Mitsubishi mod WS55511, 55" platinum series, power and code problem
The TV was working fine day before until that night while trying to turn on the tv from remote shows no power. Then I turned on from the TV, there was power but would not change channels or switch back from DVD to TV, or anything due to funchjtion is either lock or what. Is there a code or something that we can get it worked on?
  • Anonymous Jun 11, 2008
    ws55511 55, green led blinking 70 seconds goes off.press menu 10 seconds.nothing happens.have diconnected all inputs overnight still no luck.seems to be a comon problem.my set is 5 yrs old.is it time for a pro or could this be a simple fix......
    Genius:
  • 1,153 Answers
Press the menu button for 10 sec on the set
Posted on Mar 24, 2008
MITSUBISHI WS55907 Diamond 1080 TV bought in 2000 was powered off, unplugged, for a year. Turned the set on with remote last night and worked fine, had very crisp picture.
Your TV was waiting between 2000 and now to suffer power supply failure. It is very frustrating to go from everything working perfectly to nothing.
Oct 31, 2016 | Mitsubishi WS-55907 55" Rear Projection...
Mitsubishi cold 3.0 v6 workshop manuals
If your philips tv keeps losing it's stations when you switch it off, this my be a solution -----my 42" tv would need to be retuned every time I wanted to watch it this fault just started over night it was all working fine then sat down to watch tv and had to retune tv from scratch I could then watch telly all night fine change channels no probs all great switch it off next day retune and so it went on if you have this problem switch telly on then hold in menu button on tv until screen goes black (this reboots software) then retune tv as normal it will ask if you want a full retune (yes) when this is complete digital and analogue your tv should now remember channels when switched off and work as it used to ----( Hope this helps you if you have had this problem it worked for me ). Good Luck
May 29, 2014 | Televison & Video
WD57732 purchased 12/06 and has worked fine. Turned off at 11 pm last night. No indication of trouble. Tried to turn on this morning and nothing. Did TV Reset, green light flashed for a minute like it...
Now,tv on?.Tv "LAMP" LED light indication flashes or stay on?How long the Lamp been inside this tv,been inside like 1 1/2 or 2 years and tv been on each day like 4 or 5 hours a day in used.The lamp life are over.Should replace another lamp.
Dec 10, 2010 | Mitsubishi WD-57732 Projection Television
My mitsubishi HDTV series 1080 will not power up a green light come on then goes right off
i have the same exact problem. My mitsubishi HD 1080 series suddenly stopped working. when i hit the on button, the on-light goes on for a second and then goes right off. any luck figuring this out?
Jun 26, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi WD-52525 was working fine and now it will not turn on
This is just a shot - but it worked with my Sony (same problem).
Pressed remote power on button AND held Power button on TV on at the same time.
Set clicked 4 or 5 times and then came on....
Other, most have a (VERY small) reset switch on the rear - near where the power cord enters the TV... Use a flashlight and a mirror to locate it on your set....
Nov 26, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp Indicator is Red
a 41 error code for a short is usually caused by the power PWB. The power board will need to be replaced
May 30, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi rear projection HD1080p tv model # ws-48311
press in the menu and input/device buttons both in together on the TV and hold in for 6 seconds to see if the led will blink a two digit error code then let me know what the code was.
Sep 10, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Power plus universal remote control codes
Try downloading this manual
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/mitsubishi/bd512-manual.zip&area=other
Jul 13, 2008 | Televison & Video
Televison & Video Logo
130 people viewed this question
Top Televison & Video Experts
Electro Med Services...
