Question about Craftsman 20 hp 42 in. Deck Yard Tractor
Where is the oil drain plug? - Craftsman 20 hp 42 in. Deck Yard Tractor
    Problem Solver:
  • 6 Answers
Do you see a small plastic yellow cap on the side of the engine below the oil dipstick? If so you pop the cap off and use a small plastic tube to drain oil away from frame and slip over the place where the cap came from and push in and turn to the left( I think). When the oil quits draining push in and turn back the opposite way then replace the yellow cap.
Posted on Apr 27, 2010
Where is the oil drain plug on this mower engine.
The oil drain plug is usually on the bottom of the engine. ,if not you may have to turn the mower on it's side and drain the oil out the fill tube.
Mar 08, 2015 | Garden
+how to change engine motor oil
let engine cool down. that way all the oil will drain to the pan. leave engine off until new oil is added. it is a good idea to also change the oil filter at this time. you can ask the guy's at the place where you bout the oil, how many quarts your car will take. autozone is a good source. they can also recoment the right oil as far as viscosity. now it's time to crawl under your vehicle and remove the drain plug. don't forget to put the drain pan directly under the drain plug and oil filter that's why i always use a container that i buy from the dollar store, it's big enough to get under the drain plug and the filter(carefull, the oil filter will still have oil in it). i think they mostly use them for doing dishes. let it set and drain for 10 minutes to get the most old oil out..................now it's time to add the new oil and filter. in this order.....add new oil filter(wet the seal of the filter with oil), add new oil except for last quart. (last quart add only half of it as there are lots of cars that require for example.........(5 1/2 quarts) now start engine and look for leaks around filter and oil plug. now remove drain pan or you'll probably run over it. lol take it for a short drive and while engine is still running, check for leaks again. if you have followed these instructions, your done. congratulations !!!.
Oct 04, 2014 | 2014 Nissan Pathfinder - All Pathfinder...
The oil doesn't drain out of my 2001 Harley Davidson Dyna When I remove the oil plug only a half quart of oil drains out. Dipstick is removed and oil is hot.
Are you sure you're pulling the correct drain plug?
On Harleys with the oil tank under the engine, there are usually two drain plugs, oil and transmission drains.
Also, some have a drain on the bottom of the engine, which only a little residual oil will come out of it.
Finally, when the oil stops draining from wherever you're draining from, does the oil dipstick show that the oil level has dropped?
If not, you got the wrong plug!
Aug 07, 2013 | Harley Davidson FXDL Dyna Low Rider...
Oil change 1994 Cadillac Eldorado
well let me see you have 4.6L engine you need 7.5 quarts of oil with new oil filter.to do the oil change you need large drain pan and oil filter wrench and a metric wrench to remove oil drain plug you need a funnel also.you need first start engine let it run for 5 minutes to warm up thin out the oil so it will flow better.once engine warm up.turn off the engine.open you hood.now safely raise support vechicle on jack stands make sure vechicle parked on solid level ground.place large drain pan under oil pan remove oil drain plug you need a 15m wrench remove drain plug let all old oil drain out until you see slow drip then reinstall oil drain plug dont over tighten drain bolt.then place drain pan under the oil filter then remove oil filter using oil filter wrench or large channel lock pliers.once you remove oil filter wipe oil filter seal surface with clean paper towel.take new oil filter add oil to new filter then install new oil filter hand tight take filter wrench turn oil filter one half more turn dont over tighten will damage oil filter seal.make sure oil pan drain plug is in place. then lower vechicle. remove oil filler cap on the valve cover add new oil to the engine using a funnel to keep from spilling oil all over the valve cover and exhaust manifold.add all 7.5 quarts to oil crank case wait until oil settle down in crank case check oil dip stick oil level should be at the full mark on oil dip stick.dont over fill crank case.once you finished oil level correct crank engine check for oil leaks at oil filter and oil drain plug. if engine running okay you see no oil warning lights you ready wheel and deal.
Nov 20, 2011 | 1994 Cadillac Eldorado
Weed eater 22" mower with
Hi stnstomper...
Look under the mower for a square plug or allen wrench type plug, this will be your oil drain for the motor.
Some of Briggs & Stratton motors do not have an oil drain plug...
If you do not have an oil drain plug then you will have to run the mower to get it warm, then remove the oil fill plug and tip the mower towards the oil fill plug to drain out the oil thru the fill plug hole.
Free Answer...Please take time to rate me
Jun 13, 2011 | Mtd 22" Yard Machine Push Mower
I added oil to my Cadillac and it drained onto the ground
Before adding any more oil, make sure that you have securly replaced and tightened the oil drain plug (which is located on your engine's oil pan, under your car).
The FixYa Team!
Feb 01, 2011 | 1996 Cadillac DeVille
How do i change the oil filter on a 1991 cutlass calais? any special tools?
YOU NEED 4.5 QUARTS OF OIL WITH NEW OIL FILTER.YOU NEED OIL FILTER WRENCH YOU NEED WRENCH TO REMOVE OIL DRAIN PLUG.YOU NEED A DRAIN PAN CATCH OLD OIL.NEED LATEX GLOVES TO KEEP GETTING OIL ON HANDS.OIL DOES CAUSE SKIN CANCER.NOW YOU CRANK CAR UP LET IT IDLE 5 MINUTES TO LOOSEN UP OIL AND SLUDGE.TURN OFF ENGINE.SAFELY RAISE SUPPORT VECHICLE ON LEVEL SOLID GROUND USING JACK STAND.PLACE DRAIN PAN UNDER OIL PAN THEN REMOVE OIL DRAIN PLUG LET OIL DRAIN OUT UNTIL IT STOP DRIPPING. PUT OIL DRAIN PLUG BACK IN OIL PAN. THEN SLIDE DRAIN PAN UNDER OIL FILTER REMOVE OIL FILTER LET OIL DRAIN UNTIL IT STOP DRIPPING.TAKE CLEAN PAPER TOWEL WIPE OIL FILTER SEAL SURFACE MAKE SURE NO DIRT ON SURFACE.TAKE NEW OIL FILTER POUR NEW OIL IN FILTER UNTIL ITS ALMOST AT TOP THEN.RUB CLEAN OIL ON NEW OIL FILTER SEAL.THEN PUT NEW OIL FILTER IN PLACE HAND TIGHTEN IT.POUR 4 QUARTS NEW OIL IN ENGINE CRANK CASE USING A FUNNEL.WHEN DONE.CRANK THE ENGINE CHECK FOR LEAKS AT OIL FILTER AND OIL DRAIN PLUG.IF ALL IS GOOD JOB WELL DONE.
Aug 11, 2010 | 1991 Oldsmobile Cutlass Calais
Looking for the oil drain plug on my 2006 dyna street bob
you probly drained the primary case oil, which house the primary drive chain and clutch. The main oil is in the oil tank, there should be a drain bolt on the bottom of the tank
May 21, 2010 | 2006 Harley Davidson FXDWGI Dyna Wide...
Location of oil drain plug on harley davidson road king
The tank on your Road King is on the bottom of the transmission. Look underneath the transmission and you'll see two drain plugs. The plug on left front of the oil pan is the engine oil drain. The plug near the center of the pan is the transmission drain plug. Good Luck, Steve
Apr 28, 2010 | 2001 Harley Davidson FLHRCI Road King...
Change the oil on a 2000 Dodge Caravan
Jack up pass side.Put cardboard, BIG piece under engine just in case. Using a pan to drain the oil in put under oil pan drain plug. Remove drain plug with socket wrench. Let drain 5 min. Check the gasket on the drain plug, if bad replace with new gasket .99 cents to replace gasket only on plug. Put plug back in DO NOT OVER TIGHTEN the plug. Slide drain pan with drained oil to the front to remove oil filter. Using a filter wrench remove oil filter. Let drain. When installing new filter put a little new engine oil on the rubber gasket on the filter with your finger. Screw filter back on tighten with filter wrench. Fill van with oil from front valve cover opening.
Nov 21, 2009 | 2000 Dodge Caravan
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
193 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
