Washing machine displays FH fault and water tap closed light comes on,water taps are both on and working correctly.
  • 299 Answers
? If there is no water in the unit: —Make sure that both valves at the water source(s) are turned on all the way. —Check for plugged or kinked inlet hoses or plugged screens in the inlet valves. —Verify inlet valve operation. ? If there is water in the unit: —Verify drain pump operation. —Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch. 1. Verify there is not a siphon problem. 2. Unplug washer or disconnect power. 3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter, and Central Control Unit (CCU). 4. Check all hoses for possible leaks. 5. Plug in washer or reconnect power 6. Verify pressure switch operation. 7. Verify flow meter operation by blowing air through the part and measuring the resistance. 8. Verify CCU operation by running a Diagnostic test or any cycle.
Posted on Apr 27, 2010
My whirlpool keeps coming up fh and red light comes and water tap closed what does this mean
if you lift the top of your unit you will find the paper work for repairs in there and also has the code sheet.
Feb 11, 2016 | Whirlpool Washing Machines
My whirlpool 6th sense washing machine keeps saying water tap closed half way through a cycle and displays FH what dus this mean?
That's a water filling problem.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Oct 04, 2011 | Washing Machines
We have an AWM8143 (German Made ) whirlpool front loader. The machine stopped during a wash just before the rinse cycle and is coming up with 'FH' fault on the display. The windows on both inlet...
The 'FH' fault is listed as "Water Inlet Fault" in the manual. When the windows in the inlet hoses come up with their red dots, it means that the leakage valve has tripped and shut off the water at the tap. No water will flow into the machine. This can be confirmed by first turning the taps off, then taking the hoses off at the machine end. While holding the loose ends of the hoses over a trough or sink, try turning the taps on. No water will come out. I've had the same thing happen to us. We were quoted $66.00AU per hose for replacements. I'm going to try to fix one of these hoses today. They have a sponge in them which expands when it gets wet and shuts off a valve. I'm going to try getting the sponge very wet and squishing it back down and hopefully opening the valve again. Hope this helps.
Jun 07, 2011 | Whirlpool AWM8143 Front Load Washer
Fh comes up on the screen
"FH" is a No Water Detect error.It is an indication that you either have no water coming into the washer, or very little water at all. Check whether the water taps are turned on sufficiently, the inlet hoses are not kinked, the water inlet valve is not clogged, you don't have a siphoning issue, and/or the drain pump is working.
Thank you !!
Aug 17, 2010 | Whirlpool Washing Machines
The machine displays FH, what does this mean?
Thank you !!
Jul 02, 2010 | Whirlpool AWM8143 Front Load Washer
Whirlpool washer duet
The FH means water tap closed. If you were happy with using cold only you could get a Y-piece connector and join both the red and blue inlet hose to the cold tap.
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My whirpool aw614 displays FH error display which suggest water inlet probs, clean filters a;though they are spotless, still get same prob, on some programs it will work until it comes to rinse, where it...
Suspect low water flow rate ., check flow rate from main sink tap , when turned on full this should be pretty fierce. Put machine on normal cool wash , when it is taking in cold water through the soap drawer , pull out the drawer a little , the water flow rate should be allmost the same as the tap , if not investigate , fill pipes at rear etc..
Nov 02, 2009 | Washing Machines
Water tap closed led illuminated also FH in time remaining
traced the fault to the cold water valve solenoid not operating so pleased to say that the person that sold me the washer has now given me my money back
regards paul
Jan 25, 2009 | Washing Machines
FH Error on a whirlpool front loading washing machine
fh is no water in unit if no water coming in suspect fill valve if water comes in first ck drain hose ..be sure it is correct height from floor and fits loosely in standpipe it may be siphoning out fast as it runs in..next suspect flowmeter this is under top left side has a small hose in and 1 out with 2 blue wires attached ..this let,s computer control know there is water flow into machine try tapping it lightly with a screw driver if problem corrects replace it if not still might be flowmeter it has a small leaf switch that will stick in postion
Sep 24, 2008 | Whirlpool Washing Machines
Washing Machines Logo
82 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
