Question about Flip Video Flip UltraHD 8GB High Definition Camcorder
Flip ultra HD won't record. The screen turns green and pixelated. Powers on just fine but when you hit the record button it goes green. Help!
SOURCE: flip ultra hd not charging
I came across the same "Check Battery Pack" message last night when trying to charge my Flip Ultra HD for the first time last night. My husband just took an exacto knife and "trimmed" the plastic around the (-) part of the battery and cleaned the terminal a bit and it works!
Posted on Sep 06, 2009
SOURCE: My Flip Ultra HD wont turn on "Its Too Hot .. Need to cool Down"
Same here , This product sucks!!@!
Posted on Dec 23, 2009
SOURCE: flip videp ultra hd - red light blinking while charging
i have the same problem too. whenever i try to charge it through the dock. the red light continuously blinks and it won't charge.
Posted on Jan 04, 2010
tbreeze47
  • 3083 Answers
SOURCE: Flip Ultra HD won't turn off or on!
It's a bad, intermittent on/off switch. If you're real technical, you can take it apart and try to clean it, chances are it's dirty or the contact is slightly corroded, maybe because of humidity. If you can get a broken "as is" model off ebay, you can swap the parts out, possibly. The last and only easy "fix" to a swith problem, is to spray electric contact cleaner into them, to clean them. There are certain ways that cause less stress to the plastic parts that possibly could be susceptible to cleaner "melting", or damage. This rarely happens, but is only a warning. Now, hold the on/off switch toword the floor, and spray upward, into the switch, pressing the switch on and off as you spray. Blow compressed air into the switch as much as you can, and try to shake the excess spray solution out. Let the camera thoroughly dry (depends on the amount of fluid that got inside), but make sure it's dry, say 10 minutes or so. If the switch doesn't work properly now, the unit will have to be disassembled and further inspected, and possibly repaired or replaced. Other possibilities, such as cold solder joints, or cracked joints can cause similar symptoms, but most of the time it's the switch. Good luck, sometimes you get lucky...:-)
Posted on Apr 16, 2010
SOURCE: Flip Ultra HD - conflicting storage info
connect your flip cam to your computer.openo c drive on your computer.open flip program.look for trash file.empty it.that will restore your full 2hr record time
Posted on Jul 28, 2010
When I press the power button on my ultra hd 2nd generation camcorder, the screen lights up with the flip logo and verbage that says hold the record button for setup. It also makes the correct sound for...
Will the camcorder let you go ahead and complete "SETUP"?? if so, go ahead and redo the setup maybe some glich and maybe doing setup again may get the camera going again? hope so!! I have one also and knock on wood, no problems so far. it may be worth a try:
when camcorder turns on: when Flip Video Logo comes up press and hold RECORD button, to enter setup mode use the + and - to adjust current setting and the left and right arrows to select other settings
good luck!
Apr 25, 2011 | Pure Digital Flip Video Ultra Camcorder
Have a new Ultra HD Flip Video. How do I know when it is fully charged? Does the red light go off or what?
Hello there,
The Flip Ultra should have a rechargeable AA battery pack.
To verify it is charging, the battery icon will be flashing lightning bolt. The red light goes from red to green the moment it is fully charged. It takes six hours before it gets a full charge via the USB.
Please let me know if this gave you enough information. Thank you for using FixYa.
Oct 08, 2010 | Pure Digital Flip Video Ultra Camcorder
My flip mino HD has been charging for 3 hours and will not turn on. I've tried resetting the battery and it still won't turn on
Is it plugged in directly or with a USB extension cable? Some cheaper cables are not sufficient to charge it.
Mar 18, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip Ultra HD red light won't turn off after charging. Camera won't do anything at all. What do I do?
UNIT: ultraHD
PROBLEM:
I just had this problem: I turned it on, started to record a video, but it hung up on frame #1, with the record red light stuck on. And I couldn't do any of the following: restart the recording, play already recorded videos, turn it off, connect to PC.
SOLUTION:
I removed the battery for about 30 seconds, then replaced it. my UltraHD flip works great now.
Jan 26, 2010 | Pure Digital Flip Video Ultra Camcorder
Flip HD camera frozen "on"
Just take out the batteries and put them back in. That should fix your problem. =)
Dec 06, 2009 | Pure Digital Flip Video Ultra Camcorder
My Flip Ultra HD won't charge or upgrade.
What about if I can get it charge, full green bar, but it won' turn on. Then after some time messing with it, I get it to charge again and the battery is empty again. Any ideas???
Jul 31, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip video mino troubleshooting freeze
There is a reset button! Get a pin and push into the tiny hole at the bottom - inside the tripod screw hole. Push in and hold. The camera will reset. I called the Flip support - they were great !
Apr 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Record Beep Tone - How To Shut Off
On the Mino HD, Hold down the record button as you turn the camera on. Navigate the menu and turn off the sound under the sound option.
Mar 31, 2009 | Pure Digital Flip Video Ultra Camcorder
Flip Video Flip UltraHD 8GB   High Definition Camcorder Logo
365 people viewed this question
Top Flip Video Video Cameras Experts
Tom Chichester
ray gallant
Are you a Flip Video Video Camera Expert? Answer questions, earn points and help others
