Question about Compaq fs740 17" CRT Monitor
Constant hum after power surge
Monitor has a constant loud hum after a power surge. It continues whether display is on or off. If it is plugged in it hums. Any suggestions?
  • malibu1000 Mar 25, 2008
    I deguassed it. No change.
  • 85 Answers
Try using the OSD menu to Deguass it.
Posted on Mar 24, 2008
Klh powered subwoofer model ASW10-120B... when you plug in to power... it makes a loud buzzing/humming noise
I would check the caps on the power supply. They are rather large electrolytic capacitors that will look like they burst and/or leaking. When these die, the caps ground and the sub will make a loud buzzing sound. If you are handy with a soldering iron you can replace them yourself. Replace them with the same voltage or a little bigger and same with the size.
If the cap. says 16v 4700pF on it, for example, a 20v 5300pF or a 16v 6200mF cap. will work for this application.
Jan 05, 2016 | Audio Players & Recorders
Our KitchenAid microwave works well, heats food, etc., but makes a constant loud and annoying humming noise (close in frequency and tone to the hum of cold fluorescent tubes) even when not in use. When...
hi it could be a bad neutral connection on your plug or inside on your high voltage transformer check the plug for burning and try plugging it in a different socket
Mar 17, 2011 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Device is making a whistling sound or humming sound. It still has power and is powering the devices plugged into the back up system.
Is the unit running on battery power? A hum is normal when the inverter is running.
if it is CONSTANTLY making a humming noise, it is possible the unit is failing. Check your battery inside the unit, make sure it does not look swollen at all. If it is, you know the unit is failing and overcharging the battery. If it is not, pull the power cable from the outlet and see if it provides back up power and then plug it back in.
If the connected equipment stays on line, then the unit is working fine however I would consider buying a replacement UPS in the near future, a constant hum all the time is a bad sign.
Annoying hum from speakers w/system off
The big electrolytic capacitor(s) in the power supply. The filter out the 50/60HZ hum in the mains, so you could be hearing the mains hum!
Jan 02, 2010 | Memorex MX4100 CD Shelf System
Constant hum from speakers
It sounds like you might have a grounding issue. Try connecting to the wall outlet with a ground prong lifting adapter. Not just the speakers but the source plugged into the speakers also. Good luck.
Oct 09, 2009 | Logitech Z-10 Computer Speakers
My external hd makes a constant, loud noise
Back up your files and buy a replacement drive the grinding noise is the hard drive experiencing mechanical failure and may stop working soon.
Oct 08, 2009 | LaCie Computers & Internet
Constant buzzing in my 15 W amplifier
Make sure you have a ground prong on your power cord. Most input jacks nowadays are closed circuit. They have a switch built in that won't allow any sound without the cord plugged in. You may have a damaged jack that will give you a loud hiss, a loud hum or crackling depending on what volume your controls are set at.
Aug 27, 2009 | Line 6 Spider Iii 15 Modeling Guitar...
Audio technica at 4040 constant ground hum noise
you can test the cable from connection to connection for continuity from end to end. There should be no resistance( a complete short) If the cable is good, there is a bad or broken connection inside the mic. Good Luck
Jun 23, 2007 | Audio Technica Audio-Technica AT4040...
Constant beeping,won't turn on
What is the beep pattern? beeeeeeeep, beep,beep beeeeeep etc. also what BIOS do you have?
Aug 05, 2006 | Gateway EV 700 17" CRT Monitor
Open Questions:
See all Compaq fs740 17" CRT Monitor Questions
Compaq fs740 17" CRT Monitor Logo
83 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
