Question about Nextar Q4-04 Car GPS Receiver
Where I can I find a SD card for GPS with the map of canada and the US?
  • 508 Answers
I would start here if i was you. If you download the maps and then upload them onto a new SD card you should be ok.
http://www.nextar.com/frontend/prodsearch.asp?keyword=PART-GPS-MAP09SDC
Hope this helps
Posted on Apr 27, 2010
Only shows us routes not canada
I fell foul of that the other way. I have Canada maps and lent it to a friend who was going to California.
You need a map that covers Canada and it is an extra cost. The USA is in two zones, or one map does both zones.
You need to buy the Canada maps and then put it on an SD card. The map costs $84
https://buy.garmin.com/en-CA/CA/maps/on-the-road-maps/city-navigator-nt/city-navigator-north-america-nt-canada-only/prod8750.html
City Navigator North America NT Canada Only Garmin
Feb 20, 2016 | Garmin Nuvi 2360Lmt - Gps Receiver
Can you put in a SB card in your computer and up date your GPS or put in Canada?
That's exactly how you add maps to a newer GPS.
You copy the map and other data files (depends on make and model what you have to copy) onto the SD card and insert into the slot on the GPS unit. Then you go into the utility menu and select your new map.
Other than check to see if you need to have the files in a certain folder name or directory it is that easy.
Usually you will have a map utility on your computer that will load the map or when you plug in a usb cable the GPS and the SD card are seen as two removable drives.
Sep 04, 2009 | Nextar GPS
I am not able to input Canadian addresses into my Garmin nuvi 660 GPS
Hi,this will be dependant on the sd card and it,s maps database. if you have usa maps. this probably does,nt include maps of canada. check nuvis site, to see if canada maps are available for download or purchase.Mike @ Compurepair.
Jun 12, 2009 | Garmin Nuvi 660 GPS Receiver
My unit came with US map, I downloaded Canada Map, but...
magellan maps can only be used once and if you downloaded a torrent, chances are its been used already
Jun 11, 2009 | Magellan Roadmate 1200 Car GPS Receiver
Garmiin nuvi gps,
The device uses SD cards actually. They will not however work with TOPO maps or Bluechart. They are primarily for loading media or city street maps for other country's.
Jan 14, 2009 | Garmin 010-C0495-00 TOPO Canada - Manitoba...
Magellan Triton 500 value bundle
magellan has a big problem in the past with the Canada Value Pack. It did not work with the Triton. It was only made to work with the older Magellan GPS units.
Best to contact Magellan and see if they will give you a new one.
Dec 29, 2008 | Magellan Triton 500 Handheld GPS Receiver
I cant get no canadian maping?
The 400 supports Canada, the 300 does not. According to their website, they only listed those two models.
Here is the support website:
http://www.finedigitalusa.com/2006/support_01.htm
Jun 21, 2008 | Fine Digital FineDrive 350 GPS Receiver
Putting maps on sd memory card
(Untried)
For C330 owners that want to have both Canada and US 2008 map update on their GPS this is what you have to do.
Must have:
1 - Street pilot C330
2 - 512mb SD card
3 - SD card reader of some form (some cameras will suffice)
4 - Garmin 2008 Map Update North America
What to DO:
1 - connect the GPS to the computer
2 - Insert the Map update disk
3 - Install the Lower 48 states, United States
(Reason - the C330 has around 1000mb of memory and the "US 48 states" map uses around 900mb" while Canada uses 400mb...which is why you will need that 512mb SD card later)
4 - Once the GPS is updated with the US map. Browse the Map update disk contents. This can be done with going to "My Computer" right click on your CD/DVD drive and click on "Explore"
5 - Open the folder called "img"
6 - Copy the file called "gmappromU.img" file is around 430mb. (This is the map file for Canada)
7 - Insert your SD card into your card reader and connect it to your computer. A window should pop up. If not you should see it on your "My Computer"
8 - Once you have navigated your way into the SD card directory. Create a folder on the SD card named "garmin" (no caps)
9 - Go into your newly created "garmin" folder right click and paste the "gmappromU.img" file. (This may take upto 20 to 30 mins)
10 - Once the process is complete, Rename the "gmappromU.img" file to --> "gmapsupp.img" (watch for spelling, no caps at all)
11 - Remove the SD card, Turn off your GPS, Insert SD card into GPS.
12 - Turn on GPS, let it load, and there you have it, the FULL North America Map.
When you are searching a state or province (depending where you are located) it will give you an option which map to use, Canada/Alaska or the lower 48 US states. Select your map and you are set to Go.
Feb 01, 2008 | Garmin StreetPilot C330 GPS Receiver
Error message
The WGPX-550 doesn't support 2GB card. You can have Canada on a separate card (512MB will be big enough) and Canada includes the bordering US states
Dec 31, 2007 | Whistler WGPX-550 GPS Receiver
Error code.
I had the same problem, but the fix was to download directly to the SD card.I had been downloading to the pc and then copying to the card.Once I downloaded directly to the card everything worked great
Nextar Q4-04 Car GPS Receiver Logo
393 people viewed this question
Top Nextar GPS Experts
Are you a Nextar GPS Expert? Answer questions, earn points and help others
