Question about Dryers
How can I tell if the dryer is getting too hot, like a problem with the thermostat?
  • 784 Answers
Unless the vent gets blocked, when the thermostat activated then it is too hot. However thermostat could be wrong due to aging. Replace the thermostats to see if it still is doing that. Most of the time the problem will be cured.
Posted on Apr 28, 2010
Replace fuse dryer model GEQ8821LLO
Hello;
My name is Peter. I am a retired field service appliance technician.
You never explained what the problem was. Dryer not running? No heat? Dryer shutting down. It could be as simple as cleaning out your dryer hot air distribution manifold. A dryer will not run if you do not have good air flow due to lint blockage. A dryer will not run if you have a bad door switch. You can Ohm components out with a multi-meter, setting the meter to the lowest Ohms (Omega Symbol). You should get a reading of "0" if the component is good.
1.) Dryer Door Switch - This switch replaces your dryer door's switch.
  • You may need to remove your dryer's lint screen and lint screen housing before lifting its top panel to reach its existing switch.
  • Be sure your dryer is unplugged during installation.
This Dryer Door Switch part #3406107 Cost $20.00
Dryer Door Switch - Unplug the dryer before replacing the door switch.
This Dryer Door Switch part #279782 Cost: $22.00
Thermal Cut-Off- This component is located on your heating element housing,. you may be able to access it at your hot air distribution manifold in the back of your unit.
  • When replacing your dryer's fuse, replace its thermostat, too. The thermostat should have prevented the dryer's existing fuse from blowing. The high-limit thermostat is functional to 250 degrees (Fahrenheit) and the thermal cut-off fuse to 360 degrees (Fahrenheit).
  • Install the fuse in your dryer's heater element housing box. Be sure your dryer is unplugged during installation
  • Part #: 3977394 Cost: $33.00
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-9.jpg Cost: $34.00
    The high-limit thermostat replaces your dryer's thermostat.
    • The thermostat is functional to 250 degrees (Fahrenheit).
    • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
    This High-Limit Thermostat part #3390291
    Hot Air Distribution Manifold:
    This is in the back of your dryer and easily unbolted. If you are plugged up with lint your unit will shut down. Remove this component and clean the lower discharge end.
    25432459-jpgjqed1aonpcy4b0i04xdgb-5-14.jpg So, tell me what the problem is, and I will tell you how to fix it.
    Peter,
    Glen Burnie, Maryland, USA
    Feb 15, 2015 | Whirlpool Dryers
    I have a TDC6 drier. It starts drying and dryer light is on, but light goes out and it stops drying? Will you be able to tell me what the problem is?
    DRYER OVERHEATING:
    Heating Element
    A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
    Other Causes and Conditions
    Air Flow Problem
    Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
    Cycling Thermostat
    Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
    Felt Seal
    Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
    Blower Wheel
    A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
    https://www.youtube.com/watch?v=3m5NZvY9V5Q
    Electric dryer no start does nothing
    Oct 10, 2014 | Dryers
    Why does dryer gets super hot
    DRYER OVERHEATING:
    Heating Element
    Air Flow Problem
    Cycling Thermostat
    Felt Seal
    Blower Wheel
    GOD IS still GOOD !!!! SO MY ADIVE IS FREE
    Aug 02, 2014 | Dryers
    Dryer gets hot and turns off
    Hello there:
    A lot of the times the problem lies with in the Cycling thermostat that is going out Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly.and can make the dryer stop working after it is working for a given amount of time If so, you need to replace it.
    Next is the The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
    It overheats and shuts down due to a bad thermostate Usually when an electric dryer overheats it's because of a defective cycling thermostat or a clogged vent system. Clean any lint from the internal and external ductwork, and/or replace the cycling thermostat (read about cycling thermostats in "Drying is too slow," above). It seems to run forever If your dryer seems to run forever, it could be because of a clogged vent or internal ductwork. Your dryer may have an automatic cycle that turns off the dryer when the clothes are dry. It does this with a special thermostat or moisture-sensing system. Normally, this is what happens during an automatic cycle: The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees. When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.) The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again. This cycle continues until the clothes are dry. But...if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
    Sep 27, 2010 | Kitchen Ranges
    I just bought a new heating element for a 70 series dryer and it is still not getting hot. What is another possible solution
    test the hot side of the heater element, also check that the circuit breaker has been turned all the way off then all the way back on. If this does not fix it or you have tried it let me know and I can tell you what to check next.
    Aug 20, 2009 | Dryers
    My front loader dryer stopped heating,
    have a electrician inspect the circuit going to the dryer as it might not be providing proper current to operate the dryer
    Jun 22, 2009 | Maytag MDE9206 Dryer
    Dryer will not turn off
    • The thermostat tells the dryer to heat until the interior of the dryer reaches a pre-set temperature--say 135 degrees.
    • When the dryer reaches the pre-set temperature, the thermostat tells the timer to begin advancing. (If there's a moisture sensor, the timer advances only if the moisture content of the clothing is low enough.)
    • The timer advances until the interior cools, then the thermostat tells the timer to stop advancing, and tells the dryer to start heating again.
    This cycle continues until the clothes are dry. But…if the vent is clogged, the dryer may never reach the proper operating temperature, so it doesn't send the signal to the timer and the dryer continues to run indefinitely, even if the clothes are completely dry. To fix the problem, clean the vent and/or internal ductwork.
    May 20, 2009 | Dryers
    Dryer not heating
    Don't think so. My issue with the no hot air on the dryer was the relay switch. There is also a heat switch and thermostat that could be a problem.
    Nov 17, 2008 | Kenmore 62602 Electric Dryer
    Whirlpool gas dryer is not hot .burner ignights but it is not hot enough
    if this helps please give me a fix ya vote
    Jul 14, 2008 | Whirlpool Dryers
    Dryers Logo
    41 people viewed this question
    Top Dryers Experts
    Dan Webster
    Dan Webster
