Question about GE Profile JK915 Electric Single Oven
When my GE wall oven is in the middle of heating up, I get an F3 edit and the oven keeps beeping. I turned it off and then turned it on again and it seems to be heating again. What part should I look to replace?
  • GE Master
  • 3,051 Answers
Hello there:
Normally this is due to a bad temperature sensor F3 Open oven temperature sensor circuit Measure oven temperature sensor circuit at oven temperature sensor (should be approx 1100 ohms at room temp); check for cut or pinched wire or loss of contact and replace if found faulty
Posted on Apr 30, 2010
Wall oven flashing f3 and beeping
Use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
If your oven sensor tests good, then your control board would need to be replaced.
Apr 10, 2011 | GE Ovens
Shortly after pressing the Bake button it starts beeping and F3 shows on screen. In the past, it would do this a couple times and then begin to heat and be fine. Othertimes, it would just stop cooking in...
F3 error code is telling you the oven temperature sensor has failed on the oven. You can access the oven sensor from inside the oven. The sensor is a stainless steel probe about 1/4 inch in diameter and several inches long. Disconnect the power to the oven and remove the screws that secure the probe to the rear oven wall and you can usually pull it into the oven.
Jan 19, 2011 | Kenmore Ovens
On my GE jkp27w0w2ww i keep having F5 and F3 appear almost everytime i cook. I turn off the oven when it happens and then turn it back on and it usually happens again. Is there something I can do, and what...
F3 is usually an oven temp sensor. Replace the sensor. (pencil shapped probe at back top inside oven) It usually can be replaced from inside the oven by gently coaxing the plastic connector through the hole behind the sensor. Sometimes, it is only the plastic plug connecting the sensor. A possible bad connection can be eliminated by usings ceramic (high heat) twist wire connectors to make better connections.
Jan 02, 2011 | GE JKP27 Electric Double Oven
F3 keeps flashing on the display
F3 or F4 Open or shorted oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Nov 25, 2010 | GE 30" Built-In Single Electric Wall Oven...
GE Wall Oven JTP 10GP F3 code when I turn it on it goes straigt to F3
on our maytag a f3 code means shorted or open temperature sensor. do not know if that code is the same as a ge, but you can google your oven model codes and find out what the problem is.
Jun 21, 2010 | GE Profile JTP18 Electric Single Oven
Receiving F3 Code
HI, no need to replace the unit at this time. this is a Open or shorted oven temperature sensor (RTD).
Jul 16, 2009 | GE JRS04 Electric Single Oven
F3 and F5 signals
could be a probe thats that brass looking rod you see when you open the oven f3 is oven probe code it controls the temp some of them you can take the two screws out on the in side and pull the probe out far enough to get to the connector to change some you have to pull the oven
Sep 10, 2007 | GE JKP15 Electric Single Oven
F3 code
It's your oven temperature sensor. It's a thin metal stick that juts into the oven. It is located on the upper right back wall of the oven cavity. Flip your breaker, slide out the oven. You install it from the back, very simple, two screws, i think. I'm a beginner at DIY and had no problem fixing it.
Feb 23, 2007 | GE Profile JK915 Electric Single Oven
GE Profile JK915 Electric Single Oven Logo
152 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
