will not clear.
E2-3 is paper jam at tray 3 check paper path as paper exits this tray.
-Carl, please let me know if this helps.
Jan 21, 2009 | Xerox Phaser 4500/YDX Printer
Lemark printer
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button. (On the X83, press the Select button.)
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Nov 09, 2008 | Lexmark X2500 All-In-One Printer
Okidata-B6200-
Check the reg sensor for dirt etc and paper setting is correct in the paper tray
Sep 24, 2008 | OKI B6200 Laser Printer
Everytime I try to print to my PIXMA 9000 I get an error from the print spooler that the printer is not responding. THe print job starts to print, stalls after a few lines.
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
OR=
1. Check the printer and/or the software to see if "manual feed" is selected. If manual feed is selected, the printer may be looking for paper in another tray.
2. Reseat paper. Ensure printer is on-line. Check for paper jams or obstructions.
3. Likely suspect: paper-out sensor is damaged or broken. Consult a computer repair shop.
Sep 16, 2008 | Office Equipment & Supplies
Printer malfunction
The samsung printer have three paper jam sensors. First (paper jam 0) after the feed rollers. Second (paper jam 1) at the left of the feed rollers and third (paper jam 2) at the fuser unit where it is hot. You can see the actuator between the two white rollers. Paper jam 2 is mainly cause by the scrappers out of position on the side of the upper heat rollers.You will have to clean it and put it back into position.
Dec 19, 2007 | Samsung ML-2150 Laser Printer
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
HP LaserJet 1320 Printer Logo
67 people viewed this question
Seeker5211
Seeker5211
